| Software Tuning Discuss all software tuning topics. |
#29 |
Drives: 2013 GBS BRZ Limited
This is still somewhat related to the OP:
1 - When the ECU boots, I assume that it transfers the software image from Flash Memory to RAM, then begins executing from RAM - Yes? 2 - Once the ECU SW is running, the CAN bus monitor may request data by asking directly for memory addresses from RAM? I have a tactrix cable (waiting on definitions) and an ELM327 OBDII monitor. So when the OBDII monitor is requesting data, is the ECU actually just reporting memory contents? 3 - I read some of the "AccessTUNER_HelpFile_Subaru" manual from COBB tuning. The way it reads, it sounds like the manual is suggesting that you can make modifications to parameters in the MAPs (obviously in RAM, not flash) while the engine is running. Is that the case? If not it seems like having to reflash for every tiny adjustment would be a huge PITA (not to mention a risk to the ECU having to do it too often). Am I close? |
#30 | |
That's so far off base. Because they do a better job of controlling documentation than other companies doesn't mean they don't document every single bit of information about every single step of the manufacturing process. The most impressive part of working for them is the level at which you learn to document every single thing.....twice. Those guys are the kings of crossing your T's and dotting your I's. |
#31 | ||||
Drives: car
IF you have the right commercial tools, you can read the "real" CAN signals that are already going on the network. Probably the most common commerical tool is Vector CANalyzer. This includes things like vehicle yaw rates, steering angle, turn signal commands, and torque requests from various modules. It's all (or some portions) a bunch of hexidecimal nonsense unless you have access to the CAN .dbc file from the OEM. Quote:
With an Accessport (and a few other tools out there for various applications), Cobb has cleverly managed to use built-in RAM on the stock ECU so that some realtime changes are possible. So when you tune a WRX with AccessTuner, you get a small list of "realtime maps" which include primary fuel and spark, boost control, rev limiter, etc. This is a tiny portion of all the normal ROM values, but it's all you need for most tuning activities. These values will stay active as long as the battery isn't unplugged. You have to flash the changes to the stock ECU (just like a dealer tool would) to make the changes permanent. The final result is a much easier tuning process for most things in an affordable and usable package. Some things can be very very difficult or at least time consuming to tune in a vehicle when reflashing is the only method. MAF and injector scaling is a big one, and boost control. IMO, that alone is worth the money for going with Cobb over Opensource on a DIY tuning project if you have a WRX/STi. Quote:
Now, are some polished information about controls given to government regulators to satisfy certain questions of OBD and emissions? Of course. |
| The Following User Says Thank You to arghx7 For This Useful Post: | stugray (10-18-2013) |
#32 | |
The systems I work on give direct access to the running SW via a JTAG or serial "terminal" access. Either of those give access to the RAM and you can manipulate memory or registers directly. However there is an OS that gives terminal access. JTAG is in hardware so it works even without code support running on the ECU So I looked at the SH7058 manual and there IS a AUD (Advanced User Debug) port that allows direct read/write access to the system RAM while the code is running. I thought that might be how Accessport was manipulating system parameters while in operation. You just need the correct header file for the ROM and you would have access directly to MAP data, assuming any MAP data is stored in RAM during operation. Do the stock ROMs store any MAP data in RAM? If so the AUD port could be used to manipulate it (Assuming it is brought out to a header or test points) Last edited by stugray; 01-11-2014 at 02:50 PM. |
#33 |
Drives: car
#34 |
Drives: 2013 BRZ, WRB
at the idea that Japanese auto manufacturers and their vendors (e.g. Denso) are not documenting the shit out of their control system software."Unintended Acceleration", anyone? No, I'm not an industry insider and so of course, I'm speculating. But if *you* were running Toyota, would you be content with a "brain trust" and scanty docs? If you were a part of any .gov DOT, would *you* be content with this? |
#35 | |
Drives: car
As for the brain trust, it's part of Japanese business culture. Many Japanese companies are paranoid about corporate espionage, especially from companies in developing countries. |
#36 | |
Documentation for each of the ECUs processes most certainly exists. I've never heard of or even considered such a thing to be publicly available.
#37 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#38 | |
You could install the unichip, then tune (in realtime) the timing & MAF scaling. Then remove the unichip & incorporate those #s into the maps. Then continue the standard tuning with flashing. Seems it might save some time and a few flashes to the ECU. Would that be much of a benefit? |
#39 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
With Unichip, you will constantly be fighting against the ECU itself. It will notice that things aren't happening the way it was wanting and start to apply learning compensations.
#40 |
You Made Bro?
Drives: Raven 86
wow this thread was not inteded for fucking casuals like me haha ill just leave tuning to the pros
"Careful though, I've seen many of my friends turn from ironic bros to full on bros by accident." - cfusionpm
#41 |
Next question(s):
1 - Does this ECU use a RTOS? I saw this thread (http://www.ft86club.com/forums/showthread.php?t=50251) about the toyota acceleration issue and it mentions: OSEK http://www.edn.com/design/automotive...s-consequences OSEK Open Systems and their Interfaces for the Electronics in Motor Vehicles So does the BRZ use a RTOS? (real time {embedded} Operating System) That would completely change the way that the ECU code is reverse engineered. 2 - In this thread: http://www.ft86club.com/forums/showthread.php?t=47113 (Advance Mutiplier resetting on restart?) it seems that the ones that reverse engineer the code that makes this stuff go would be able to answer that question by just looking at the code. Why cant the code monkeys answer that question for them (I am not an IDA expert, so I am not volunteering). I just seems that if you have rev. engineered the code to determine what all the maps mean that you should be able to tell what the ECU does at boot. I am still wondering about the state diagram that just takes this engine from: ECU Off -> ECU On -> Engine start requested... Still learning |
#42 | |
Drives: car
Reverse engineering for tuning purposes is all about finding which "knobs to turn" to get close enough to a desired final results. Here's a perfect example: Cobb really doesn't know how ignition timing is calculated on the R35 GT-R. They found some maps though that if adjusted, will change the final ignition timing value in the intended direction. Knowledge of those three things: how the low-level hardware and software work so you can break into the ECU, what the maps generally affect, and what to change to get the desired final result are really all separate. You can know a little bit of each, or be an expert on one or two out of three. On the OEM level, there are entire teams often within separate companies for each of those functions. |
| WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** | RavSpec | Wheels and Tires | 18 | 12-10-2013 06:19 PM |
| 18x9.5 +38 Work Emotion CR kai Work Metal Buff | Jive Turkey | Wheels and Tires | 22 | 05-20-2013 02:54 AM |
| Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts | serial gixxer | Wheels and Tires | 41 | 03-29-2013 04:14 AM |
