Old 10-11-2013, 06:05 PM   #1
Raceseng
Raceseng's Avatar
Raceseng | Introducing STIFF ARM | New Strut Tower Bars
We are excited to announce the release of our new strut tower bars...
STIFF ARM |
We developed an all aluminum strut tower bar system we call, Stiff Arm. The Stiff Arm bars are not only lighter then the factory bars but stronger providing a more rigid connection between the firewall and strut towers.
The Stiff Arms are available in:
ORANGE
BLUE
RED
BRONZE
GUNMETAL
http://www.raceseng.com/stiff-arm-20...r-s-subaru-brz
$299
STRONGER AND LIGHTER
TUBING
We utilized aluminum structural tubing that is 2X the wall thickness of the factory steel bars. Our tubing wall thickness is 1/8" thick while the factory bar is 1/16" thick!
BAR ENDS
The bar ends are intentionally designed to translate the load from the bar into the strut tower while maintaining a lightweight design. To achieve this we had to do extensive sculptural machining to create a minimum wall thickness throughout the bar end.
TIG WELDING
The union of the bar end and tubing is done through meticulous, high quality TIG welding. The physical bond created with this process creates an incredibly strong connection.
LIGHTWEIGHT
The Stiff Arms weigh .735 lbs while the stock arms weigh 1.043 lbs.
DIRECT BOLT ON
The Stiff Arms are a direct bolt on product, no modifications necessary. The arms come with high quality stainless steel hardware including socket head cap screws, nyloc nuts and washers.
SIDE BY SIDE COMPARISON
The factory strut tower bars are a piece of steel tubing that is crimped on either end to create a flat bolting surface. While this is a cost effective part, it is not the most ideal scenario. We took the principle of what a firewall to strut tower bar is and designed the Stiff Arm to be a rigid structure while maintaining a lightweight design. Let's not forget about design, this is where form and function come in! We designed the bar ends to have a gorgeous form while maintaining their function as a mounting block for the tubing to be welded to.
RACESENG DESIGNED + CRAFTED
DESIGN
We design and develop our products in house! This capability allows us to create products like nothing you've ever seen or experienced. Our goal is to deliver products with a resounding sense of authenticity, where form and function fuel each other.
CRAFT
We manufacture our products in house! From cnc programming to machining production, our parts are made in house using our own manufacturing equipment. "Proudly made in the USA" may sound a bit cliche but that mantra is an integral part of the culture at Raceseng. Our joy lives in the process of crafting our own performance products.
Raceseng is offline   Reply With Quote
Old 10-11-2013, 06:59 PM   #2
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Really like these, but looks like the wont work with the grimmspeed strut tower brace...too bad.
gdrider77 is offline   Reply With Quote
Old 10-11-2013, 07:02 PM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Damn the quality you guys manage to put out!
Makes other parts look crap!
Old 10-11-2013, 07:05 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Top notch stuff, guys!!!
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-11-2013, 07:12 PM   #5
Raceseng
Raceseng's Avatar
That is the Raceseng way!
Jarrett Seng
Raceseng | Owner
610.336.0206
Old 10-11-2013, 07:33 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
any ideas of a strut bar?
Old 10-11-2013, 07:56 PM   #7
Tsungfai
Tsungfai's Avatar
Drives: 2013 Scion FR-S Raven
Damn, really wanted this, though it doesn't seem like it'll fit with Ground Control camber plates.
Tsungfai is offline   Reply With Quote
Old 10-11-2013, 09:24 PM   #8
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
If it replaces the stock bars how does it not work with the GrimmSpeed strut bar or GC camber plates?
Enraged21 is offline   Reply With Quote
Old 10-11-2013, 11:19 PM   #9
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Because the point where you bolt up to is not flat like the OEM bar. The GrimmSpeed bar is installed on top of the OEM bars. Now Raceseng has to come up with a flat "Stiff Bar" strut brace that goes under these Stiff Arm bars if they decide to go that route.
For Reference:
LeeMaster is offline   Reply With Quote
Old 10-11-2013, 11:42 PM   #10
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Dear lord that stuff is gorgeous. I'm so tempted to get that, the tow hook, and if you guys plan to anodize the camber plates that are in development that color as well I'm gonna be a long time customer. I'm sooo interested in lots of orange bits for my car.
raul is offline   Reply With Quote
Old 10-11-2013, 11:52 PM   #11
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
Loooooks great~
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 10-12-2013, 12:05 AM   #12
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
This stuff is like functional jewelry for your car, the entire line of raceseng products. Dang...
Intent > Content
Old 10-21-2013, 06:40 PM   #13
frs10
Drives: tezla
make a strut bar too!!
frs10 is offline   Reply With Quote
Old 10-28-2013, 09:55 PM   #14
Raceseng
Raceseng's Avatar
In the works!!
Tanabe front and rear strut tower bars .. ?? FriedRicr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-27-2014 01:46 PM
FS Cusco Strut Tower bars front and rear Wes Brakes, Suspension, Chassis 17 01-09-2014 11:54 PM
Raceseng | Introducing STIFF ARM | New Strut Tower Bars Raceseng Brakes, Suspension, Chassis 1 10-28-2013 09:54 PM
Raceseng | Introducing STIFF ARM | New Strut Tower Bars Raceseng Announcements, Contests, Giveaways 2 10-11-2013 06:52 PM
Beatrush strut bar and tower bars installed [picture] Asus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 04-28-2013 07:51 PM
