Old 05-14-2013, 08:27 AM   #29
brufleth
Drives: 2007 WRX
Originally Posted by Floggin Tires View Post
Also to note Turbos:
Lag
= Delay of boost.
When throttle position changes to the time of actual noticeable boost
when the engine is at an RPM that boost can be made.
Example:
Boost set at 10psi.
Cruising, at 4500 RPMs where 10psi can be made.
For now, no vacuum, no boost. Were just cruising.
Floor it.
Lag is the time it takes from here to build boost.
Boost threshold= The lowest RPM an engine can begin making boost.
Example:
Rolling 5mph 800 RPMs
Floor it.
Boost threshold is from here to the lowest RPM at which boost starts.
Boost threshold is often confused with lag.
I'm glad to actually see someone explaining this so well. I see so many people talking about lag on a dyno where the car is running pretty much steady state. As someone who works with jet engines I'm super sensitive to power lag. People really need to consider the responsiveness of a given setup and not just the steady state high end power output.
brufleth is offline   Reply With Quote
The Following User Says Thank You to brufleth For This Useful Post:
Floggin Tires (10-03-2013)
Old 10-03-2013, 02:14 PM   #30
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
I think these cars suffer most in the low RPM range.
I myself hate that first gear is so weak.
So this being the case, a turbo would most likely be the best option to get lower end power?
This car is great on the twisties but my goal is to make Mustangs feel the shame at stop lights.
That being said, i've found most turbo kits are cheaper, but I think that's the price without all the other mods that go into it.
For the SC like Vortech it's petty much plug n play. For the turbos, are we needing new fuel delivery systems, headers (obviously) and other systems?
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 10-03-2013, 02:29 PM   #31
sw20kosh
Drives: 2013 Black FR-S
If all you are concerned about is bumping up low end power, then get a tiny turbo or twin screw sc.
Old 10-03-2013, 02:49 PM   #32
AVOturboworld
The need for fuel upgrades is in direct relation to the amount of power made. The FI system that creates that power doesn't affect that need. The only variance is that FI systems with more parasitic loss at the engine will need more fuel to reach certain at-the-wheel power goals.
Almost all turbocharger systems come with a header as part of the kit. It's the s/c systems that don't, and are thus the ones that most commonly upgrade their headers. All FI systems benefit from a freer flowing exhaust system.
If a turbocharger kit *needs* other upgrades besides the kit itself, it's because it's exceeded the limits of particular OEM equipment - such as the fueling or clutch. If that's an issue, simply make sure to buy a FI system that doesn't exceed those limits, at least in base configuration.
The Following User Says Thank You to AVOturboworld For This Useful Post:
mitosis (10-04-2013)
Old 10-03-2013, 04:13 PM   #33
SillySaxon
SillySaxon's Avatar
Not just low end, but i want a system which will give me the greatest low end boost. Since I live in an area where I'm racing from stoplight to stoplight instead of up a mountain trail my concern right now is quick, immediate, straightline power so that big muscle car junkies can gawk at my little "cracker jack box" import beating them.
Good info. That said, what all would we need to purchase extra for your AVO Stage 1 bolt on kit if we are completely stock beforehand?
Old 10-03-2013, 04:31 PM   #34
AVOturboworld
Whatever BOV of choice you want to run with, and I'd suggest a high flow panel filter.
Old 10-03-2013, 05:06 PM   #35
Sonolin
If you want a chance of beating any of the modern muscle cars, you'll probably want to run a turbo with fairly high boost (or big turbo with low-medium boost) and target ~350-400 whp+
Its not going to be easy getting these cars to beat a new v8 mustang in a straight line, and you'll need better tires and suspension to give it a hope to stick. If you notice most cars with F/I are actually in the 13-14s 1/4 mile times which isn't very fast for 1/4.
These cars just seem really hard to launch even with sticky tires.
Or just give up on the silly notion. This car was made for curves why do you need to prove yourself to a v8 mustang which was built for going as fast as possible for the money?
Sonolin is offline   Reply With Quote
Old 10-03-2013, 05:43 PM   #36
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Originally Posted by jamesm View Post
Centrifugal supercharger are a bastardization of the two, and IMHO, not worth consideration. They are mechanically driven turbos for all intents and purposes. So, you get boost that ramps up as RPM's rise. It's basically the worst of both worlds: limited efficiency, parasitic loss, etc. without the benefits down low of a PD blower. The upside is that they're generally easy to install and package.
In the end it comes down to what you prefer. It's very subjective.
