Old 10-12-2013, 04:51 PM   #1947
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Area86 View Post
Question for you guys. What is the best vacuum source to "T" off of for my boost gauge? On the automatics we do not use the brake booster line on the rear of the supercharger so I was thinking of connecting it directly to there without tapping into anything. I read that you can tap into the brake booster line too as long as it's before the check valve. Is this correct and would that be a good source?? Suggestions?? Thanks in advance.
None of the "stock" ports on the kit are post blower thus boost cannot be read from them.
You can tap the MAP plate maybe? I think Nameless's plate has this standard.
Old 10-14-2013, 10:56 AM   #1948
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Thank you. I have the IAT kit from FA20club so I'll have to take a look and see if I can squeeze it on there.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
Old 10-16-2013, 10:47 AM   #1949
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I ran into a problem that I believe someone else ran into but I can't find the post. The grey nipple that goes to the EVAP Solenoid came loose allowing it to spin. Is this threaded directly into the intake tube or is there backing nut on the inside? Is there an easy fix for this? It can only rotate 180 because of clearance. Does anyone know if there is a gasket between the intake tube and the charger that I will mess up if I take it apart?
calispec is offline   Reply With Quote
Old 10-16-2013, 10:49 AM   #1950
xjohnx
Grip>Slip
xjohnx's Avatar
paging @mines13
Old 10-16-2013, 11:54 AM   #1951
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by xjohnx View Post
paging @mines13
Greetings John, this fitting is threaded directly in to the inlet tube with no lock nut. It is okay to disassemble the elbow and re thread with new thread sealer if deemed necessary. On a side note, there is some big things getting extremely close fruition.
mines13 is offline   Reply With Quote
The Following 3 Users Say Thank You to mines13 For This Useful Post:
akuhei (10-16-2013), calispec (10-16-2013), TemeCal (10-16-2013)
Old 10-16-2013, 12:12 PM   #1952
Ross
Drives: 85 corolla gts
Mines13 are you referring to the upgraded blower and intercooler kit?
Ross is offline   Reply With Quote
Old 10-16-2013, 12:12 PM   #1953
xxscaxx
Drives: 2013 SWP BRZ
Mine also moves around, I pushed it to tighten it, but I thought this wasn't a big deal?
Anything you can tease us with @mines13?
PS - 70mm pulley is amazing.
xxscaxx is offline   Reply With Quote
Old 10-16-2013, 01:00 PM   #1954
xjohnx
Grip>Slip
xjohnx's Avatar
there's your answer, @calispec.
as for the big things, can't wait! intercooler here i come.
Old 10-16-2013, 01:32 PM   #1955
Rev Works
Rev Works's Avatar
Drives: 2013 STi
I guess this is a nice place to leave this lol.
We have installed a few of these kits now and love the outcome. Also the fact that the car can come in and leave with a ton of extra power, in the same day makes this kit amazing!
-Matt
Rev Works is offline   Reply With Quote
The Following User Says Thank You to Rev Works For This Useful Post:
mines13 (10-18-2013)
Old 10-16-2013, 02:01 PM   #1956
vgi
Drives: frs
sadly I doubt it'll be the upgraded blower, i think the intercooler release and/or CARB approval?
vgi is offline   Reply With Quote
Old 10-16-2013, 06:54 PM   #1957
xxscaxx
Looking at RevWorks photos, I think I put the couplers for the piping on backwords Don't think it really matters, but whatever. Not sure how I ever looked past that.
Old 10-16-2013, 07:09 PM   #1958
xjohnx
Grip>Slip
xjohnx's Avatar
Just checked, mine are backwards too. Guess I'm gonna go fix that in a minute.
Old 10-16-2013, 07:50 PM   #1959
xxscaxx
If you think about it, it makes sense for the flex one to be up top, but they are both 3" at the end of the day lol. I am surprised I didn't flop them around because with the flex one near the air box it lets the piping move a bit and its real close to the oil stick. Wonder if swapping them will fix this.
Oh well, no harm no foul
Old 10-17-2013, 12:47 PM   #1960
mines13
mines13's Avatar
Not really, I can only say that good things come to those who wait... And you won't have to wait very long. And yes, 70mm pulley does feel pretty beast provided you have the fuel, etc. I am still on a 75 myself.
calispec (10-17-2013), CSG Mike (10-17-2013), sw20kosh (10-17-2013)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
