Old 10-11-2013, 01:43 PM   #57
Nissanfan
Drives: subaru brz
Originally Posted by driftartist View Post
mine have been gone 7000 miles but im sure everyone's situation is different.
Does anyone know, why it does the noise? And why after replacement works fine for couple thousand miles, then comes out again? Are there any aftermarket options? I might buy a used pump (the broken one), and inspect it and try to redesign the crap subaru/toyota fxcked up.
Mine was replaced month ago, and after a week noise came and went. Seems like something is wearing out and once it lets go, noise just happens. Maybe flow actuator of some sort i'm thinking, since it silences when revs are increased.
2013 BRZ Limited 6speed Manual
Nissanfan is offline   Reply With Quote
Old 10-11-2013, 02:02 PM   #58
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showthread.php?t=41776
This is the most scientific we have. There are hypothesis about ethanol content causing some coating to wear away or not lubricating properly but there are people running E85 with no chirps and others who have run ethanol free fuels with no results.
The noise is never permanent in my experience, mine's been 90% quiet (as in unnoticeable unless you pop the hood and stick your head in) for the last 5,000+ miles. I'm almost at 15,000 miles, on the original pump, all California 91 octane E10, the cheapest/most convenient station I come across, everything some people say guarantees the chirp.
ineedyourdiddly
Old 10-11-2013, 07:49 PM   #59
Ozzman
Drives: old
I tend to think it's the sound of cavitation.
I had a rear shock on my MTB that would make some strange noises if the nitrogen charge got low.
Ozzman is offline   Reply With Quote
Old 10-11-2013, 10:34 PM   #60
PMPB
Drives: BRZ Sport-tech
I agree. I'm pretty sure I remember reading that they engineers said it was 'aeration' of the fuel. To me, this means cavitation. Some of the TDI fuel pumps have been known to eat themselves after long time in service with cavitation. I'm pretty sure everything between the fuel pump and the engine is destroyed when the pump internals come apart.
PMPB is offline   Reply With Quote
Old 10-11-2013, 11:45 PM   #61
wootwoot
Drives: FRS
I worry about the longterm effects 2 stroke oil will have on Catalytic converters and o2 sensors.
And to some extent if it will cause any build up on the direct injectors.
You only put a cap full or two in at every fill up. I doubt there will be any long term issues with that small of volume,
Old 10-12-2013, 01:34 AM   #62
ironsurfer129
Drives: Whiteout FR-S
I'm taking my car in to replace certain thing for this cricket sound tomorrow; let's see what Toyota can offer me this part did take them 1.5 months to get to the dealer
ironsurfer129 is offline   Reply With Quote
Old 10-12-2013, 02:00 PM   #63
JSMIL
JSMIL's Avatar
Drives: FRS 10 series
Be sure and get a part number for the fuel pump and post it, if they replace it, so the rest of us can look into it.
JSMIL is offline   Reply With Quote
Old 10-13-2013, 09:59 AM   #64
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
As JSMIL pointed out in the Engine idle chirping (cricket) noise poll thread, Subaru has a new HPFP part number 16625JB010 (Stock - 16625JB000). So its likely Scion will have one too, please help us confirm this by posting your replacement HPFP part #s.
mwjcyber is offline   Reply With Quote
The Following User Says Thank You to mwjcyber For This Useful Post:
PoorMansRacing (11-20-2013)
Old 10-13-2013, 10:57 AM   #65
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Bad Habits View Post
Sry didn't notice you had a scion. I feel you on sounding like crap. Nothing like having a brand new car with windows that sound like fingernails on a chalkboard and an engine that sounds like its two decades old.
When my doors were being done (prepped for speakers), we had to connect the switch to move the window. That is the only time I have heard it squeal. The problem might be missing or misaligned guides.
I'm getting the pump done tomorrow. I'll report back in 500 miles.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-14-2013, 10:24 AM   #66
JSMIL
JSMIL's Avatar
Get the pat number of the fuel pump and post it so we can see if it is a new one or the same green dot that does not work.
Old 10-14-2013, 11:06 AM   #67
mid_life_crisis
I'm told it is still the same part number. That's why you can't tell what you're getting.
I haven't been following this for very long. Is a green dot supposed to differentiate a new design from the original design? So it's possible that this will only be a short term fix or there might be three different pumps? Be bizarre to lemon law the car over crickets, but if they replace the pump every 500 miles...
Old 10-14-2013, 02:05 PM   #68
JSMIL
JSMIL's Avatar
The green dot is the first replacement pump they tried. It was the same part number as the original but had a green dot on the box to differentiate between the two. Supposedly there is a new 2nd replacement, however no one seems to have the part number for Toyota yet. The Subaru part number has been posted for it though. Hope this clears things up as we know them now. That is why I am trying to get someone to post the new part number for Toyota.
Old 10-14-2013, 02:16 PM   #69
mid_life_crisis
What is the original Toyota part number so I can tell if they are different when I get the paperwork?
Edit: The part # is su003-00328. They also replaced a couple of pipes. I don't know if that means anything or not.
There is no mention on the papers of a flash, but the car is quicker than it was before, and louder under acceleration. I could be imagining the change in power but I have definitely never heard the car rumble under acceleration before. It makes no sense, but there it is.
Old 10-15-2013, 12:27 AM   #70
ironsurfer129
Here are the parts
SU003-00342 pipe ay-fuel dlvy
SU003-00328 pmp at-fuel, h prs
SU003-00347 gskt-fuel pipe
SU003-00316 gskt-throt chmbr
SU003-00290 gskt-int mainf
So far I haven't heard any cricket sound yet, but it's only been 100 miles or so
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 09:41 AM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 01:21 PM
FYI Engine Chirping Fix pvtpile Hawaii 139 05-19-2015 05:42 PM
Can you hear chirping from my engine? 8987846 CANADA 4 06-28-2013 12:16 PM
Can you hear chirping from my engine? 8987846 Engine, Exhaust, Transmission 1 06-26-2013 11:15 PM
