Old 08-07-2013, 02:23 PM   #71
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by altezza280t View Post
if you like the tail loose then go FR-S spec. BRZ spec will make the car more neutral
We used the BRZ spec in my daughters FRS, she claims the car is neutral and no longer "tail happy".
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-07-2013, 02:33 PM   #72
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
i like tail happy . Might be some negative effects in autox/track, but it's all part of the fun.
bkblitzed is offline   Reply With Quote
Old 08-09-2013, 11:55 AM   #73
mrk1
Drives: Sterling BRZ Ltd
I have the BRZ swifts in my car and I don't think they cause understeer at all. It comes down more to how you drive through the corner then anything. I find the car very neutral but can I can induce either under or steer when needed. Go in to hot and heavy and it will understeer. Sudden lifts will cause over steer. I am still on factory tires and have put small spacers on the rear top hats to raise it a bit and dial out some of the camber, really helped the rear of the car come around and not stick so hard.
Over all very happy with the springs, its the first fiance approved suspension Ive had in any car.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-17-2013, 08:40 AM   #74
trustyler
Drives: Toyota 86
Sorry to resurrect this thread. I'm currently looking at Swift lowering springs as well because I have read good reviews. I want my car lower by just about an inch and at the same time handle like OEM or better. I have read that these springs aren't just for show and improve not only handling but soaks up bumps better resulting in a great daily driver set-up. My question is, I have a Toyota Ft86 Philippine version. Should I go with an Fr-s spring or a BRZ one? Also, I know the 2 different spring rates up front induce either oversteer or understeer. But when it comes to comfort, will there be a difference if I choose one over the other?
trustyler is offline   Reply With Quote
Old 10-17-2013, 12:29 PM   #75
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I am running the swift BRZ specs. I would recommend the FR-S spec springs if you plan on using the factory dampers as they will give more adequate damping for the slightly lower front rates on the FR-S springs.
Intent > Content
Old 10-17-2013, 12:42 PM   #76
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
I'm going to go with frs springs. I like being able to kick out the rear end for fun every now and then and dont plan to autoX.
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 10-17-2013, 01:15 PM   #77
trustyler
Drives: Toyota 86
Thanks for the reply guys!
Old 10-17-2013, 05:19 PM   #78
solidONE
solidONE's Avatar
I got under steer after installing BRZ spec swift springs. Added negative camber out front to bring it back closer to neutral, but the front feels under damper by the stock struts.
Intent > Content
Old 10-17-2013, 05:21 PM   #79
tonystewart
The car has Koni's, it's neutral
Old 10-17-2013, 05:28 PM   #80
solidONE
solidONE's Avatar
How are you guys liking the koni/swift combo? Rides better than the factory dampers with the springs (less oscillation after bump), I'd imagine.
Intent > Content
Old 10-17-2013, 05:30 PM   #81
tonystewart
Good ride, no issues, pleased with overall package
The Following User Says Thank You to tonystewart For This Useful Post:
solidONE (10-17-2013)
Old 10-18-2013, 03:53 AM   #82
Anaxilus
Drives: They have four wheels
Unrelated to handling dynamics, but the FRS rates seem to promote front/rear oscillation on bumpier roads due to softer fronts. Something to think about for DD.
Anaxilus is offline   Reply With Quote
Old 10-18-2013, 07:31 AM   #83
tonystewart
Good point
Old 10-18-2013, 08:01 PM   #84
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
That's the basic reaction we have been getting from our customers as well!
As simple as it may sound, I still try to recommend FR-S Swifts for FR-S' and BRZ Swifts for BRZ's
Also I talked to Swift about the bump stops since we work closely with them for our race programs and other ventures. They said that the springs are made in conjunction with the stock shocks and stock bumpstops in mind so trimming them is not 100% neccessary. HOWEVER, if you want and need more travel within the shock you can cut the bumpstops to whatever applications you are using the car for, but in modern day suspensions a bumpstop isn't just a regular peice of poly or rubber anymore, it's an elastic part that actually has a rate in it.
Surprisingly these have been flying off our shelves still!
Thanks,
Michael
Corner3garage is offline   Reply With Quote
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 09:36 PM
Stance coilovers with Swift Springs clickfiveZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-05-2013 06:20 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 04:26 PM
Fortune auto with swift springs? DarkCard Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 03-29-2013 03:15 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
