Old 10-09-2013, 07:42 PM   #197
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Couldn't wait until Nov so Bob and me are trying to push for end of Oct bwahaha
Can't wait to be Drift Office tuned instead of my ticking time bomb Visconitune
Originally Posted by OjiGeorge View Post
You better believe I'll be planning a visit back to Vancouver to check it out when you're done Jeff!
Come on come all. I will show you the light as @Drift Office Bob showed me
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 10-09-2013, 11:23 PM   #198
tiny41
Drives: Subaru BRZ Limited
I'm getting mines installed with my friends this weekend.
Still trying to figure out who can tune my car since I bought the openflash tablet instead of the ecutek.
tiny41 is offline   Reply With Quote
Old 10-10-2013, 12:29 AM   #199
Pete156
I like to eat!
Only way to go
Pete156 is offline   Reply With Quote
Old 10-10-2013, 02:13 AM   #200
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Last of the parts arrived today. So it looks like I will be installing this weekend as well. If all goes according to plan.
FrX is offline   Reply With Quote
Old 10-12-2013, 07:53 PM   #201
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Ongoing install, plan to remove the washer fluid bottle/reservoir because it kinks the hose for the inter cooler.
Has anyone done a mod for the bottle or is there an alternative product for this?
andrewFT86 is offline   Reply With Quote
Old 10-12-2013, 08:39 PM   #202
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
AVO instructions say to enlarge a hole that holds the bottle on the bottom thus allowing it to sit lower and make room for the IC hose.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
andrewFT86 (10-12-2013)
Old 10-12-2013, 09:00 PM   #203
Calum
That Guy
Drives: 2013 asphalt FRS MT
IIRC Vortech sells their bottle separately.
The Following User Says Thank You to Calum For This Useful Post:
Old 10-12-2013, 09:11 PM   #204
Sportsguy83
Drives: Limited BRZ
Yes they do and I would have bought it if the reviews didnt say it was a POS
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
andrewFT86 (10-12-2013), Calum (10-13-2013)
Old 10-12-2013, 09:31 PM   #205
MFB
Avo Turboworld Phil Rep
Drives: Forester 2009 XT on e85
Currently this is what we are seeing with your car Doc.
Let me get back to you on this, wait what Paul suggests.
MFB is offline   Reply With Quote
The Following User Says Thank You to MFB For This Useful Post:
Old 10-12-2013, 11:20 PM   #206
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
I posted this in my build thread but I thought I'd share it directly here as I think it's pretty useful info. I was having an overboosting issue that I didn't discover until today on @ptuning's dyno.
So the overboosting issue was caused by the following broken hose:
This little bastard was hooked into the turbo directly. I can only assume it was responsible for feeding to the wastegate. Since it was broken right at the turbo this meant the air pressure never reached the gate and therefore never caused it to open.
My car built boost continuously. Toan @ptuning never let it get too dangerous but noticed there was an issue when I was making over 300 hp at around 5500 RPMs. He's going to send me the dyno plots for comical value.
Thankfully we caught this when we did. I learned a couple things here:
1. GET A @#$%ING BOOST GAUGE!! Even my "safe" 5 psi tune could have had catastrophic mechanical failures which very nearly lead to engine grenade. I would have known something was wrong if I had a boost gauge. I know this is obvious but I felt like reiterating the obvious since I didn't do the obvious...
2. This was the reason I "needed" a new clutch. I was making tremendous power and didn't even realize it. A stage 1 tune with the stock clutch might be just fine after all.
3. THIS ENGINE IS AMAZING. It put up with this unbelievable punishment without knocking or showing any signs that something was wrong. I was pushing 12+ psi on pump gas with no fueling system upgrades. I DO NOT recommend doing this permanently, but I must say I am thoroughly impressed and relieved that this wasn't a blown motor.
I'll post the dyno plot when PTuning sends it to me. I was on track to make nearly 330 whp lol. Don't know what the torque numbers were yet but boy was that a surprise....
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
The Following User Says Thank You to nataku For This Useful Post:
Old 10-12-2013, 11:22 PM   #207
gdrider77
gdrider77's Avatar
This. I imagine you could also drill another hole and move the hose over if you wanted, but not sure this would be required?
Is that kinked hose the washer spout feed line? Not sure I can tell from that pic/angle. I actually drilled the hole out as Avo instructed, and then also on the top mount I drilled a new hole and put a new screw in to the sheet metal.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Old 10-12-2013, 11:47 PM   #208
andrewFT86
andrewFT86's Avatar
Thanks Mark. Just want to find out how the other owners dealt with it. It's not a big thing to have but it is something nice to have.
Thanks for all the help.
Old 10-13-2013, 12:04 AM   #209
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Andrew there are three mods to the washer bottle.
1) enlarge the hole where the rest on.
2) oblong the top hole to allow the drop
3) oblong the side hole to allow the drop
you need to do all three or the bottle will not drop enough.
DAMotorsports is offline   Reply With Quote
The Following User Says Thank You to DAMotorsports For This Useful Post:
andrewFT86 (10-13-2013)
Old 10-13-2013, 03:23 AM   #210
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
Well I guess I got a lemon.....turbo got massive shaft play after only 17,000km and ate itself.....now the process of checking and hoping my motor isn't effed from all the metal...fml
brz2013 is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
