Old 07-20-2013, 10:03 AM   #29
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Originally Posted by Tromatic View Post
So far, I do not have the chirp running e-free fuel.
Unrelated...
DylanFRS is offline   Reply With Quote
Old 07-20-2013, 10:18 AM   #30
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by WHITE View Post
My crickets died at 3500 miles, and returned around 3800 miles, i love my zombie crickets even more.
Zombie crickets...
sato is offline   Reply With Quote
Old 07-20-2013, 01:49 PM   #31
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by SkullWorks View Post
Hard to say.
If I was more familiar with the part number designation of the major manufacturers it would be easier I assume. It is VERY similar in foot print to one of the audi pumps I have done R&D on and that specific pump had several manufacturers and revisions....but this is different from each of those.
It is definitely something that FHI could make if they so desired, hyundai also makes alot of these as do Denso, Bosch, and others i assume aswell.
Funny you should mention the similarity to an Audi pump. When I first got the crickets I was worried there was an issue with the pump. But one day an Audi pulled up next to me at a stoplight and it sounded JUST like my car; crickets and typewriters. So I haven't worried about it since. If Audi thinks it's ok, and Audi OWNERS think it's ok, then there's no need to make a fuss about it. It's just a noise and it's only audible at idle. *shrug*
Great write-up btw. Thanks.
The Following User Says Thank You to Draco-REX For This Useful Post:
SkullWorks (09-17-2013)
Old 07-20-2013, 07:54 PM   #32
Tromatic
Originally Posted by DylanFRS View Post
Unrelated...
I think it is, but I'm not smarterer enough to figure out why. If they come back while running booze free gas, I will admit you are correct.
At this point, I think it may be related to water content. Just a WAG, as I say.
Old 07-20-2013, 11:45 PM   #33
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Sorry, I should have specified that I was being sarcastic... Since some people have decided that ethanol and the pump are completely unrelated and that everyone that has had the same experience you did should just mark that off as a coincidence.
Old 07-21-2013, 12:16 AM   #34
whataboutbob
AutoX-10/10ths every run
Thank you for taking the time to write this up!
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 07-23-2013, 07:30 PM   #35
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Originally Posted by Area86 View Post
Yes I have been on e85 since November with no crickets and I switched back to 91 last week and they were back instantly. I will be going back to e85 after this tank and will see if they go away again.
Sent from my DROID RAZR using Tapatalk 2
I switched back to e85 and the crickets are gone now.
Area86 is offline   Reply With Quote
Old 07-24-2013, 05:10 PM   #36
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Thanks @SkullWorks for taking the time to do a real analysis on the HPFP design.
It's a relief that it's strictly an NVH/perceived problem and not a real problem like the VW Diesel HPFP's.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
The Following User Says Thank You to Ryephile For This Useful Post:
Old 08-12-2013, 01:33 PM   #37
SkullWorks
Drives: SSM LT MT BRZ
Back to the top,
Too many "new" threads about crickets that are the same old bag of BS.
READ people, look around before you go on a rampage about a problem you didn't even try to understand.
The Following 2 Users Say Thank You to SkullWorks For This Useful Post:
HunterGreene (08-12-2013), Sportsguy83 (08-12-2013)
Old 08-12-2013, 03:06 PM   #38
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I lived in fear of the TDI pump issue for 3 years and 100k miles, mine never failed :-). I did have the icing intercooler problem though.
Scenic Driver is offline   Reply With Quote
Old 10-18-2013, 03:49 AM   #39
Anaxilus
Drives: They have four wheels
Lol, lowering our standards huh?
Anaxilus is offline   Reply With Quote
The Following User Says Thank You to Anaxilus For This Useful Post:
BRZ21 (10-18-2013)
Old 10-18-2013, 05:12 PM   #40
JSMIL
JSMIL's Avatar
Drives: FRS 10 series
Wait a minute! So you are saying the problem is not related to a family of crickets that have made there home in my engine bay? That is a relief and explains why the fumigation of my engine bay did not work. LOL, Just Kidding! Good work on the research. Now if you could only get on that CAD and design a fix for it. Then you could send it to Toyota and ask how their Army of engineers can design this amazing car, but not get the squeak out of the fuel pump after a year. Especially since you were able to diagnose the problem in your room on your home computer. LOL
JSMIL is offline   Reply With Quote
The Following User Says Thank You to JSMIL For This Useful Post:
sierra (10-18-2013)
Old 10-18-2013, 06:11 PM   #41
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Hunting down the cause of that chirp is not that simple, a redesign is very costly along with the required testing of the new unit. All we've got is one pump cut open and a hypothesis of tighter tolerances being the solution
If it had an impact on performance or durability it would have been fixed before the first unit left the factory.
ineedyourdiddly
Sportsguy83 (10-19-2013)
Old 10-19-2013, 10:48 AM   #42
im2lazy789
Drives: BRZ Limited DGM
I am curious if reducing the OD clearance of the washer from 3 mils down to 1.5 or 2 mils would help alleviate the crickets effectively reducing the angle at which the washer can "wedge". Alternatively, it could be possible that it requires more clearance given that the issue seems to be temperature related and the washer could be expanding taking up that little bit of clearance and running into wedging/stiction issues.
Would be nice to be able to have a pump that we can try different size and material washers with without having to grind out the weldment to disassemble.
im2lazy789 is offline   Reply With Quote
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 09:28 AM
Engine Internals from CP-Carrillo Now Available! Infamous Performance Engine, Exhaust, Bolt-Ons 108 02-13-2014 11:35 AM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 05:18 PM
stronger/forged internals Tyson Engine, Exhaust, Transmission 24 03-15-2013 04:38 AM
How about them internals nytfury Engine, Exhaust, Transmission 5 08-27-2012 07:23 AM
