Old 01-05-2012, 05:22 PM   #309
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Originally Posted by arghx7 View Post
I would be surprised if the intake ports would flow above the stock red line. If you port it out there is a potential for driveability issues due to a lack of charge motion and combustion instability. It's hard to say for sure though, so somebody will have to get in there and try.
ah but you are forgetting where AVCS and GDI come into play. So it isn't as bad as a motor without cam phasing and solely port injection (or ever worse, carb).
Homemade WRX is offline   Reply With Quote
Old 01-05-2012, 10:41 PM   #310
arghx7
Drives: car
GDI engines are more sensitive to intake port shape because they rely heavily on charge motion for mixture formation (unless it is a spray-guided combustion system like BMW uses). When you increase the coefficient of flow you decrease the tumble ratio, reducing combustion stability. That's a fundamental problem in design of a GDI system.
You have PM.
Old 01-06-2012, 01:01 AM   #311
NastyNate
Drives: 05 MazdaSpeed Miata
Originally Posted by miata View Post
I like naturally aspirated engines because turbo will die when the car is out of warranty. All snails die. I would have been happier with a 1.8L. 200hp engine.
That's not a bad thing. It gives you an excuse to put a better turbo on, which needs better ems, stickier tires, better brakes. Sounds like forced incentive to me.
Fast in the straights is for everyone else. Fast in the corners is for me.
NastyNate is offline   Reply With Quote
Old 01-06-2012, 12:35 PM   #312
Homemade WRX
You have PM.
Yes, that is very true but also why were are seeing GDI pistons resembling diesel pistons more and more. I'm glad that most have changed from chasing swirl (early days) and are aiming for tumble as swirl by nature will for fuel towards the cylinder wall/away from the center of chamber, opposite of what you want to do.
As I'm sure you know, the more focused the area for combustion, the better it'll be
I think the same way, though I would have ditched the stock turbo before it failed
Old 02-02-2012, 03:59 AM   #313
Driver
Drives: GTE
tl;dr but im glad its NA for same reasons in OP. so ya cheers. although toyota's last 4cyl turbo was... ahhhh just simply great. i'm excited for something new though.
Driver is offline   Reply With Quote
Old 03-23-2012, 11:24 AM   #314
racerkyo
XIII
Drives: 98 Supra na auto
I'm fine with it. The car was made NA for gas mileage purpose which is nice for daily driver
racerkyo is offline   Reply With Quote
Old 03-23-2012, 01:22 PM   #315
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
If they wen't with a 1.6T, they could theoretically get better mpg than the NA. Just look at the 1.6T that Hyundai designed for the Veloster Turbo.
tranzformer is offline   Reply With Quote
Old 03-23-2012, 03:22 PM   #316
NERO
Drives: 2012 Honda Ruckus
Originally Posted by Levi View Post
Yes 200 PS is little, so I'll be getting 250 PS with NA mods, surely an engine kit.
I think that's going to be difficult without a turbo. Can it be done, yes, but you will more thn likely have to get every bolt on known to man. I'm going to start with the normal, intake, full exhaust and a tune and see where that lands me. Then I'm going in the motor and throwing a turbo underneath it.
NERO is offline   Reply With Quote
Old 03-23-2012, 06:42 PM   #317
Levi
Drives: Toyota
250 PS with increased capacity, forged internals, race exhaust and all this is possible. ITB would be even better.
Levi is offline   Reply With Quote
Old 03-23-2012, 07:12 PM   #318
Capt Canuck
Drives: BMW E36 323is
Erm no. It was made NA to provide a responsive, sporty feel. If they wanted 200bhp and mpg it'd be a turbo.
Capt Canuck is offline   Reply With Quote
Old 03-23-2012, 07:59 PM   #319
dabocx
dabocx's Avatar
Drives: Scion FRS
Some one needs to make ITBs for this car, though the thought of tuning it is somewhat disturbing >_>
dabocx is offline   Reply With Quote
Old 03-26-2012, 05:12 AM   #320
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Very happy the motor is NA...I like higher revving, smaller displacement NA motors.
I've had both a '90 Integra RS and 98' Camaro V6 as 'track' cars (gutted but with untouched stock motors - other than custom intake and exhausts) and definitely loved driving Integra way more even though it was just as fast as the Camaro and not to mention cheaper on consumables (tires and brake pads). The Camaro was very insane in the braking department though; awesome brakes with Hawk HP+ pads and Brembo blanks riding on Nitto NT-555 RII that would just throw you forward and loose speed so fast it was nearly mind boggling.
That's the one thing the Camaro could do better than the Integra...brake! But overall the ~2340lb with full tank, 130hp/121 lbft, 1/4 mile in 15.798sec @ 86.82mph Integra RS just felt way more alive and fun than the ~3200lb, 200hp/225lbft, 1/4 mile in 15.767sec @ 87.27mph Camaro. It also probably has something to do with the ~8lb flywheel in the integra that made it so much fun as well...that was probably the best thing done to it - increasing it's acceleration performance, throttle response, and shifting at the same time.
Weight is the big killer for the Camaro - it just can't change direction quick enough even when loosing a couple hundred pounds over stock and riding on Koni adjustable shocks with massive F/R Hotchkis hollow anti-roll bars and having the rear suspension located with spherical ball end race arms and panhard bar. The car was neutral and pointed in well...it just was so slow at doing so compared to the Integra. The Integra just felt like it could run circles around the Camaro in the handling department, both at Autocross Evolution school/local evolution like practice event and on track even though both could equally steady state corner and pull G's as well as the Corvette Z06s and Elises (though could in no way keep up on track due to stock motor power).
My co-worker let me be the first to drive his turbo'd civic since I gave him an oil-cooler kit I originally purchased for my Tacoma when I had bought a supercharger kit for it. It was fun and really put a smile on my face (the push into the seat from acceleration and the BOV sound never get old either!) but I just don't like the maintenance/reliability aspect of a turbo compared to N/A for track use with a DD based car. I also like the screaming motor and instantaneous throttle/directional response from the slightest pressure change of the right foot that a nicely setup high revving NA motor car gives.
Hopefully the FR-S comes close to what I felt with my Integra: the FR-S will rev higher and have noticeably more power, but it also is over 400lbs heavier, and weight is ALWAYS an enemy I'm looking to defeat...
Speaking of high output motors, how does a normally aspirated 3.0 Liter V8 that revs to 10,500 rpms and makes ~470hp/~295lbft grab ya? It's the Hartley H1V8 motor used in the Ariel Atom 500...
Too bad that just the motor costs more than the most expensive BRZ model and it is not really designed for longevity in a DD production car... still a sweet motor (but not 1.5L BRM V16 sweet that makes any V8 cower in fear by it's growl while simultaneously wailing like the F1 motor it is past 12000 rpm!)
Vracer111 is offline   Reply With Quote
Old 03-26-2012, 09:43 AM   #321
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i have spent 3 years taking a 115hp car to autocross and time attacks
ive spent 3 years after that taking a 166hp car to autocross and time attacks
i'll be very happy with a 200hp car
Old 03-26-2012, 11:04 AM   #322
Pakjk89
Drives: 2010 VW GTI
Coming from a GTI that gets 200 hp with a turbo, I am excited to get 200 hp without the added turbo lag, although I'll miss the torque.
Pakjk89 is offline   Reply With Quote
Happy Thanksgiving!!! S2KtoFT86 Scion FR-S / Toyota 86 GT86 General Forum 11 11-27-2010 07:01 AM
Happy Holidays, all White Comet Off-Topic Lounge [WARNING: NO POLITICS] 4 02-12-2010 08:45 AM
