Old 02-06-2012, 01:37 AM   #1
ayau
Drives: Some rust bucket
Official JDM BRZ weight and MPG
1230 kg = 2706 lbs
12.4 KM/L converted to MPG is 29.17.
http://www.subaru.jp/brz/brz/spec/spec.html
Old 02-06-2012, 01:43 AM   #2
Xdragonxb0i
Drives: ex500r
pretty good, but i was expecting at least 35. i mean that what DI was suppose to be for.
i wonder if its an average of city/hwy. Why do the different specs get different MPG rating.
13.4 for RA. and 12.4 for the S
Xdragonxb0i is offline   Reply With Quote
Old 02-06-2012, 01:45 AM   #3
ayau
Because the lower grades weigh less.
Old 02-06-2012, 01:45 AM   #4
dsgerbc
Drives: BRZ(sold), STI
40 kilos lower mpg by 2.5? Hm.
Old 02-06-2012, 01:50 AM   #5
dsgerbc
Here:
Japanese 2005 emission regulation introduced a new JC08 chassis dynamometer test cycle for light vehicles (< 3500 kg GVW). The test represents driving in congested city traffic, including idling periods and frequently alternating acceleration and deceleration. Measurement is made twice, with a cold start and with a warm start. The test is used for emission measurement and fuel economy determination, for gasoline and diesel vehicles.
The JC08 test will be fully phased-in by October 2011. In the transitional period emissions are determined using weighted averages from different cycles, as follows:
2011.10: 25% of JC08 cold start + 75% of JC08 hot start.
Pretty harsh test, if you ask me.
Old 02-06-2012, 02:44 AM   #6
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Its also a different final drive ratio for the open diff vs LSD
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 02-06-2012, 04:31 AM   #7
serialk11r
Drives: '06 AM V8V Coupe
Notice the test doesn't spend much time holding speed, so the higher diff ratio isn't making much of a difference. The frequent stopping/starting means the weight will matter much more as you can see. On the highway, the diff ratio will determine the cruising efficiency, which I predict to be pretty low. Hoping Toyota changes the 6th gear to 0.62 ish for a 2200 rpm cruise on the 4.100, 2000 on the 3.727, or even lower.
Oh and another thing to note is that the faster the car, the more it is hurt on a test like this because the acceleration is pretty leisurely (to accomodate the slow cars).
For more extreme gas savers, the good thing about a 2.0L engine is the idle consumption is low so you can pulse and glide with the engine on and get a very high mpg number.
Old 02-06-2012, 04:52 AM   #8
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
If you read the notes on Subaru's website, the fuel mileage information becomes a tiny bit more clear.
RA 6MT = 13.4 km/L without A/C, 13.0 km/L with A/C (16" Wheels, 3.73:1 Final Drive)
R 6MT = 13.0 km/L (16" Wheels, 3.73:1 Final Drive), 12.4km/L (17" Wheels, 4.10:1 Final Drive)
S 6MT = 12.4 km/L (17" Wheels, 4.10:1 Final Drive)
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 02-06-2012, 11:35 AM   #9
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
Well it looks like these figures are for city driving, not highway like we were assuming, based on the JC08 spec. So in a 20 min session with 10 stops and starts, less than a minute of sustained highway(ish) speed and plenty of acceleration (albeit slow acceleration) 29.2 mpg is quite impressive. I'm trying to find two equivalent cars to compare JC08 vs EPA ratings, which is hard when you can't read Japanese.
Edit: I guess I was wrong. The 2.0L SKYACTIV Mazda 3 gets 38mpg from the JC08, which is almost exactly it's EPA highway rating (39), so now I'm just confused. I need to stop speculating. It's way too frustrating.
GT86: "This car has two steering wheels: one is circular, the other is operated with the right foot."
no_name is offline   Reply With Quote
Old 02-06-2012, 01:46 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Isn't the JDM motor quite different from the US on the SkyActiv Mazda 3 though?
I have no idea how JC08 compares to the EPA testing, but that may be a bad example. I recall the compression ratio at least being significantly different but I may be wrong (on the US vs JDM Mazda 3 SkyActiv).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-06-2012, 09:18 PM   #11
serialk11r
The US one has lower CR because US fuel quality has some issues or something.
It's hard to compare these tests but yea the 86 isn't doing as well in economy as it could be. Hard to say why. I'm curious what this scores on the EPA test because you'd think CAFE standards would prompt them to try to do better, if this only get say 31mpg (for CAFE calculation, I don't remember what that is exactly), then even with its small volume it poses a pretty big threat to the 39mpg small car requirement.
Old 02-06-2012, 09:43 PM   #12
Slide
Drives: Toyota Aristo
Because the higher modesl will also have a better air flow and under car air flow thing.
and 12.4km/l = 8.1l/km pretty decent.
Slide is offline   Reply With Quote
Old 02-06-2012, 09:56 PM   #13
Sasquachulator
Pavement Grey
Also note that the boxer configuration is inherently less fuel efficient than an inline configuration for some reason.
Old 02-06-2012, 09:57 PM   #14
serialk11r
I forgot about the lack of underbody panels on the RA. But all you really have to do is buy some corrugated foam board and tape it to the bottom...
No, boxer is not inherently less efficient. Subaru's EJ engines were just really old and inefficient by design. If anything, the better balance would make it more efficient due to slightly lower friction.
So what is the official weight? brillo Scion FR-S / Toyota 86 GT86 General Forum 76 05-03-2020 06:11 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 06:09 PM
How can i shave weight? fernan2 BRZ First-Gen (2012+) — General Topics 15 11-01-2011 11:31 AM
Another Rumor About Weight Enzie Scion FR-S / Toyota 86 GT86 General Forum 1 10-23-2011 03:00 AM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 11:43 PM
