Old 09-27-2013, 12:58 AM   #71
Gen
Drives: Scion FR-S
Originally Posted by Ethan View Post
There is a thread on this and a mesh part you can buy through Rally Sport Direct. See: http://www.ft86club.com/forums/showthread.php?t=33462. I was ready to do this because: (i) I hate have a fake vent on my BRZ, and (ii) extra cooling would be nice.
I held off, however, for a couple of reasons. If you pop the hood, you'll notice that the hood hinges are right in the area where the vent would go. So, I have a hard time believing that a ton of air could flow through that spot. Also, I was concerned that rain would get in and then get stuck inside the quarter panel. Any thoughts on those issues?
You'd be quite surprised how much heat is released with those vents. After a hard drive, it will burn your hand if you hold it there too long.
Gen is offline   Reply With Quote
The Following 2 Users Say Thank You to Gen For This Useful Post:
Anthony (09-27-2013), Ethan (09-27-2013)
Old 09-27-2013, 12:04 PM   #72
Ethan
Drives: Subaru BRZ
Back to the original question of this post, I have been lusting over the Seibon TS hood. Anyone have experience with it.
Ethan is offline   Reply With Quote
Old 09-27-2013, 02:59 PM   #73
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by ftc~brz View Post
oh but they do read themselves in the brz. Just saying
Weeeeellllllllllllllllllllllllll... technically that's the car reading the message. Not the message reading itself. I still stand by my conviction.
Is that your car?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-27-2013, 03:09 PM   #74
ftc~brz
Done
Drives: WRB BRZ
Is that your car?
true…
yes it's mine.
the last 2 times I have had frs owners in my car when I have received a message it's been my hubs sending me his standard "I love you" txt. So both times it's been witnessed my car has told me it loves me lol
ftc~brz is offline   Reply With Quote
The Following 3 Users Say Thank You to ftc~brz For This Useful Post:
Anthony (09-27-2013), DriftEightSix (10-17-2013), RedAlert (10-10-2013)
Old 09-27-2013, 03:24 PM   #75
Anthony
Weight Nazi
Anthony's Avatar
Haha nice. That was my first time hearing crickets. Was that your car making the sound? If so, I'm surprised that it sounds exactly like crickets.
Old 09-27-2013, 03:33 PM   #76
ftc~brz
Done
Drives: WRB BRZ
no, that was actual crickets the car wasn't running, but the "crickets" do sound just like that.
The Following User Says Thank You to ftc~brz For This Useful Post:
Old 09-27-2013, 11:33 PM   #77
Ethan
Drives: Subaru BRZ
On the possibility of replacing the fake fender vents with real fender vents, I spoke with a body shop today and thought I should share a few points. First, I asked about using the stock plastic pieces on the BRZ cutting out the fake part and replacing with mesh. The problem with that approach is that would be cutting out four of the six plastic clips that secure it to the car. The Prova part only uses to fasteners, but it looks like they are metal screws. So, while the Prova parts are expensive ($399), it would be more secure than using the stock piece with only two plastic clips. The second issue to consider is getting rain inside the fender. The body shop recommended pulling the fender off, drilling any necessary holes at the bottom to let water out (and which wouldn't be visible after the fender is back on), and then spraying the inside to prevent rust. I am very tempted to do it.
Old 10-10-2013, 02:06 PM   #78
phloozy
phloozy's Avatar
Drives: Scion FR-S
any updates on people with vents?
phloozy is offline   Reply With Quote
Old 10-10-2013, 04:39 PM   #79
JustBoostin
Drives: Asphalt FR-S 6MT
I cut stock brz vents for mine. And only left one clip. I put double sided foam tape around the edges and it holds flawlessly, and releases a ton of hot air. I'll update my post later with pictures!
*EDIT*
JustBoostin is offline   Reply With Quote
The Following 19 Users Say Thank You to JustBoostin For This Useful Post:
1slowbrz (10-11-2013), 86-tundra (05-25-2014), Anthony (10-12-2013), bama_brz (03-03-2014), blackfireball5 (03-03-2014), diss7 (02-15-2014), ftc~brz (10-16-2013), gdrider77 (10-11-2013), GT 86 Brah (12-18-2013), GT86_PRAGUE (06-18-2015), kask2_6.0 (10-17-2013), kmbkk (10-11-2013), mikeTee (10-16-2013), OjiGeorge (05-26-2014), pheoxs (10-10-2013), SkAsphalt (03-03-2014), SPCorBUST (10-05-2015), Sportsguy83 (10-11-2013), Wes (10-11-2013)
Old 10-11-2013, 12:09 AM   #80
1slowbrz
1slowbrz's Avatar
Drives: 2017 WRB BRZ PP
^Want!
1slowbrz is offline   Reply With Quote
The Following User Says Thank You to 1slowbrz For This Useful Post:
JustBoostin (10-11-2013)
Old 10-11-2013, 01:28 AM   #81
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by 1slowbrz View Post
^Want!
Me too. Great job.
Sellout is offline   Reply With Quote
The Following User Says Thank You to Sellout For This Useful Post:
Old 10-11-2013, 01:55 AM   #82
mike the snake
I think I'm going to try this. The aftermarket plastic vents are like $400, almost what a vented hood costs.
This can be done for free, and looks like it might work pretty well.
Old 10-11-2013, 02:15 AM   #83
redsuns03
Off the top of my head, I believe @Supermassive has a vented hood and P&L Turbo Kit.
Edit: Yes, he does
http://www.ft86club.com/forums/showthread.php?t=23457
I know it's an old post but I pretty much bought his hood and it's on my car lol.
The Following 2 Users Say Thank You to redsuns03 For This Useful Post:
bama_brz (03-03-2014), Sportsguy83 (10-11-2013)
Old 10-11-2013, 11:11 AM   #84
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
Originally Posted by Supermassive View Post
I can actually attest to this...the FR-S generates a ton of underhood pressure. When I was running my CF hood it was extremely noticeable because it would flex the sides of the hood up (near the wheel arches). At 160 there was about a 1-1/2 inch gap between the hood and the wheel arches...I decided to slow down since i didn't want the hood to break. That hood was also vented so it's definitely a science as to where venting should be to alleviate that pressure. I personally think that function fender vents would help substantially...but that would require some serious fabrication to make work well.
are u saying a vented fender would be a better option then a vented hood??
DAN_BRZ is offline   Reply With Quote
snails and turbos carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 10 12-27-2012 05:44 PM
Turbos making less power down low? subatoy Forced Induction 40 10-03-2012 03:30 AM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 05:44 PM
Why does the aftermarket love turbos? Why not superchargers? ahausheer Other Vehicles & General Automotive Discussions 43 07-22-2012 11:27 AM
For those crying about turbos Mari0 Off-Topic Lounge [WARNING: NO POLITICS] 2 06-15-2012 10:57 PM
