Old 10-05-2013, 02:04 PM   #15
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
Hey guys slightly off topic but I got this small dent on the top of the driver side, and it has started to rust. Anyone know how to fix this kind of thing?
I was planning to get some touch up paint and clear coat from Toyota/Subaru. If I just paint over it, will the rust continue to grow?
Thanks for the help
Chinadian is offline   Reply With Quote
Old 10-05-2013, 02:42 PM   #16
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
clean the rust asap and put on touch up few coats.
hanabie is offline   Reply With Quote
Old 10-06-2013, 02:26 PM   #17
Chinadian
Chinadian's Avatar
How do I clean the rust? what products do I need to use?
thansk!
Old 10-06-2013, 02:45 PM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
thansk!
x2
Old 10-07-2013, 03:39 AM   #19
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
thansk!
drcolorchip.com recommends this 3M sanding pen on rusted paint chips.
Found it in their FAQ section under the "surface types" drop down menu.
Never add touch up paint over rust! Clean it first no matter what.
Anorexic 86 is offline   Reply With Quote
Old 10-11-2013, 03:16 PM   #20
mush
mush's Avatar
How many times have you washed your car since applying it?
Do you find it to be permanent or just a temporary filler?
washed it maybe couple times
too soon to know if its permanent, i got it about 2 months ago
so far its holding up pretty well, and its way better than a black spot, blends good
The Following User Says Thank You to mush For This Useful Post:
dem00n (10-11-2013)
Old 10-11-2013, 03:56 PM   #21
mid_life_crisis
Drives: FR-S 10 #103 AT
thansk!
Fine grit sandpaper and get down to bare metal. You also need to make sure you get back into what looks like good paint to make sure you get all the rust. When you finish sanding, the area on a small nick like that should be at least twice as large as when you started. Dry it thoroughly and apply some primer immediately to seal it until you can decide whether to paint it yourself or have a pro shoot it.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Chinadian (10-12-2013)
Old 10-12-2013, 12:19 PM   #22
Chinadian
Chinadian's Avatar
What kind of primer? any examples? what does it look like and if we can get it at like Canadian tire or big box stores ( incananada?)
thanks
Old 10-12-2013, 04:21 PM   #23
mid_life_crisis
It's been too long since I did my own work. I have no knowledge of current products, sorry.
Any decent parts store should be able to set you up. If you have it painted professionally they'll probably sand it off and start clean anyway. The sanding and priming is just to stop the rust while you decide what to do. Rust is car cancer. You need to excise it immediately so it doesn't spread.
Old 10-13-2013, 12:59 AM   #24
Chinadian
Chinadian's Avatar
Anyone Know where I can get some of this in Canada? I have tried 2 different Canadian tires' auto section but couldn't find it. some other forum had said we could find it in Canadian tire.
Thanks
Old 10-13-2013, 04:55 AM   #25
Anorexic 86
Thanks
I found several different ones on amazon.com
Search 3m spot sanding pen
Touch up paint? Hanakuso Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 76 10-08-2015 01:55 PM
touch-up paint jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 08-14-2013 10:34 AM
touch up paint Bt216 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-15-2013 09:40 PM
Touch Up Paint... ScionFrsFan Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 36 03-19-2013 02:21 PM
Touch Up Paint or too big? JohnAyySays Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 02-21-2013 12:11 AM
