Old 10-14-2013, 10:45 AM   #29
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
These motors like to rev. As long as you aren't doing repeated clutch dumps and missing gears, you shouldn't have to worry about breaking too much. I tend to be nice to mine, but I'm not afraid to rev it out to 7k+ when I'm having fun with it.
FReSh is offline   Reply With Quote
Old 10-14-2013, 10:57 AM   #30
Porsche
Drives: 2013 BRZ Ltd. MT
Originally Posted by whaap View Post
No, you're right. I guess all I'm trying to say is the harder you beat on something the more likely you are to have problems.
And of course, you're right.
Knowing this, I'm always reluctant to consider purchasing a used performance car. And right now, I'm reluctant to take my BRZ over 6000 rpm, because of the DI issues.
Porsche is offline   Reply With Quote
The Following User Says Thank You to Porsche For This Useful Post:
whaap (10-14-2013)
Old 10-14-2013, 11:14 AM   #31
Luis_GT
You should have gone scion... at least they don't void the warranty just because they feel like it.
Old 10-14-2013, 05:21 PM   #32
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by JonnyJames View Post
My question is, what kind and level of abuse can this car handle on a regular basis without sacrificing reliability or messing something up?
The limit is the driver.
A good driver will know what the limits of the car are, and drive to the best of his/her ability (which may or may not hit the car's limits).
An average driver will hit the limits of the car, but often exceeding his/her own driving abilities.
The two are not the same, and no amount of armchair advice given online can help you on this.
-alex
humfrz (10-14-2013)
Old 10-14-2013, 05:27 PM   #33
amram
amram's Avatar
Drives: 2013 FR-S AT
Key point: Make certain your engine oil is up to operating temperature. Not the coolant temp, the OIL TEMP. By then the rest of the drivetrain will be at operating temperatures, too. And you're good to go.
Noob question - what's the best way to do that (on the stock car that is)?
"That's why I like the GT86 so much..... It's a car designed for one thing only: fun." - Jeremy Clarkson
amram is offline   Reply With Quote
Old 10-14-2013, 06:07 PM   #34
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showthread.php?t=48264
Specifically:
http://www.ft86club.com/forums/showp...0&postcount=82
ineedyourdiddly
amram (11-05-2013)
Old 10-14-2013, 06:20 PM   #35
Muskokan
Drives: white Sport-tech
Lmao did you just compare out 2L engines with the reliability of NASCAR engines lmao, please just be trolling if your ever gunna reproduce.
An engine for a NASCAR Sprint Cup car costs between $45,000.00 and $80,000.00. It's not uncommon to see engine failures in races that are 500 miles or less. When you consider the cost of our engines that should give you an idea of what it's limits are. The better you take care of your equipment the longer it will last you.
Muskokan is offline   Reply With Quote
Old 10-14-2013, 07:26 PM   #36
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Please read post #28. I tried to explain myself a little better.
whaap is offline   Reply With Quote
The Following User Says Thank You to whaap For This Useful Post:
Muskokan (10-14-2013)
Old 10-14-2013, 07:39 PM   #37
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Just saw this today. Granted it's not our engine or transmission, but still.
EKANOORACING GT86 LAID DOWN 1083 RWHP & 786 POUND OF TORQUE , MAKING IT THE WORLD MOST POWERFUL FT86 , USING 2JZ STOCK BLOCK , EKANOORACING RACING HEADS , SUPRA 6 SPEED TRANS , HYPER TUNE INTAKE , PRECISION TURBO , AEM ECU TUNED BY HUSAM TAYIB.
THIS IS A STREET CAR IT HAS NAV, STOCK STEREO WITH A.C. , ABS , TRACTION CONTROL , 18 INCH WHEELS , , EVERYTHING WORKS LIKE HOW IT CAME OUT FROM THE FACTORY
[ame]http://youtu.be/JL3Kphce1j8[/ame]
mwjcyber is offline   Reply With Quote
Old 10-14-2013, 07:52 PM   #38
Hi amram .....
My short answer is .... to drive it for about 3 miles ..... then the oil should be all warmed up....
amram (11-05-2013)
Old 10-14-2013, 08:04 PM   #39
DANG, Muskokan, I'd suggest you consider easing off of my old buddy .... old whaap .......
TIA
humfrz - old too .....
Braces (10-15-2013), Porsche (10-15-2013)
Old 10-14-2013, 08:11 PM   #40
EKANOORACING GT86 LAID DOWN 1083 RWHP & 786 POUND OF TORQUE ,...........
That thing shouldn't be allowed out in public !! .....
Old 10-14-2013, 08:16 PM   #41
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Every time I have taken this car out, it has seen 5k+ RPMs. The rear tires have seen more high angle/high speed drifts than any car I have owned before. I once did a standing burnout for 40 seconds (this is all on a closed track, of course) and the tires didn't even lose a 32nd of tread.
I beat the hell out of this car, but I meticulously care for it's engine and transmission. Fluids are changed on time and never cheaped out on. As long as you perform proper maintenance and don't do anything idiotic, you can have your way with this car and it will still greet you with its goofy, fanged smile every time you start it up.
- The Ancient BRZ Sacrament
by Zaku
Old 10-15-2013, 03:19 AM   #42
Porsche
Lacking an oil temperature gauge, I use a small kitchen timer set to 10 minutes. I've usually driven 5-6 miles in that time.
I use only part throttle and 3000 rpm max, and especially avoid lugging up hills at low rpm. I'll do 3000 rpm up a hill rather than 2000 rpm when cold.
After 10 minutes, I progressively use more throttle and raise the rpms.
"But I'm only 2 miles from work! I'll never be able to push it hard!" some complain.
It's a problem, I know.
When it's time to buy a used BRZ, ours is the one you want.
amram (11-05-2013)
Engine Rev Limit liluxiaorealnew Engine, Exhaust, Transmission 35 07-29-2013 12:07 PM
No Limit Motorsport LeeMaster User/Vendor/Sponsor Reviews, Feedback, Comments 6 05-17-2013 12:16 AM
Rev Limit Acid18 Scion FR-S / Toyota 86 GT86 General Forum 36 01-13-2013 04:55 PM
Pushing a tank of gas to the limit. RoryTate CANADA 36 09-09-2012 10:22 PM
Dealer Limit blackfireball5 Scion FR-S / Toyota 86 GT86 General Forum 12 06-29-2012 09:25 PM