While you did state it was your opinion, there are other very noteworthy parts to consider.
Centrifugals may seem to you like it is not the best option, however a great deal of the equation is being skipped over entirely.
Centrifugal superchargers have many of the benefits of a turbo, without the enormous heat concerns of a turbo. If you don't generate the heat in the first place, you don't have to go to great lengths to get rid of it. Plus, without the charge cooler being a safety precaution, it becomes an additional add-on for increased power gains, with IATs coming in relatively close to ambient on a consistent, stable basis in most applications (and we are not just talking about iced down setups on a perfectly controlled dyno situation). In addition, while a centrifugal compressor may have some parasitic loss due to being belt driven, the losses are drastically less than any positive displacement unit. The amount of horsepower it takes to spin a Vortech is nominal compared to any roots or twin-screw. This is one of the main reasons we have display units with drive pulleys on them at all the shows and events we attend. People comment all the time once they see (and feel) first hand that the effort to turn the compressor is quite low, practically free spinning...especially compared to any other supercharger.
Adiabatic efficiency also comes strongly into play when comparing types of superchargers. No positive displacement compressor can ever come close to the efficiency of a centrifugal, especially the 78% (or higher) efficiency of the current line of Vortech units. Most pd blowers come in at an abysmal 50-60% efficiency, which comes right back to heat and parasitic loss. With a 50% adiabatic efficiency, literally HALF of the work going into turning the compressor is being converted directly into heat, and (as everyone knows) cooler air makes more power.
Other things to consider are possibility CARB approval, (in some cases) underhood packaging, and (as stated) ease of installation.
The options cannot be so quickly dismissed. They all have their merits and detractors.
Brian@Vortech is offline   Reply With Quote
The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post:
jamesm (10-03-2013), mitosis (10-04-2013)
Old 10-03-2013, 06:50 PM   #37
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Originally Posted by NomoreNA View Post
Twin screw = low end torque, centri = linear power/torque, single turbo = big power on the top end "high rpms", twin turbo = worthless on our platform. That covers the basics
Why is a twin turbo worthless on our platform? From what I've read about boxer engines, wouldn't a twin scroll design provide the greatest efficiency with minimal lag while retaining good top end power?
I'm not the most knowledgeable person when it comes to auto mechanics, so I'm not saying you're wrong. I guess what I'm asking is, can you explain why twin turbos are worthless on our platform?
Hanni_0176 is offline   Reply With Quote
The Following User Says Thank You to Hanni_0176 For This Useful Post:
Ammonia (10-03-2013)
Old 10-03-2013, 06:52 PM   #38
xjohnx
Grip>Slip
xjohnx's Avatar
twin turbo!=twin scoll
Old 10-03-2013, 07:14 PM   #39
Hanni_0176
Hanni_0176's Avatar
Well, a twin scroll is a twin turbo, but not all twin turbo designs are twin scrolls.
Old 10-03-2013, 07:28 PM   #40
xjohnx
Grip>Slip
xjohnx's Avatar
Not exactly. Twin turbo means 2 of the exact same sized turbos, no?
I think you're thinking more of a bi-turbo or sequential type setup (a smaller turbo for low lag, and a bigger one for high flow, which in my understanding is the same concept in which twin scrolls operate.)
Old 10-03-2013, 07:51 PM   #41
Frs300
Frs300's Avatar
Drives: Pile of junk
Twin scroll isn't twin turbo..twin scroll has two holes that blow air over the exhaust wheel. One is open at low rpms to increase air velocity, at higher rpms second one opens up to help out the top end. Twin scrolls usually spool at low rpms and are tq monsters.
Frs300 is offline   Reply With Quote
The Following 2 Users Say Thank You to Frs300 For This Useful Post:
mitosis (10-04-2013), Team STILLEN (10-14-2013)
Old 10-03-2013, 07:53 PM   #42
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
I remember seeing two tiny turbos on a 3000gt, they made my turbo look beefy hahaha
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline   Reply With Quote
JDL 5130 Twin Scroll Turbo Kit JDLAutoDesign Forced Induction 390 05-27-2021 12:14 AM
Twin Turbo FR-S/BRZ? KidWonder Scion FR-S / Toyota 86 GT86 General Forum 44 06-27-2014 01:22 AM
Twin Turbo kit? enjoi23 Forced Induction 15 12-03-2012 07:53 PM
Silver FR-S sunset photos and... Twin turbo mod. CSSM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 06-18-2012 01:37 AM
