| FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
#127 |
No one's really mentioned Ford motors, Duratec? Zetec? Older Escort motors? I know little about them but I'm sure they deserve mention... What about the MX-5 2.0 liter? Or the Skyactiv engines?
How about the Nissan S20 used in the C10/C110 Skylines and Fairlady Z 432? 2.0 straight six, twin cams, 24 valves, triple carbs producing 160hp and 130lb/ft. Sounds like pure sex! I feel like 1.6L engines are in another class but I wanted to give another vote for the 4A-GE blacktop; 165bhp out of a 20v 1.6L with factory ITB's and 11:1CR. Fun motor!
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#128 | |
Drives: '12 C63 P31, '23 GRC
Nobody has mentioned them because they're all inferior to Honda's engines. And the reason that the newer Honda VTEC engines don't have that Jekyll & Hyde personality is thus: -iVTEC engines include variable cam phasing, which smoothens out the switch from the small cam to the big cam -None of Honda/Acura's V6 engines are DOHC, and thus are incapable of having a small and big cam. You cannot do it with SOHC, since each bank of cylinders only has one camshaft. If the VTEC system from the NSX's DOHC V6 was applied to Honda's modern V6 engines (assuming they were DOHC) they would be making a lot more than the 280-320 hp they currently produce.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#129 | |
Honda motors go in everything from boats to planes and lawnmowers. I long for the day someone will make a better factory 2.0 than the F20C. |
| The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | Anthonytpt (10-01-2013), chaoskaze (12-30-2014), Dephective (10-01-2013), drewbot (09-18-2015), krayzie (05-22-2015) |
#130 | |
Drives: Honda S2000
#131 | |
Maybe my wording wasn't clear before but I was not implying that you needed DOHC so you could have a low cam and a high cam. You can have VTEC at work on a SOHC engine, but it's a mild application due to lack of adjustability.
#132 | |
Drives: Honda S2000
F20c 4-life! |
| The Following User Says Thank You to vangisback For This Useful Post: | WolfpackS2k (10-02-2013) |
#133 |
Drives: '06 AM V8V Coupe
You can certainly have multiple sets of both intake and exhaust cams on SOHC, but the problem with SOHC is that it's quite complicated to get the exhaust and intake lobes adjusting separately timing wise (phasing), so usually they don't. That's actually pretty significant, being able to advance the exhaust opening while retarding intake opening is how you cut overlap and thus make the engine run better at idle and such, and it's why variable lift systems are kind of rare: having just the ability to phase the cams already does a lot.
#134 | |
Drives: Scion FR-S/Toyota Yaris
I have one hill where the car literally stops accelerating at 4.2k in 3rd gear! That's the torque dip and no you don't need a dyno to notice it. The saving grace is it sounds like its fixable with a tune and header. I've yet to hear someone with a good tune and a good header ask for a return of the factory hole in the torque response. The torque dip is severe because this is an NA engine developed for the next decade. The header and tune just put this engine on a level playing field with engines developed last decade. I think other auto makers realize the new and upcoming regulations/red tape are forcing them to DIT for performance, yes even Honda.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#135 | |
Drives: '23 BRZ
| The Following User Says Thank You to ZDan For This Useful Post: | WolfpackS2k (10-02-2013) |
#136 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
#137 | |
Drives: 2013 Scion FR-S 10 Series MT
![]() I do see what you are getting at though, since most of my commute is flat. Still, why not start off in 2nd gear during that hill climb if it's that steep? Redlining in 2nd doesn't drop you down to 4.2k in 3rd... And I'm not advocating that the torque dip is a good thing, I was simply saying that I see people making such a big deal out of it all over the place on these forums, and that I don't think it's nearly as bad as it's made out to be. In terms of headers and a tune... well, I will definitely be modding my car in the future, and those two are just a few on a long list of stuff I want to do.
#138 | |
#139 | |
Registered you sir
Drives: 99 impreza coupe
[ame]http://youtu.be/Bch5B23_pu0[/ame] |
#140 | |
1. Computer screws up, smashes valve into the piston = bent valves. No cam profile can possibly do that. 2. All the kinetic energy you give the spring is lost, whereas with cams you get most of it back. This is quite a lot since you still have to open valves at part load. |
| New rumor: 1.6-liter turbocharged engine one year after initial introduction | Clode | Scion FR-S / Toyota 86 GT86 General Forum | 208 | 12-16-2016 07:14 PM |
| Frs not being produced in auto? | camelflage | Scion FR-S / Toyota 86 GT86 General Forum | 70 | 04-17-2013 08:50 AM |
| VR6 engines... | dem00n | Other Vehicles & General Automotive Discussions | 29 | 01-25-2013 01:41 AM |
| 100 hp/l NA engines | einzlr | Other Vehicles & General Automotive Discussions | 95 | 11-15-2012 07:55 PM |
| So you think you know engines? | Ryephile | Other Vehicles & General Automotive Discussions | 43 | 02-04-2012 03:49 AM |
