Drives: 2012 FR-S and BR-Z
New Zeek Snorkel Systems from Japan
Available in FRP fiberglass or CF Carbon Fiber Options: Sound Tube Extra Here is a new product Zeek that we are carrying from Japan. Air duct for FR-S / BRZ routes fresh, cold air to the stock intake box by collecting air from the grill of the front bumper and directing it over the radiator and into the intake box. This prevents the intake from ingesting hot engine bay air and ensures the engine operates at peak efficiency with the best intake air temperature possible. ![]() There are many design considerations when developing an air intake system for street and race applications. The process is complex when peak HP numbers are not the only goal; a properly designed system will maximize torque and power throughout the RPM range. Consideration should be given to system volume, air inlet temperature, filter construction, sound and wave characteristics, system weight, and final fitment. Zeeks High Performance Intake Systems incorporate all critical design criteria and as a result they fit perfectly, provide maximum torque and horsepower across the entire RPM range, and allow the driver to experience the engine note without being overpowered by extremely high sound levels. ![]() ![]() (DYNO SPECS)
| The Following User Says Thank You to Evasive Motorsports For This Useful Post: | BRZ68 (10-17-2013) |
#2 |
Old Fart
Price?
#3 |
| The Following User Says Thank You to Evasive Motorsports For This Useful Post: | bear89103 (10-17-2013) |
#4 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Would these be compatible with the AFE Takeda Type 2 intake that requires the removal of the stock snorkel?
| The Following User Says Thank You to Wise For This Useful Post: | NoFear99 (10-20-2013) |
#5 |
Drives: Unicorn
Is there an option with a snorkel delete?
| The Following User Says Thank You to JETRED For This Useful Post: | Evasive Motorsports (10-22-2013) |
#6 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Sound tube thinggy?
Really? meh
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Evasive Motorsports (10-22-2013) |
#7 |
Drives: Asphalt Scion Frs 6MT
interesting
| The Following User Says Thank You to DarkCard For This Useful Post: | Evasive Motorsports (10-22-2013) |
#8 |
Drives: 2013 FRS
Curious if this would benefit us vortech guys. Wonder if this would enhance the flow without getting in the way of the intercooler as much. Opinions ??
#9 |
Man-ape
Drives: 2013 Buddy Club Scion FR-S
Evasive I want this like this week! Are they in stock? I'm in SoCal! Pm me please
#10 |
Requires removal of the bumper foam???
#11 |
Drives: bucket
couldn't find any info about the option to eliminate the sound generator? i feel the carbon intake tube would keep cooler than an aluminum one but i don't need the sound generator to stick around. any info?
| The Following User Says Thank You to humanshield For This Useful Post: | Muaddib (08-04-2014) |
#12 |
Man-ape
Well the foam is a shock absorber and helps the from fascia hold shape from flex under high speed I'm sure but I'm sure you can fabricate around it? It's just foam.
#13 |
Drives: DGM BRZ
The sound generator tube delete should be an option available. I know this because Sunline Racing has this as an option for their intake snorkel and it's the exact same thing. FRP or CFRP versions. Whether Zeek makes these products for them I'm not sure. Not sure if @EvasiveMotorsports has them on option for order without it?
| The Following 2 Users Say Thank You to brz_star21 For This Useful Post: | humanshield (10-21-2013), Muaddib (08-04-2014) |
#14 | |
Drives: bucket
| Zeek - CF intake tube and snorkle | *KID* | Engine, Exhaust, Transmission | 11 | 10-17-2013 10:56 PM |
| Best alarm systems? | normanb21 | Electronics | Audio | NAV | Infotainment | 4 | 05-24-2013 02:19 PM |
| Exhaust Systems | hunter3232792 | Engine, Exhaust, Transmission | 23 | 12-10-2012 06:14 PM |
| WTB: OEM snorkle (not sound generator) | Laika | Engine, Exhaust, Bolt-Ons | 2 | 11-08-2012 11:31 AM |
