Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 10-16-2013, 08:29 AM   #1625
musclecars
Drives: Subaru BRZ
Sorry correction @Wilcats
Sent from my iPad using Tapatalk HD
musclecars is offline   Reply With Quote
Old 10-16-2013, 08:43 PM   #1626
dhoeze
Drives: Toyota 86
Wilcats, kelan mo ipapacheck... same here sakin.. front driver side... or need ba kung saan ko binili?
dhoeze is offline   Reply With Quote
Old 10-16-2013, 09:23 PM   #1627
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
@RK, yes sir, same handle in HCP mukhang marami-rami tayo galing HCP.. @Wilcats, @x3m_priv8.. sino pa ba? GT na to kasama si Totenkopf ng HCP din
@Wilcats, balitaan mo na lang ako kung ano cause hehe nakakabit na ren lowering springs ko so baka mamaya, if something is wrong, di ren nila i-cover under warranty mukhang problem siya for the 86?
pcuerpo is offline   Reply With Quote
Old 10-17-2013, 04:36 AM   #1628
RK
Drives: Subaru BRZ
@pcuerpo
BlueBurnsOrange of HCP here siir!
RK is offline   Reply With Quote
Old 10-17-2013, 04:41 AM   #1629
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Originally Posted by RK View Post
@pcuerpo
uyyyy.. ikaw pala yan! diba Mandaluyong area ka lang din, tama ba? nice at naka BRZ ka na din pala btw, may pinaplano si Totenkopf na GT kaso sa south, sana makapunta mga HCP peeps
Old 10-17-2013, 06:26 AM   #1630
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
question, what chins and side skirts are available locally? im not looking for original ones, copies with good fitment would do any suggestions? TRD is out of the question since im going with Tom's for my accessories
Old 10-17-2013, 09:56 AM   #1631
RK
Drives: Subaru BRZ
Newport area lang ako pards 1 week old BRZ pa lang hehe
Old 10-17-2013, 11:18 AM   #1632
Wilcats
Drives: Toyota 86
Had it checked na kanina. Lahat naman ng bolts mahigpit. Ang sabi naman sakin, it is the metal engine cover that is making the rattle. There's a little play kasi dun sa clips that hold the plate in place. Di naman daw pwede malagyan ng rubber washers, di rin papasok un clips. Oh well guess we'll have to live with it. Another client had it removed and it was gone. downside lang, wala ng protection from dirt / water un engine sa ilalim.
Eight - Six
Wilcats is offline   Reply With Quote
Old 10-17-2013, 01:21 PM   #1633
trustyler
Drives: Toyota 86
Hi guys! Does anybody know who sells Swift lowering springs for the Toyota 86 here in the Philippines?
trustyler is offline   Reply With Quote
Old 10-17-2013, 01:24 PM   #1634
NIKDENG
Drives: RED BRZ
Originally Posted by x3m_priv8 View Post
Guys pansin ko lang mahina buga ng aircon ko compare sa fortuner namin. Parang lalamig then mawawala kahit nasa 22'C settings. Ibalik ko na ba agad sa casa para macheck or maghintay pa ako ng 1,000km PMS para maisabay na?
@x3m_priv8,
Your aircon is normal. The FRS/BRZ climate control settings are on the higher side (+2 to +3degC)compared to most other cars so a 19 setting on the FRS/BRZ is equivalent to a 21-22 setting on other cars. Checked this out by using a temperature gun on my BRZ in comparison with my other cars. The FRS/BRZ compressor also turns off automatically on WOT and when the engine rpm exceeds 6k rpm which adds to the feeling that the cooling system is inadequate.
Originally Posted by musclecars View Post
I received my subaru genuine dimming mirror from us the other day with installation instruction. According to the manual there is a pre installed socket inside the dome light but when I removed the dome light I can't find one 😩 so I wasn't able to install yesterday 😭 I guess I have to bring to MI for installation ...
@musclecars,
You might want to take another look using a flashlight and small mirror. The socket is usually tied to the power cable of the dome light and is pretty tucked inside the dome light cavity that is why you can't see it.
Originally Posted by Wilcats View Post
Hi guys. I have this issue with the suspension. I hear this clunking/rattling noise when I go over small ruts & humps at about 10-20kph. None when I speed up. Anyone here experienced this?
My 86 is just a week old. I already heard/felt this since day 1. Is this a suspension thing or they just forgot to tighten some under chassis parts?
@Wilcats,
If your suspension is fully stock and the noise is coming from the front then it is most likely caused by incorrectly torqued bolts on the bottom engine cover. It is not enough to just tighten them, they have to be torqued to the correct specs. For your reference on the bolts and corresponding torque settings:
If the noise is coming from the rear, this is most likely caused by your rear deck rattling. This can be remedied by bending the tab shown below so that it joins the two rear deck panels together instead of hitting each other.
NIKDENG is offline   Reply With Quote
The Following 3 Users Say Thank You to NIKDENG For This Useful Post:
jdmasfcuk (10-23-2013), melon (10-19-2013), pcuerpo (10-17-2013)
Old 10-17-2013, 02:01 PM   #1635
1RonM3n
1RonM3n's Avatar
Drives: 2013 FRS Hot Lava / 2011 M3 E92
share ko lang po some pix here sa NJ, kahit na po d sa pinas ang location
kahit saling pusa lang.
My family is from Manila , Jose Abad Santos malapit sa blumentritt.
kung kailangan nyo po ng gulong at rims, punta po kayo sa Tomas Mapua... Carport/Gladdies Tire, Mags and Service Shop (Facebook)
uncle ko po ang owner. Jojo po name ng may ari. Tell him pinadala kayo ni John (anak ni TYREX)
yun FRS binili ko po para sa anak ko, stock muna...five axis spoiler / beat sonic sharks fin
smoked fender lights and smoked front turn lights for now
d pa namin nilalagay yung iba pang mga mods kasi magwiwinter na dito.
yung red M3 ang DD ko. nakawinter mode sya ngayon, pero
pag summer IRONMAN theme ang set up ko.
kasama ko sa trabaho ang anak ko so we always park on the same spot.....malayo sa gasgas....
eto po ilang pix.
1RonM3n is offline   Reply With Quote
Old 10-17-2013, 10:21 PM   #1636
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
@Wilcats, balitaan moko dun sa post ni @NIKDENG tapos kung yun nga ang issue, pasok ko yung 86
@1RonM3n, nice M3
@RK, sarap i-road trip niyan meron fun run daw bukas, sama ka? meet-up sa Petron SLEX ng 6am tapos Tagaytay ang destination pero sa Talisay galing
anybody else going here sa fun run? hope to meet some of you
Old 10-17-2013, 10:25 PM   #1637
musclecars
Drives: Subaru BRZ
I will be there tomorrow fun run
Old 10-18-2013, 01:23 AM   #1638
RK
Drives: Subaru BRZ
@pcuerpo
Negative bro i have work tomorrow attend ako sa mga gt pag pwede hehe
Sent from my iPhone using Tapatalk - now Free
