Old 10-11-2013, 05:32 PM   #43
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
There are guys with just e85 tunes and bolt ons in the low 5s spinning lol... as mentioned above the turbo ones are doing it in the low 4s and under with 300-400whp. Spinning is the problem for sure, mine does like crazy and I'm stock still.
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
Old 10-11-2013, 05:52 PM   #44
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by Kido1986 View Post
Ive done 5.9s and similar with light wheels, sticky tires, air filter, axelback delete. Verified and repeated with Torque
Would you mind sharing how you are launching? Might help out in Autocross.
raul is offline   Reply With Quote
Old 10-11-2013, 06:23 PM   #45
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
60 to 130 is the new 0-60
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
SkullWorks (10-11-2013)
Old 10-11-2013, 06:56 PM   #46
Hardrock4445
Hardrock4445's Avatar
Originally Posted by stefmiesterb View Post
Block the sound tube, you'll thank me later.
Sound tube is deleted
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 10-11-2013, 07:34 PM   #47
davidp
Drives: BRZ Limited
well here is mine i didn't count how long it took but this is a bone stock car
edit: around 6.3
[ame="http://www.youtube.com/watch?v=oUq7zTNsru0"]Brz acceleration - YouTube[/ame]
davidp is offline   Reply With Quote
Old 10-12-2013, 07:16 AM   #48
Kefuddle
Drives: Blue manual Toyota GT86
Originally Posted by NoFear99 View Post
I dont see how we can reach 0-60mph or 0-100 km/h in 6 seconds with our car...My car is not stock and it is more toward the 7 seconds.
You look pretty high up there NoFear, what's the elevation above sea level. That probably is one of the biggest factors for a normally aspirated motor.
Kefuddle is offline   Reply With Quote
Old 10-12-2013, 10:56 AM   #49
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Street grip sucks so I launch hard at the track. Im on RS3s remember so your results may vary with different tires, even of the same quality.
Find the spot to let out all of your clutch play (since these pedals are dead for the first 50%). Once you have the the clutch out to the point the car's moving, push it back in BARELY, just to stop the rolling. 4000rpm, then I pick up off of it as quickly as possible (note that I'm not sidestepping it). Put the throttle to the mat a the same time and you're off.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 10-12-2013, 01:22 PM   #50
raul
Lap time enthusiast
raul's Avatar
That helps a ton. I'm on Bridgestone RE-11As so it might be similar. They like slightly lower pressures so I'm probably looking at a decent amount of grip.
Old 10-12-2013, 07:44 PM   #51
Cal3000
Drives: Panda FR-S
Originally Posted by tacoss23 View Post
What I wonder is the 0-60 times for the Vortech/Innovate Supercharged builds?
It would be interested to see if the $5k-$7k investment has a decent effect in the 0-60 time.
[ame="http://www.youtube.com/watch?v=Z_P8O0bDh04"]http://www.youtube.com/watch?v=Z_P8O0bDh04[/ame]
I did a launch at 216whp with the crappy stock tires, traction control on which slows the car down a great deal, and slow shifting while holding the camera and steering with one hand. I think it's about 5.6s
Give me better tires and a camera mount, I think I can get to the 4s
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
