| CANADA Canada |
Drives: Sliver FRS done the way I like it
Tire Pressure
What pressure you guys run ur street tires and track tires at ? .
#2 | |
Drives: 996 C4S
Track Pressure really depends on your Tire, Condition, Alignment Spec, Driving Style and Track .With Toyo R888's on my Porsche around Mosport the sweet spot is 32-34 PSI heat dependent. If Michilen PS Cups like 30ish. however Pirelli Trofeo's require more camber and lower pressure around 29psi and Trofeo R's like 27psi. These are Hot Temps Whats your Track Set-Up? |
#3 |
i'm sorry, what?
Drives: Canada
the stock Michelins seem to respond well when set at around 35psi cold, this is for both autocross and track
if you're gonna be on the track, don't stay out too long and bleed off pressure if you start going over 39 hot
| Have a tire pressure gauge you really like? | Anthony | Tracking / Autocross / HPDE / Drifting | 21 | 09-10-2013 06:09 PM |
| what is your tire pressure? | abling2 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-03-2013 10:49 AM |
| What Hot Tire Pressure? | gbgracer | Tracking / Autocross / HPDE / Drifting | 24 | 05-14-2013 05:47 AM |
| Autocross Tire Pressure on ZII's | Areddi | Tracking / Autocross / HPDE / Drifting | 6 | 04-12-2013 08:37 PM |
| BEST TIRE PRESSURE TO RUN TRACK | karma003 | Tracking / Autocross / HPDE / Drifting | 13 | 10-24-2012 05:32 PM |
