#16647 |
It's the Mad Cow
Think I am going to either turn my Rota's into Track only rims or just sell them along with the FR-S rims and buy something a little different.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#16648 |
Drives: Mazdarati
Friday had the FR-S in for its 7500 mile service at Autonation Toyota, left the mods in-place including the UniChip..............they could care less and are very mod friendly.
Even discussed the intake I have and how touchy the MAF is with aluminum tube intakes. Seems the MAF dose not like the aluminum versions and his theory is the aluminum heat-soaks and will not allow the MAF to give correct readings. Most of the CEL issues he has seen are on aluminum intakes.......I do pop the rich CEL once in a while but figured it was from the MAF being in turbulent / wrong sized tubing....I looked at the Data logs later on and found when the intake readings show over 140 degree F is when the rich condition pops the CEL when the LTFT and STFT go to -25 to -30%. This lead me to experiment, grabbed two of my 500 watt computer chillers (peltier effect chips http://en.wikipedia.org/wiki/Thermoe...Peltier_effect ) and attached them to the intake tube right next to the MAF, forward voltage cooled the tube, reverse voltage made it hot.....drove around while heating and when I got to 140 F I could get the STF and LFT trims to show -20% or more, cooling it kept them within 7% of 0.........while standing still at idle I got the benifit of under-hood temperatures making it worse......seems to be some reality to his theory. As I gave away my stock intake I decided to order the TRD intake......should be here this week. Before anyone gets the bright idea that adding a peltier effect chip to an intake to cool the incoming air for more HP, don't bother. 1000 watts of chips only dropped the intake temp reading 5 degrees F, you need to drop 10 degrees to get 1% HP increase.....746 watts is 1 HP, so I did not even come close to adding what I was using up......and that 1000 watts at 14.3 volts is 69.93007 amps (4 gauge wire to the chips). Also while talking with the service manager he mentioned that the Subaru BRZ is getting a "factory supercharger kit" soon, but this kit will not be available for the Toyota / Scion dealers to sell......
#16649 | |
I have your stock intake technically sitting in my living room. I only modded the snorkel which is on my car so let me know if you need that setup back. And as far as the brz supercharger kit from subaru. Lolz. If I had a dime for everytime a sales or service guy mentioned a rumor to a forum member about fi on these cars id be able to afford fi on my car. Lol Sent from a Motorola DynaTAC 8000X |
| The Following User Says Thank You to Yruyur For This Useful Post: | IceFyre13th (09-30-2013) |
#16650 | |
Drives: Mazdarati
The Intake I am running now is my own design, similar to the FA Club one I had on first but larger tubes with a flow straightener just in front of the MAF sensor location. The MAF location has the tubing the exact diameter as the factory tube.......but now that I know the heat-soak information is valid on the FR-S it will be used on my other project vehicle (one less thing to build for it). BTW, you still looking to get a Drone........the AR Drone 2 I flew at the coffee meet is taking up space...... The new one is almost built, just got the new flight controller in for it.
| The Following User Says Thank You to IceFyre13th For This Useful Post: | Yruyur (09-30-2013) |
#16651 |
It's the Mad Cow
Well I bought a new style of Rim... lets see what happens.
| The Following 5 Users Say Thank You to Cross For This Useful Post: | brenesk91 (09-30-2013), captain_jack (09-30-2013), EZWood (10-01-2013), SMOKETREES (09-30-2013), Yruyur (09-30-2013) |
#16652 | |
Drives: Monkey-butt red FR-S
MotoEast ECUTEK tune; PPE Engineering intake, EL headers, overpipe, front pipe w/ hi-flow cat, midpipe, and single exit axle-back; GC camber plates; GC coilovers with Koni Sport (r) and Koni 8612 (f); Eibach front springs and Hypercoil rear springs; Hotchkis rear sway bar; Eibach front sway bar; Whiteline positive traction sub-frame inserts and differential support outrigger bushings; 17x9 Enkei RPF1 w/ 245 Hankooks.
| The Following User Says Thank You to Evil86 For This Useful Post: | Cross (09-30-2013) |
#16653 | |
It's the Mad Cow
#16654 | |
Drives: SWP BRZ 6MT
Sent from my GS4. |
#16655 | |
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson
-2013 Scion Raven FR-S -2009 Honda Green/Black CBR600RR |
| The Following User Says Thank You to Sivtec For This Useful Post: | Cross (09-30-2013) |
#16656 | |
It's the Mad Cow
I agree it really does
#16657 | |
John 1:12
Drives: Pearl white BRZ Limited
Sorry. Didn't see the above posts until I submitted mine. |
| The Following User Says Thank You to 40flash For This Useful Post: | Cross (09-30-2013) |
#16659 |
Drives: GBS Limited 6MT
Thanks for the tips. I'll likely sign up for that event at AMP on the 13th. I have been looking for a reasonably close event this weekend and found a few other upcoming events so I figured I'd make a list.
10/13 Autocross AMP 10/19 Autocross Tempe Diablo Stadium (Porsche Club) 10/19 HPDE AMP (ProAutoSports) 10/19-20 Autocross Marana Regional Airport 10/26 HPDE AMP (Porsche Club) I don't know how open the porsche club is to other makes, but I'm interested in their autocross and track day. |
#16660 |
I know some of you engineering types are gonna love this kickstarter project
Its based in TEMPE as well so that would be cool to become a tester, Pretty bad ass http://www.kickstarter.com/projects/...=home_location Not as simple a clean of a design as Michelins airless tire design put pretty cool either way. |
| The Following User Says Thank You to Yruyur For This Useful Post: | jeffsides (10-01-2013) |
| Tags |
| arizona, fr-s, mesa, phoenix, scion, tucson, we need a subforum |
| Arizona Bill 'could' criminalize Internet Trolls | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 12-30-2013 02:54 PM |
| Accessories page for Canadian BRZ owners | percyng | CANADA | 1 | 06-15-2012 07:27 PM |
| FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 03:12 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
