Old 10-15-2013, 11:45 AM   #239
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by AVOturboworld View Post
It's the same price as the 8psi actuators, actually. I'll talk to the factory and see if they can get me some asap.
Only issue is going to be the length of the arm, and mounting it up to the bracket. Not major issues, just something to look out for.
Thanks. Let me know what the factory tells you on ETA for that 12 psi actuator.
Old 10-15-2013, 12:30 PM   #240
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Paul....Your gonna hate me...After all that harassing to get me the 8psi, didnt realize you guys have 12psi ones available. Can you PM me price and availability of these as well...
Thanks!
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Sportsguy83 (10-15-2013)
Old 10-15-2013, 12:58 PM   #241
tiny41
Originally Posted by DAMotorsports View Post
You se the stock under tray. It you re having a hard time getting it lined you then loosen the impact beam and pull up on it as you tighten it up. Secondly make sure you have the IC up all the way. All the stock parts fit back in place. The side air panels (behind the grill) need a touch of a trim to fit. YOU NEED ALL OF THOSE PARTS TO KEEP YOUR CAR COOL, in both FI and NA.
Let me know if you need more help
I didn't install the side trims that needed trimming because it got in the way of my oil cooler. I will keep an eye out on my temps now to make sure its properly cooling...
The bottom try should fit though...Mines barely has a gap from the bottom of the intercooler and it was damaged from shipping!
tiny41 is offline   Reply With Quote
Old 10-15-2013, 01:04 PM   #242
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Nearly done with my install. Just got the basemap programmed, and got the car started to check for leaks:
https://www.dropbox.com/s/2gjzn1gantfvmqm/VIDEO0020.mp4
FrX is offline   Reply With Quote
The Following 3 Users Say Thank You to FrX For This Useful Post:
AVOturboworld (10-15-2013), DAMotorsports (10-15-2013), gdrider77 (10-15-2013)
Old 10-15-2013, 02:58 PM   #243
DAMotorsports
Drives: 2013 Scion FRS "Raven"
It is a snug fit once everything is back in place
DAMotorsports is offline   Reply With Quote
Old 10-16-2013, 12:56 AM   #244
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Having tip-in issues lately among other things. Updated my build thread here:
http://www.ft86club.com/forums/showt...24#post1273024
Looking for any input from previous cars or this platform. I'm hoping it's something simple like bad tune because of exhaust leak or something. I don't blame anyone in particular even if it sounds like it. Each vendor I've worked with has been forthcoming and helpful with all the problems I've had so far.
Hope to have answers soon and have everything sorted out, I'll keep updating.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 10-16-2013, 01:58 AM   #245
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Did you have the headers checked for leak(s) like Sportsguy83?
andrewFT86 is offline   Reply With Quote
Old 10-16-2013, 02:20 AM   #246
nataku
Negative Mass
nataku's Avatar
I've had a leak at the header flanges pretty much the whole time I've had the kit. It used to go away when everything warmed up but it has since gotten much worse. Grimmspeed gaskets on the way, should see soon if they fix it. I'm hoping I won't have to RMA for new headers.
Old 10-16-2013, 02:55 AM   #247
FrX
I used the Grimmspeed gaskets on my install. I've only run the car for maybe 10 minutes after getting it together so far, but there don't seem to be any leaks.
Side note: PLM overpipe + Perrin motor mounts fit perfectly for me. There does not seem to be any clearance issues.
Old 10-16-2013, 03:27 AM   #248
andrewFT86
andrewFT86's Avatar
I hope it is just that. I ordered the gasket set because of what I read on this thread. Good luck
Old 10-16-2013, 03:31 AM   #249
ft_sjo
Drives: GT86
Thicker gaskets (of the same material and design) are less likely to seal a leak as they're less flexible.
Old 10-16-2013, 04:36 AM   #250
andrewFT86
andrewFT86's Avatar
The reason: AVO gaskets are better flanged than OEM gaskets.
The Following User Says Thank You to andrewFT86 For This Useful Post:
DAMotorsports (10-16-2013)
Old 10-16-2013, 08:40 AM   #251
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
AVO Turbo Kit Owners Topic
I took @Sportsguy83 advice when it came to gaskets and got some OEM Forester gaskets. No exhaust leak from the header flange once it was all torqued down.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following 3 Users Say Thank You to ecko04 For This Useful Post:
CxG (08-03-2015), DAMotorsports (10-16-2013), Sportsguy83 (10-16-2013)
Old 10-16-2013, 02:34 PM   #252
FrX
Almost completely done with the turbo install. Only a few minor things left to wrap up. Just took it for its first test drive. In the rain. First and second gear are useless with the stock tires.
I had the same issue with the bumper nearly not having enough room. Even with everything pushed up to the highest adjustments, it is a tight fit. It may have been advantageous to make the intercooler just on row shorter for ease of assembly.
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
