Old 10-07-2013, 05:47 AM   #113
ft_sjo
Drives: GT86
Kind of curious why this valve is based on 80's technology, when even in the 90's people were already developing double piston solutions which don't suffer this?
Old 10-07-2013, 06:10 AM   #114
v1ru5
Drives: BRZ D4S 6MT L Vortech
This is what I was expecting:
[ame="http://www.youtube.com/watch?v=i979eGJ0w74"]Supercharged 350Z Blowoff Sound - YouTube[/ame]
I want to know what needs to be done to eliminate the ear piercing whistle. It sounds like I have a terrible Ebay fake turbo whistle attached to my car. I want the smooth "woosh" noise that was in the first video posted by Vortech about this valve.
v1ru5 is offline   Reply With Quote
Old 10-07-2013, 10:02 AM   #115
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by v1ru5 View Post
@F1point4 let me know how adjusting it goes in regards to eliminating the ear piercing whistle when cruising.
6th gear at 70-80mph is almost unbearable with the windows down when you are just cruising down the highway. If the valve could just a touch more open i'm sure it wouldn't whistle. The original video posted by Vortech only had a "whoosh" not a whistle... I feel like it was falsely advertised at this point.
Didn't know it was that bad. Seemed pretty loud in videos but damn. I 99 percent of the time have the windows down so I guess thartd be a bad thing since I'm usually on the freeway.
So what exactly loosening the valve do? Sorry noon question.
ft86me is offline   Reply With Quote
Old 10-07-2013, 10:16 AM   #116
ft86me
ft86me's Avatar
Drives: 2013 FRS
New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems
Actually I just answered my own question because I remembered I had a message from Rick about what happens if the valve is loosens or tightened.
So according to Rick they did is just right. If you are to tighten the valve then what you are doing is making the valve open at higher vacuum level which could run the issue of compressor surge Wyses a big no-no. And this would be happening because the valve is not opening fast enough. On the other side if you loosen it it will need a lot less vacuum to open up. The issue with this is that it could open too fast.
With that being said I'm not sure how much of a minor adjustment or major adjustment would be needed. Hope this info helps
Old 10-07-2013, 10:18 AM   #117
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I'm actually confused on this too so I shot @Rick@Vortech a PM.
The instructions that come with the kit say its for both a bypass and blow-off valve from their MaxFlow Race series. The instructions say adjustment on the **BYPASS** sets when the valve opens and closes. for the **BLOWOFF** I think it reads, "don't touch it"
Maybe my English is bad.
Instructions pacge
20131003-VortechMaxFlowRaceBlowOffValve-001 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 10-07-2013, 10:30 AM   #118
Rick@Vortech
Drives: Scion FR-S
Looks like you got the instructions for our old valve (which came in a bypass valve & blowoff valve configuration). Discard those.
Right now, the valves you guys have are set to open at around 6" Hg (you can verify with a vacuum pump). At this point, yes you can play with adjustment screw & turn it down to open at a higher Hg. Keep in mind, the black plastic bypass valve that comes stock with the kit is set exactly the same as this new valve, you just can't hear it because the opening is much smaller.
We have a different spring that should do the trick if you don't have enough adjustment in your current vavle.
Rick@Vortech is offline   Reply With Quote
Old 10-07-2013, 10:33 AM   #119
ft86me
ft86me's Avatar
Drives: 2013 FRS
Tightening will cause compressor surge though right?
Old 10-07-2013, 10:39 AM   #120
Rick@Vortech
Drives: Scion FR-S
On this application, it shouldn't. As long as you make sure the valve is opening enough after you tighten the spring. This is where using a vacuum pump to test the valve is critical.
The Following User Says Thank You to Rick@Vortech For This Useful Post:
ft86me (10-07-2013)
Old 10-07-2013, 01:08 PM   #121
v1ru5
Am I reading this correct that I can loosen the screw to have the valve open a little bit more (hopefully softening the whistle a bit). how much of a turn is considered a "little bit".
Old 10-07-2013, 01:22 PM   #122
ft86me
ft86me's Avatar
Drives: 2013 FRS
I thought it was the opposite and you tighten it down some. I've been asking rick questions about how to tighten the valve. I gave it three good turns and used a vacuum reader and at 6 it's opening but not as much so I'm thinking this should do it. Of course I don't have my car so I can't say if it works because it's in the body shop. I thought loosening would cause it too blow off earlier. Tighter of course too would make it blow off later. So idk if I'm doing the right thing. Main goal is to eliminate the whistle. I don't mind the release while cursing like the by pass. Just wanna get rid of the whistle.
Old 10-07-2013, 07:01 PM   #123
F1point4
Photo Specialist
F1point4's Avatar
It's cool enough down here to roll around with the windows down: it is now bald eagle swooping in to gouge out the eyes of its prey. It's majestic to look at going about, but do not dare cross it........
Old 10-07-2013, 11:54 PM   #124
F1point4
Photo Specialist
F1point4's Avatar
Going about
One more montage of the new Vortech BOV at the default setting. I'm pretty sure i'm going to get her in the air and try to adjust it this weekend. Overall it doesn't bother me that it whistles. It mostly bothers me that it whistles all the time around 2.5-3k RPM.
Has putzing about, spirited driving, as well as some tach sweeps in there.
[ame="http://www.youtube.com/watch?v=1B-xTn0EFAA"]Going About - Vortech MaxFlow Race Blow-Off Valve - YouTube[/ame]
The Following User Says Thank You to F1point4 For This Useful Post:
ft86me (10-08-2013)
Old 10-08-2013, 02:11 AM   #125
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by F1point4 View Post
Going about
thank you again good sir ! so the blow off sounds amazing! just the high pitch whisltling at the mark you're talking about is pretty damn loud haha. I can see why the adjustments will be made. let us know how it goes
as for me, at work i tightened it 1 full 360 degree turn and another half. Put the vacuum reader on it and at around 6 it still opens and at 10 it looks fully open. while no vacuum the valve is completely closed sooo looks like I may be good, but my car may need more vacuum in order for it to blow off so it may not blow off as much since I tightened it. I get my car back thursday. well HOPEFULLY. soon after I will do the install with the setting on the valve I have now.
Old 10-08-2013, 11:57 PM   #126
Sniper2606
Sniper2606's Avatar
Thats one hefty price tag considering we put out $4k on the system....
Sniper2606 is offline   Reply With Quote
vortech pissing bov, wastegate option?
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
Tial Q Blow off valve Gen Engine, Exhaust, Bolt-Ons 1 11-01-2013 08:34 PM
**Visconti Tuning Vortech ProCharger Spring Blow-Out Sale** Rich@ViscontiTuning Forced Induction 133 05-10-2013 01:31 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
