Old 10-06-2013, 01:35 PM   #1
SigmaHyperion
Drives: 2013 SWP BRZ Limited
Help With Sway Bar Contact After Lowering
Hey guys,
After lowering the car (just barely an inch) on Fortune 850s, I've noticed that occasionally there will be a noticeable 'jar' on some bumps; felt almost like I was hitting the stops on even small bumps sometimes which obviously shouldn't happen with such a relatively minor drop. So, took everything apart this afternoon to take a look, make sure I tightened everything, etc; and found what I believe to be the source of my problem.
As you can see, there is a spot on the LCA where the end of the swaybar is hitting the LCA. Hard to see in the photo, but that's bare metal circled in the image, with a fairly noticeable 'notch' in it as well. This only occurs on the driver's side. If I load the suspension with a jack, I can make the swayback contact the control arm myself.
What do I need to do to fix this issue? Purchase adjustable endlinks? is there some way stock to slightly modify the position of the sway so it hangs a little lower, etc?
SigmaHyperion is offline   Reply With Quote
Old 10-07-2013, 12:18 PM   #2
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
adjustable end links are required
supramkivtt2jz is offline   Reply With Quote
Old 10-07-2013, 05:42 PM   #3
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
Adjustable endlinks would fix this problem.
Team STILLEN is offline   Reply With Quote
FR-S TRD Lowering Springs and Sway Bars releasing soon gvan1998 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 405 12-01-2015 06:48 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-23-2013 11:42 PM
Question on Sway bar and lowering coilover awang0528 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-28-2013 01:56 PM
