Old 08-01-2013, 05:09 PM   #15
Hanakuso
I have Ti brake shims for the Essex AP Racing kit but I haven't had the chance to test them out. This thread reminded me to go out and buy the temp strips or paint. Maybe for the streets I can test if they work by using shims only on 1 side.
Hanakuso is offline   Reply With Quote
Old 09-27-2013, 09:24 AM   #16
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Element Tuning View Post
Also I do believe street tires are harder on the brakes vs the slicks I run since you're traction limited and so your braking distances are extended.
Hmm, that makes sense. Good point. And corner entry speed is probably lower so you need to scrub more speed off during braking. I wonder if anyone has objective data on this.
2022 BRZ Build
2013 FR-S Build
Old 09-27-2013, 01:00 PM   #17
Hanakuso
Since you're in CA, I wouldn't worry too much about dust boots; I've been driving my s2k without boots since pretty much my first track day. It really becomes an issue when you live in an area where you have snow/salt, because that can get in between the piston and caliper, and start causing corrosion/chafing damage.
As you know, we both don't even have dust boots on our AP Sprint kit. The reason I bought Ti shims is because from what I know, reducing heat to the caliper area will help reduce the need for servicing them. I don't understand all the science but that's what I read. I know the shims aren't magic and it will only help a tad but it's still better then nothing
The Following User Says Thank You to Hanakuso For This Useful Post:
CSG Mike (09-27-2013)
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Cheap Brake kits worth it or not? Accurate Race Shop Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-11-2013 08:34 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
