Old 10-10-2013, 04:09 PM   #1
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Reuseable TPMS valve kit
Are they reuseable? Also, are they universal? I'm getting the valve kit to be installed with tpms sensor. Got a new set of wheels last night.
Thanks
Are these correct way to install them? America Tire want to charge me $5 for the installation. Please help me out. Thanks.
hanabie is offline   Reply With Quote
Old 10-11-2013, 12:54 PM   #2
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
i got the tpms from tirerack and have since moved them to different rims. These were movable no problem without a rebuild kit. they just unscrew and screw back together
abutterman is offline   Reply With Quote
The Following User Says Thank You to abutterman For This Useful Post:
hanabie (10-12-2013)
Old 10-12-2013, 02:59 PM   #3
hanabie
hanabie's Avatar
The sale tried to rip me off $7 each. He told me they were not reuseable. I'm pretty sure they are.
Old 10-12-2013, 03:59 PM   #4
Willsonk
Drives: Scion FR-S Asphalt AT & XB
It's called TPMS service pack. They cost around $3 each. Reason why you should change them to keep the tpms sealed. Its better to change then risk the air seeping out and causing damage to the tire because of low pressure. If you don't you can reuse but there is a chance something might go wrong. Yes that the correct way to install them in the pic's you have ..... need to torque them at 36 inch pounds not ft pounds ......... if you don't they are going to seep. Good Luck
Part # if you need it is: Dill 1100
Willsonk is offline   Reply With Quote
The Following User Says Thank You to Willsonk For This Useful Post:
Old 10-12-2013, 04:27 PM   #5
hanabie
hanabie's Avatar
this post really helps me out!
Old 10-12-2013, 05:56 PM   #6
wlwarfield
VTECLOL
wlwarfield's Avatar
Drives: 2011 STi & 2013 F150 SVT Raptor
^this. It's worth the extra security to just replace the service pack any time a tire is removed for service. Over time the rubber grommets can become torn, lose, or dry-rotted (in warm dry climates).
follow me on Instagram @wlwarfield
OFFICIAL Texas BRZ, FRS, GT86 Facebook Page
OFFICIAL NM86CLUB Facebook Page
2011 Subaru Impreza WRX STi sedan
2013 Ford F-150 SVT Raptor
wlwarfield is offline   Reply With Quote
Old 10-12-2013, 08:04 PM   #7
hanabie
hanabie's Avatar
My tires were only 1500. Removed the tpms for after market wheels
Sent from my SGH-T999 using Tapatalk now Free
Old 10-12-2013, 09:21 PM   #8
hanabie
hanabie's Avatar
America Tire wants $7 each and $5 labor to install. I told the guy that Id do that by myself. It is BS. If I know $3each, Id do that instead.
Old 10-12-2013, 09:26 PM   #9
hanabie
hanabie's Avatar
The only part might not be reuseable was the rubber grommets. I have read that from forums and honda also advised not to reuse compressed grommets.
PCV valve leaking? jamesm Forced Induction 24 12-25-2014 06:38 PM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 01:51 PM
Cheap Alloy non-TPMS tire valve found bpracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-08-2012 09:28 AM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
