| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Turning is for Nerds
Drives: 35 characters is not enough
Toyota filled my coolant overflow with washer fluid
I just got my 7500 mile free service, and once done I noticed that my coolant overflow tank was way overfilled (like when warm it was within 1/2 cm of the cap). I check my fluids every week, so I was very aware that my coolant level was exactly at the "MAX" line when hot and 2" below that when cold, before servicing. So, pissed off, I looked at the service record and saw that the washer fluid had been filled, but there was no mention of the coolant being touched. I had a bottle of Toyota's spec FR-S coolant at home so once I got back to my garage I compared it to the stuff in my reservoir.
Turns out that on Toyota's the washer fluid reservoir is located where our coolant reservoir is. Also Toyota coolant is red, whereas ours is blue. So some jackass tech noticed that my "washer fluid" was low and topped it off, without looking at the obvious fucking label on the cap. I took it back and had them drain the reservoir, fill it with new coolant, drain it again, and then refill with the proper amount of the proper fluid. I'm just glad I noticed it quickly and the few hours it was in my overflow tank was not enough to contaminate the coolant in the system. **edit I went back and insisted they do a full coolant flush and refill** Anyway, be careful guys. ALWAYS check that work had been done on your car properly. I for one, will be doing all of my own work going forward. Last edited by Decay107; 10-17-2013 at 09:11 PM. |
| The Following 5 Users Say Thank You to Decay107 For This Useful Post: | Corner3garage (10-18-2013), Mr. (10-17-2013), tech4pdx (10-17-2013), Tristor (09-16-2018), xia (10-18-2013) |
#2 |
Holy crap, are you serious? I'd absolutely flip out if that would have happened to me. They didn't do anything other than just fix it? I would be demanding a lot more than just fixing the problem.
#3 |
Bang Bang
Drives: 2013 Raven FR-S
Thats crazy...but also doesn't really surprise me. I too would be demanding something other than just fixing the problem
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers |
#4 |
Boosted
Drives: Not a supra....yet
you take the time to weekly check on your fluids but let people who dont give a darn about your car work on it ?
#5 |
I'm back now, getting the system flushed for peace of mind. What kind of stuff would you expect to receive, more free service? Well fuck that.
#6 |
#7 |
Bang Bang
In store credit to be used on parts. I had an issue at a dodge dealer and they sent me a 500.00 prepaid visa card.
Sent from my HTCONE using Tapatalk
| The Following 3 Users Say Thank You to trigger happy For This Useful Post: |
#8 |
Sarcastic SOB
I would have insisted they tow it back in or perform the flush and refill where the car is. Or they will hear from my lawyer. I'd demand compensation now or you can contact the local newspaper consumer advocate.
I'm shocked the car didn't overheat.
#9 |
Just in the overflow, not the whole system. Coolant temp did not go beyond 94C. I log oil and coolant temps whenever I drive.
#10 |
Thats pretty neat
Drives: LOADING......
My coolant expands from halfway between full and low, to right on the full mark when just driving 30miles to work on a highway cruising 75mph in 40 degree f weather.
What im saying is, if i put anything but coolant in my overflow it would contaminate my entire system just going 30miles down the highway. Also theres a reason my car has never seen the dealer since i drve it off the lot, dont care about any free maintenance crap they offer, trust nobody but myself. |
#11 |
Make love
Drives: H8R.. Not really
Which dealer? I'm in Portland too. I never take my car to dealers.. just wondering.
#12 |
Kurenai Samurai
Drives: Red and manual
aw dude that sucks i bet the tech felt pretty bad...i know i would. i hope the car is ok now though.
#13 |
#14 |
Volunteer Fire and Rescue
Drives: Ambulance... sideways.
That tech must seriously feel bad. I mean, he thought he was doing the right thing, being proactive and helping an owner out by refilling it. Its just unfortunate he mistook the coolant reservoir. Sounds like they did everything they could to make you feel right about it.
Does anyone know EXACTLY what happens when antifreeze mixes with washer fluid? Ill give you a hint... nothing. The alcohol will evaporate leaving additional water in the coolant. All that does is ever so slightly increase the temperature that the mix will freeze at. does not decrease the effectiveness of the coolant unless youre somewhere VERY cold.
It's more fun to drive a slow car fast, than a fast car slow.
| The Following 2 Users Say Thank You to Grishbok For This Useful Post: | JoeC (08-11-2016), Sportsguy83 (10-23-2013) |
| Washer Mod? | 636 | Engine, Exhaust, Transmission | 64 | 02-20-2018 04:08 PM |
| Dealer filled my new FRS with 87 octane; Should I flash ECU? | Hakuzen | Issues | Warranty | Recalls / TSB | 37 | 01-09-2014 05:52 PM |
| Washer Fluid Indicator | Tdot | BRZ First-Gen (2012+) — General Topics | 58 | 02-19-2013 04:02 PM |
| Deos this car not warn you when you are low on washer fluid? | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 02-07-2013 12:00 AM |
| FYI - Washer Fluid light | Ben_G | BRZ First-Gen (2012+) — General Topics | 48 | 01-03-2013 04:18 PM |
