Old 10-09-2013, 03:24 PM   #1
My_First_Subaru
My_First_Subaru's Avatar
Drives: SWP Subaru BRZ
Perrin cat back 2.5" or 3"
Hello everyone. For the past few weeks ie been trying to decide on whether or not I should get the 2.5 or 3. I'm not very good with cars so bear with me lol. I am possibly open to get sc sometime in the future but If I don't and stay NA will the 3 be useless or will it lower HP and tq. I mainly am looking at the 3 just for the fact that I may possibly sc. Thanks. Also I hear there are slight gains in the 3 but have not seen a dyno chart. Also the 2.5 is on amazon and this quarter I get 5 percent cash back on my chase card.
My_First_Subaru is offline   Reply With Quote
Old 10-09-2013, 05:45 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
3" no if your going to stay NA for a quite a while longer.
Also note that 3" catback won't do much good if the other parts of the exhaust aren't 3" as well.
Old 10-09-2013, 06:19 PM   #3
My_First_Subaru
So most likely it would be a waste to get the 3 until the future if I decide to sc
Old 10-09-2013, 06:33 PM   #4
coolaron
2.5" for NA
3" for FI
coolaron is offline   Reply With Quote
Old 10-09-2013, 06:35 PM   #5
My_First_Subaru
But then I prolly won't decide till wayy later lol. So I figure If I get the 3 I won't have to worry about getting a new catback and I could just use that then change the overpipe etc.
Old 10-09-2013, 06:42 PM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Even if you get the 2.5", you won't "need" the 3" when/if you go FI.
The Following User Says Thank You to boredom.is.me For This Useful Post:
rs999 (11-21-2014)
Old 10-09-2013, 07:23 PM   #7
My_First_Subaru
Oh ok thanks. So I can run sc on a 2.5" if I decide to. I'm assuming better airflow would be better
Old 10-09-2013, 07:46 PM   #8
boredom.is.me
Custom User Title
It probably would be better with a larger exhaust if you are really boosting, but many FI makers test their products on the stock exhaust. I know Innovative and AVO to name a couple.
Old 10-09-2013, 09:23 PM   #9
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
I am having the same issue.
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 10-09-2013, 09:53 PM   #10
Turdinator
Señor Member
Turdinator's Avatar
I haven't seen a dyno yet that shows a 3" losing power or torque with NA setup. Once you go FI a 3" will make more power even though its not "needed". If it were me, I would go the 3" to save buying two exhausts. Provided it wasn't too loud on an NA setup of course.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
DAN_BRZ (10-10-2013)
Old 10-09-2013, 10:04 PM   #11
reardrv
Drives: 2013 Subaru BRZ
I have not seen any evidence in either direction for our car saying what size is the best. A few company's do say there is a slight benefit to going with a 3", but I'll believe it when I see some dyno info. But why not prepare for the future? I've had multiple turbocharged cars and the do certainly benefit from 3" piping.
Before anyone says "well if the piping doesn't all match, you wont see any benefit". This is false. Exhaust gasses cool and expand as they travel through your exhaust system, so an increase in piping diameter as the exhaust moves to the rear can be beneficial.
And if anyone is about to say you need a certain amount of back pressure, stop yourselves right now and do some research. You do not want any back pressure. The reason using an over sized exhaust can hurt horsepower is due to excessive cooling of exhaust gasses, causing the gasses to slow. This will lead to more back pressure. Exhaust velocity and exhaust scavenging is very important to producing power.
Going on engine displacement alone, or NA vs FI is ignorant. A 2.0l ABA VW is certainly going to see negative results from a 3" exhaust, however that's not a 200hp, 12.5:1 compression, high revving performance engine.
Until I see some real numbers, I wont buy into the speculation. However since I would like to go with forced induction in the future, I will personally be going with a 3" exhaust when the time comes. No need to buy an exhaust twice.
reardrv is offline   Reply With Quote
The Following 3 Users Say Thank You to reardrv For This Useful Post:
boredom.is.me (10-09-2013), Plumbus (03-22-2020), Turdinator (10-10-2013)
Old 10-10-2013, 10:58 AM   #12
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Only drawbacks to 3 inch exhaust is noise, weight, cost and clearances. Those are pretty significant if you ask me. Only you can decide if that's worth a few extra hp.
I'm either building a NA motor or going FI and I'm pretty sure I'll be just fine with a 2.5 inch exhaust.
Also, gases don't expand on their own when they cool. If they do, you lose velocity. Not that exhaust velocities really matter beyond the header in our cars anyway.
industrial is offline   Reply With Quote
Old 10-10-2013, 01:21 PM   #13
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
If your just going cat back it will do no good to go 3" as the front and mid pipe will still be smaller. I don't think perrin has a 3" mid pipe due to clearance issues.
Just going catless or with a high-flow cat will give you more improvements than a catback.
Old 10-10-2013, 05:07 PM   #14
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
your wrong perrin does make a 3" front pipe, but does not make a 3" overpipe
http://perrinperformance.com/i-13324...-fr-s-brz.html
DAN_BRZ is offline   Reply With Quote
difficulties finding Perrin 3" cat-back jonbonazza Engine, Exhaust, Transmission 2 05-27-2013 02:34 PM
Long "Scion" sticker on back bumper CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 7 04-12-2013 10:31 AM
My Wife Found a New "Cat Back" Exhaust Toyota86Fan Other Vehicles & General Automotive Discussions 6 10-15-2012 08:17 PM
the "Your order has been pushed back" support group Surok AUSTRALIA 143 09-11-2012 02:52 AM
"Memory" on seat-back tilt? sesmls BRZ First-Gen (2012+) — General Topics 20 06-08-2012 12:42 PM
