Old 10-02-2013, 01:03 PM   #155
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by mrlewistan View Post
anyone know if this monster will run well on the dr400hd2?
http://www.sandisk.com/products/memo...?capacity=64GB
My DR400 hates any card (all are class 10) over 16gb. I have 2 different 32GB cards and when the device powers on it just cycles over and over and never starts recording. The 16GB card, it just boots right up and starts recording.
Oh well.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
mrlewistan (10-02-2013)
Old 10-04-2013, 03:33 AM   #156
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
hey guys, i have a quick question.
lets say ive installed the dash cam into my car. followed this DIY exactly. how can i install the exact same camera into the rear of my car? do i have to tap into more fuses again and get another power magic box? or can i just tap the new camera into the magic box? thanks guys
Dispect is offline   Reply With Quote
Old 10-04-2013, 08:32 AM   #157
rbizzle004
You would need another Power Magic Box and you would want to use a different fuse if possible.
rbizzle004 is offline   Reply With Quote
Old 10-04-2013, 08:41 AM   #158
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Or you can buy dual cigar adapter to attach it
Sent from my Galaxy Nexus using Tapatalk 2
Old 10-04-2013, 11:39 AM   #159
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
That is, if you don't want the "parking" feature which is one of its main features with these units. Would be a waste if you bought a $300+ BlackVue and not use all of its features...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 10-04-2013, 11:49 AM   #160
cnk
Drives: '13 DGM BRZ Limited
The output on the Power Magic box is a cigarette lighter receptacle so you could use a splitter. Just need to make sure the overall power draw doesn't exceed the unit's output.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 4
Old 10-04-2013, 12:07 PM   #161
rishi
rishi's Avatar
Drives: FR-S Series 10 #0059
Since the guys before me have pretty much answered your question, I'll give you an alternative by suggesting the DR550GW: it's the same great camera as the DR500GW, but it also includes a secondary 720p camera you can place in your rear windshield. The second cam is smaller and only needs a single wire to connect to the base camera, no extra power required - and all the recording and streaming is done by the base station, so you don't need to set up a second device, you don't need a splitter for your Power Magic, and you don't need a second SD card.
rishi is offline   Reply With Quote
Old 10-04-2013, 01:05 PM   #162
DaJo
FT86Club Vancouver
DaJo's Avatar
I don't see how that works though. Cigar lighter is not constant power when the car is off; why would you need the Power Magic Box then?
2000 MR-S 5MT
2010-2012
Old 10-04-2013, 01:12 PM   #163
cnk
It doesn't sound like you understand how the Power Magic box is hooked up. You have input wires that come from the fuse box into the PM box. The output wire to provide power to devices is a cigarette lighter receptacle, as in, that's the connector coming out of the PM. If that doesn't make sense, go take a look at the DIY on the PM/camera installation for pics and it will make sense. You're not getting power from the cigarette lighter in the center console or in the glove box. You're getting power from the PM box via a cigarette lighter receptacle.
The Following 2 Users Say Thank You to cnk For This Useful Post:
DaJo (10-04-2013), zc06_kisstherain (10-04-2013)
Old 10-04-2013, 01:26 PM   #164
DaJo
FT86Club Vancouver
DaJo's Avatar
Nvm I just refreshed my memory. Lol My bad. Had it for a year and already forgot how it was wired.
2000 MR-S 5MT
2010-2012
Old 10-04-2013, 01:33 PM   #165
zc06_kisstherain
Drives: SWP BRZ
Old 10-05-2013, 11:20 AM   #166
Dispect
Dispect's Avatar
Guys I need help. Just finished wiring it last night. I turned my car off and I think it went into parking mode. This morning I went into my car to turn it on, it didn't go into normal mode automatically. I had to press the button. What could be the problem? And now when I turn my car off, it doesn't go into parking mode.
Old 10-06-2013, 10:40 AM   #167
zc06_kisstherain
Drives: SWP BRZ
it takes 2-5min to go into parking mode.
same goes for normal mode from parking mode.
Old 12-10-2013, 12:22 AM   #168
ChiefG
Skeptic
ChiefG's Avatar
Drives: 2013 FR-S Ultramarine 6A
Lightbulb Power Option Using "Option Connector"
First off, major to F1point4 for this awesome DIY. People like you make this forum great, and I can appreciate the time and effort that went into photographing your DYI and doing the write-up.
I'm pretty much sold on this cam and the power-magic unit.
During my install of my aftermarket head unit and back-up cam, while soaking up all I could from the forum, I came across a post about the "option connector." (and now I can't find the post )
The option connector is an unused white connector behind the radio toward the passenger (LH drive vehicles) side. That connector contains a ground, 1 accessory-fused socket, and 1 battery-fused socket. There are a couple others, but you'll only be interested in those three. I think there's even a guy on the forum who can supply you with a connector and harness to plug in to that option connector. A big plus is that it is very near the glove compartment. If you use this connector you can save a LOT of work, not to mention you won't have to use an Add-A-Circuit or go anywhere near the fuse box or the driver's side and you won't be left with a fuse box cover dangling open or strapped up with wire ties.
I plan to put the Power Magic unit under the dash mounted to the roof of the glove compartment, or somewhere in the vicinity. It will be in an accessible spot where I can operate the switch if necessary. Using that connector, the wiring run will be easier as well.
Here's a photo (below) of the option connector. It's the white 6-pin connector in the lower-right center of the picture. Use a test light to find the accessory and battery-fused circuits. If you want, put a 1-amp inline fuse in your accessory and battery leads.
If you use this option connector to tap power, you can run your cam cables under the headliner, down the passenger side A-pillar, and behind the dash. The dash panels and radio are very easy to remove. Gently pry the dash panel and radio surround panel out from the bottom. Protect the plastic with a piece of paper and use a panel removal tool, not a screwdriver. Four bolts hold the radio in. You'll need a 10mm socket and extension. Piece of cake.
You should be able to find some narrow crimp-on bayonet connectors that will plug in to the option connector.
There's some good info here: http://ae64.com/Rear-camera-16p-operation.htm
Here's SSVXdc's picture of the connector:
"All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. " - Red Green
ChiefG is offline   Reply With Quote
The Following User Says Thank You to ChiefG For This Useful Post:
voyager2285 (01-02-2014)
blackvue, dashcam, diy, dr400g-hd, power magic pro
Dash Cam Installation (BlackVue DR400G-HD) DarrenDriven DIY (Do-It-Yourself) Guides 93 05-01-2018 09:54 PM
R-Magic & Rasty build 86 toxicdrift FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 08-10-2012 12:24 AM
R Magic Parts List quik1987 Engine, Exhaust, Transmission 9 07-30-2012 01:55 PM
R-Magic Demo Car (Exhaust video too!) ttknf Engine, Exhaust, Transmission 5 06-06-2012 02:20 AM
