Old 10-03-2013, 06:10 PM   #15
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I had Opticoat done on my car. I keep in in a car port, not enclosed in a garage. I can tell you my experience with it. I've had it on for about 4-5 months already.
AMA.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 10-03-2013, 10:23 PM   #16
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Originally Posted by Kwisak View Post
Ive been doing as much as i can with not doing circler motions, using two buckets, and going with a light touch on the drying with clean microfiber towels, but i am still getting some of the small scratches here and there
You're going to get swirl marks no matter what, anything that touches the paint will cause swirl marks unless there's a lubrication in between, even then eventually swirl marks will occur once the lubrication runs out. Even driving in the rain causes swirl marks. (Dirty water hitting your paint at high speed from the car in front of you, etc etc)
You can't hide from swirl marks, all you can do is cover them up or just buff them out.
Old 10-03-2013, 10:25 PM   #17
dem00n
dem00n's Avatar
Drives: Scion FRS
Originally Posted by cnk View Post
I dry using a blower. With the OC on, the water just sheets right off. The only time a microfiber cloth touches the paint is if I'm using a quick detailer in between washes or to remove bugs or bird poop.
Don't remove bird poop with towels, honestly just use your hands. Sometimes bird poop has rough solid debris that are really like rocks and wiping them down with a cloth will cause horrible scratches. I see it all the time and have done it myself.
It sounds disgusting but just spray it with lots of spray wax or water and wipe softly with your fingers.
The Following User Says Thank You to dem00n For This Useful Post:
hanabie (10-05-2013)
Old 10-03-2013, 10:37 PM   #18
cnk
Drives: '13 DGM BRZ Limited
I don't wipe it off. You spray detail spray, let it soak, use a microfiber towel and remove it. You don't use a wiping motion. If you've soaked it enough, just dabbing the poop will cause it to stick to the towel and come right off. Use a clean section for each dab. I've never had a problem doing it this way.
If you chose to use your fingers, make sure you wash your hands afterwards. The amount of bacteria in bird poop is pretty nasty.
Old 10-03-2013, 10:38 PM   #19
dem00n
dem00n's Avatar
Drives: Scion FRS
Its the removing part that causes accidents as well. Shit happens, i just play it safe.
Do what you like.
Old 10-05-2013, 02:45 PM   #20
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
agreed^^ let it soaked and remove it
hanabie is offline   Reply With Quote
Old 10-24-2013, 08:05 PM   #21
David-Fermani.com
David-Fermani.com's Avatar
Drives: Dirty
This is pretty far fetched. Rain water causing swirls? Maybe if you constantly follow people in the rain on dirt roads??
Swirls occur as a result of heavy abrasives getting trapped between the vehicle surface and the object rubbing against the paint when proper lubrication/care isn't utilized. The cars that I maintain don't get swirled up. If anything the finish isn't as clearly polished or fresh as it initially was, but not for years. No swirls. My wife's black T&C minivan was Opti-Coated over 4 years ago and doesn't have any swirls. The flake just isn't popping/sparkling like it was when it was fresh. (but is still beading like new).
Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
Official Optimum Opti-Coat PRO Application Specialist for Metro Detroit
David-Fermani.com is offline   Reply With Quote
Old 10-24-2013, 09:42 PM   #22
dem00n
dem00n's Avatar
Drives: Scion FRS
Dirty rain water hitting paint at 50 MPH? Going to cause some swirl marks.
Old 10-24-2013, 11:16 PM   #23
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I think EXO is likely as durable as opti coat and applies in a similar manner. Very hydrophobic as well.
Old 10-25-2013, 05:34 PM   #24
David-Fermani.com
Drives: Dirty
I tried searching this topic but came up empty. Perhaps you could shed some kind of scientific evidence to support this? This type of thinking goes hand in hand with the schoolof thought that recycled water scratches your car too? Just not the case. Ifthis was then brand new cars would be riddled with swirls as they get traileredfrom the manufacturing plant to the dealership. Or maybe because the vehicle is higher off the ground the dirty rain doesn't cause swirls? I’ve been putting 4000-5000 miles per month on my company cars for thelast 10 years and do quite a bit of traveling in heavy rain and I don’t haveany swirls?
The Following User Says Thank You to David-Fermani.com For This Useful Post:
Paul_S (09-21-2014)
Old 10-25-2013, 05:41 PM   #25
dem00n
dem00n's Avatar
Drives: Scion FRS
I can't even reply to this.
I'm going to go take a nap.
David-Fermani.com (10-25-2013)
Old 11-06-2013, 02:20 AM   #26
fitcious
I have 2500 miles on my car...it is leased for four years. I plan to buy it after the lease period...but obviously lots can happen in the next four years...so I wouldn't want to invest too much in the car if the unfortunate happens, such as accident or theft.
Would it be worth it for me to add opti coat in four years or will the paint be so crappy that it wouldn't be worth it or that I need to hire a detailed to clean it up and then do the opti coat?
Car is parked in a car port majority of the time. Thanks
fitcious is offline   Reply With Quote
Old 09-14-2014, 06:43 AM   #27
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
OC does not absolve you from proper washing/drying techniques. It's just like an additional protective clear coat on top of your clear coat. It can and will still scratch. You can buff if out, but that will also remove some of the OC. I believe the manufacturer has stated in some of the detailing forums that you can probably get away with buffing it once, but any more and OC will most likely have to be reapplied.
I thought so, that if you end up putting swirls in your OptiCoat you would end up having to buff it out, and therefore remove the OptiCoat which you spent $$$ on.
But the other side to it is that if you have proper washing techinques, it would be very hard to swirl the OptiCoat......so they say.
CyberFormula is offline   Reply With Quote
Old 09-14-2014, 05:54 PM   #28
Ec1990
Drives: '14 BRZ
Opti-Coat or Opti-Gloss as it is now provides increased scratch protection. Before being applied your paint should be in a condition of which you deem acceptable. Ideally before applying either the customer should know how to wash without inducing swirls or take it to a detailer for maintenance washes. Cars should not require more than one to two full paint corrections with polishing as required every few years.
Also important to pass on to the dealership to not touch the car.
Ec1990 is offline   Reply With Quote
BeSpoke worth it? garsh0p Electronics | Audio | NAV | Infotainment 8 06-19-2012 05:01 AM
How much is RWD worth it? mankarn86 Scion FR-S / Toyota 86 GT86 General Forum 53 04-24-2012 06:15 PM
What's this worth? Sport-Tech Other Vehicles & General Automotive Discussions 5 04-12-2012 11:21 AM
A Used BMW 330ci @ 10k worth my time ? MRZ415 Other Vehicles & General Automotive Discussions 3 03-12-2012 04:36 PM
worth a shot pkptd447 Off-Topic Lounge [WARNING: NO POLITICS] 1 12-23-2011 06:01 PM
