#211 |
Drives: GT86
#212 |
Drives: 2013 Scion FRS "Raven"
See as the possible metal debris would have the pass through the intercooler before it gets to the motor you might be ok. You can start by looking there and then pull the intake and scope the cylinder.
#213 |
Drives: 2013 wrb brz
#214 |
I did find a chunk sitting right in the entrance of the throttle body.We are scoping the cylinders Tuesday and flushing everything. Will do a couple oil changes in a row with a large magnet on the oil pan...let the car idle for a min for each change ...rebuild the turbo and if the motor is ok I'll be back in business next week.
#215 |
Drives: GT86
#216 |
That Guy
Drives: 2013 asphalt FRS MT
I had this happen on a Volvo Penta at work. The intercooler caught everything. I replaced the turbo and intercooler and the engine ran like a champ. Just thought I'd offer a little hope. Good luck.
| The Following User Says Thank You to Calum For This Useful Post: | Sportsguy83 (10-21-2013) |
#217 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Finishing up my turbo install today. Running into a little difficulty getting the intercooler lines fitted. Especially around the driver's headlight area. The hard pipe that fits there seems to want to point the hoses right into the headlight. When bolted to the intake mount, the clearance with the water pump pulley is very tight. Is there a trick to this?
#218 | |
#219 |
#220 |
That Guy
I'm in the navy, I didn't even try. We were in the gulf at the time, using that boat to board suspicious vessels. We didn't have time to **** around, it was a get it done right and now situation. As it was we had to locate the closest parts, convince the store to make a special trip to a courier, have the courier same day ship it to a near by city, and have a barge bring it out to us. All told it took a little less then a day and a little over $15,000 USD. The only reason we went that route is because we couldn't locate an assembled engine close enough, otherwise I would have been pulling the engine in god damn 60 deg C heat. I lost two holes on my belt worth of weight in the time it took me to replace those two parts, and that was with my boss doing nothing but running back and forth bringing me water.
#221 | |
WTF....lol |
#222 |
The front of your turbo compressor blades were all chewed up, there's a very high chance it ate a nut or bolt from somewhere. When the bearings let go, the front outer edge of the blades start hitting and either bend or break off small chunks at the upper outer edge only.
#223 | |
About an inch of shaft play to
| The Following User Says Thank You to brz2013 For This Useful Post: | Sportsguy83 (10-13-2013) |
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
