Old 10-04-2013, 08:36 AM   #2633
Nothing
Drives: FRS
Originally Posted by regal View Post
Subaru actually issued a very complicated TSB to fix the hardware. But it is so intense I honestly don't think many local dealerships could perform the work without a field engineer on site. Its one of those TSB where you are better off blowing up the engine and trying again.
Did we miss this TSB?
Sent from my iPhone using Tapatalk - now Free
Nothing is offline   Reply With Quote
Old 10-04-2013, 08:41 AM   #2634
regal
Drives: Scion FR-S/Toyota Yaris
11-130-13R
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
The Following 4 Users Say Thank You to regal For This Useful Post:
@Art_Mighty (10-04-2013), eurospeed (11-25-2013), Marrk (10-04-2013), Nothing (10-04-2013)
Old 10-04-2013, 01:02 PM   #2635
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Well we can add me to the list of with P0016. So in both cases, you guys had the passenger intake actuator replaced and it resolved the issue?
Yup. If it's machining errors with the parts replacing them will resolve the issue. Personally I think even the re flashes are fixing things as much as they are "working around" machining errors.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-07-2013, 01:12 PM   #2636
xarnyz
Drives: 2014 Frs
2014 FRS, 10 miles, crankshaft position sensor error (forgot which number that was) In shop. California.
xarnyz is offline   Reply With Quote
The Following User Says Thank You to xarnyz For This Useful Post:
Old 10-07-2013, 02:59 PM   #2637
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Anytime I speed and rev over 6000 RPM on mostly 3rd to 5th gear my SL light and check engine go on, after a day or two it's gone automatically, anyone has this?
Yamajee is offline   Reply With Quote
The Following User Says Thank You to Yamajee For This Useful Post:
Old 10-07-2013, 03:47 PM   #2638
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
I would take it to the dealer. It needs to be fixed, whether or not its the same issue is academic.
Sent from my SCH-I535 using Tapatalk 4
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 10-07-2013, 03:59 PM   #2639
xarnyz
Drives: 2014 Frs
2014 FRS, Installed new ecu, put 50 miles on it, and put it back in my hands.
Old 10-10-2013, 11:54 AM   #2640
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Initial Post:
I've noticed this issue popping up twice so far since I've put my Greddy Turbo on and had my ECU flashed. I have about 6K miles and am working with my tuner. If the components are faulty before I did my mods, then this could suck a little bit...or a lot lol
-Check Engine Light on & Traction Control light on (same time, car parked)
-Code P0011
-Code P0017
-Code P000A
shiro is offline   Reply With Quote
The Following User Says Thank You to shiro For This Useful Post:
Old 10-11-2013, 11:18 AM   #2641
PMPB
Drives: BRZ Sport-tech
Can add me to the list. No codes *yet*
But a few times I've had the engine almost stall, severe shaking, and the headlights turned off (engine keep alive function engaged I guess) with RPM's dropping into the low hundreds.
I also typically have the engine always hunting at idle. Hot or cold engine, hot or cold weather. 400-900rpm idle range, 600 being the target... 600,500,400,900...800...700...600 repeat idle pattern. (dots being long interval, comma being rapid succession of number)
PMPB is offline   Reply With Quote
The Following 2 Users Say Thank You to PMPB For This Useful Post:
eurospeed (11-25-2013), Marrk (10-11-2013)
Old 10-11-2013, 12:02 PM   #2642
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Take it in and have it fixed, Refer to Subaru Tech Bulletin 11-130-13R
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 10-11-2013, 02:23 PM   #2643
Nothing
Drives: FRS
So I'm gonna attempt to repair this myself. Does anyone have an exploded diagram of the cam system? Hell, a picture of the part itself would work at this point so I can have an idea what my weekend could look like.
Honestly I see it like this. Mechanical parts can fail at a given point. If all they are doing is increasing the tolerance of the sensor parameters who's to really say that's safe? It's a cheap and quick 15 min patch but does it correct the issue? Also, is that what they've done? And if so, what are they so we can do the same?
The Following User Says Thank You to Nothing For This Useful Post:
Marrk (10-11-2013)
Old 10-11-2013, 03:40 PM   #2644
shiro
shiro's Avatar
Update 1:
I will be taking my FRS in on Monday for my idling issues. I've talked with my Tuner and we have a good feeling it isn't the E-85 Tune on my car. This will be a good test for Toyota to see if they are going to be cool with the warranty and a moded car. The dealership said that they will do their best to work with me on this. Hopefully good news and a good fix! lol
Marrk (10-11-2013)
Old 10-12-2013, 12:22 PM   #2645
Nothing
Drives: FRS
From everyone that I've spoken with it works a lot like this.
Have you flashed your ECU?
Did you flash back to stock before you took it in?
If not you are screwed 99% of the time.
The reason is that the car talks back to Toyota to tell them what to fix and blah blah blah... If the computer sees you've flashed the ECU it reports that to Toyota and they politely tell you it's not their fault. It's your tune.
Old 10-12-2013, 12:35 PM   #2646
shiro
shiro's Avatar
Update 2:
You make a very valid point. I did chat with the service advisers about my modifications yesterday and they said if they can replicate the issue in the shop they'd help me out the best they can. I know what "blowing smoke up the ass" is but it's worth a shot. It might take a while but I will be sure to let everyone know about the results.
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
