Old 09-30-2013, 01:21 AM   #15
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by gdrider77 View Post
I thought i was having a fuel starvation issue too. right at 3500 rpm, if i have the pedal to the floor, car just bogs down and starts jerking. 3-6th super noticeable. I was hoping it was just a fuel thing, but just filled up and still same issue, car is barely driveable.
Logs from 1/4 tank.
https://www.dropbox.com/s/fesnlpg5xb...uartertank.zip
Logs after full tank.
https://www.dropbox.com/s/uhynp1se4y3znsq/fulltank.zip
Do you have an aftermarket intake?
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 09-30-2013, 08:01 AM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Logs from 1/4 tank.
How is your AFR gauge in those situations? Do you see it climb 13-15? That sounds like one of my FP install issues. I can't open the logs at work, but yeah -5 is bad.
Here are my God awful logs before switching tuners... Notice the -5 knock events. Cruising, WOT, everywhere, didn't matter.
Old 10-01-2013, 02:24 PM   #17
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Got a new file in over the weekend. Still a tad of knock but much better. Knocked once over a two mile drive to work. at low rpms low throttle. Logs are attached. @mad_sb here is a pic of the IAM value resetting from .94 from before I cranked the key to .7 on start up.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-02-2013, 01:08 AM   #18
Z0rr0
Drives: 2013 Raven 6MT FR-S
can we not just post the .csv files? that would be a ton easier
Z0rr0 is offline   Reply With Quote
Old 10-02-2013, 02:45 PM   #19
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Yup.
Perrin
gdrider77 is offline   Reply With Quote
Old 10-02-2013, 02:47 PM   #20
gdrider77
gdrider77's Avatar
I will need to take a look. Here is the thing. I flashed back to the old tune, prior to my last one, and that issue is gone, so seems to be a tune issue? I will post logs of the "old" tune later today.
Old 10-02-2013, 03:43 PM   #21
Hawaiian
That guy
Hawaiian's Avatar
It might have something to do with your tune and intake combo.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 10-02-2013, 03:53 PM   #22
Sportsguy83
Drives: Limited BRZ
Site only accepts .zip, what people do is post a .csv, change the extension to .zip and then you download it, change it to .csv and it opens in your computer.
Might be, true but since his "old tune" does not show the behavior seems to be isolated to that specific tune.
Old 10-02-2013, 04:06 PM   #23
Hawaiian
That guy
Hawaiian's Avatar
True, it's somehing changed in the tune, but i had a similar issue in the past at a lower rpm. It was intake related, but only happened at wot, and caused the same issues. My tuner later tuned it out.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 10-02-2013, 04:09 PM   #24
gdrider77
gdrider77's Avatar
Exactly what i was thinking. I was really hoping it was a tune issue and not an engine, connection, etc.. issue. I went through all the engine double checking all my hoses, connections etc.
Everything looked solid and secure...
So my next thought was it was that wacky tune. Flashed back and sure enough, running much better.
I will post logs soon, but from what i saw running the old tune yesterday, my knock correction was at least only a -2 at the most. So a bit of an improvement.
Old 10-02-2013, 04:11 PM   #25
gdrider77
gdrider77's Avatar
Its weird, and something i dont notice all the time, especially since i dont really drive around WOT usually. Only noticed while doing the datalogs...
Got an appointment on Monday with my tuner, hopefully we can resolve all this, if not, its off to Toni at FA20 for a remote tune.
Old 10-02-2013, 04:45 PM   #26
Hawaiian
That guy
Hawaiian's Avatar
It will take a little bit for your tuner to work on it, but from what i recall it's an issue with the maf placement in aftermarket intakes. Under wot the fueling switches to open loop and floods the engine with way too much fuel (simplified answer). @mad_sb might be able to shed a little more light on it.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 10-02-2013, 05:40 PM   #27
gdrider77
gdrider77's Avatar
A little bit....what would you consider a little bit? My tuner has had my car for around 20 days total. Shouldnt that be enough time to work out any bugs and get it tuned properly? Or is this car just too new?
My tuner has actually said he doesnt really want to tune twins anymore after working on mine and a couple others...says they are just too hard to tune, and the software is a pain. Is the consensus that this is true? Or is my tuner maybe just not a good fit for me and my car?
Thoughts. Hope to not derail the topic too much.
Old 10-02-2013, 05:55 PM   #28
Ross
Drives: 85 corolla gts
Tuner is not a good fit for your car or any of the newer management systems. They are not a difficult car to tune, especially if you are not doing it remotely.
Ross is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
