Old 09-26-2013, 02:23 PM   #1849
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by ft_sjo View Post
Anyone else's tensioner flapping around?
video?
Old 09-26-2013, 03:03 PM   #1850
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
They all do that. It's an autotensioner and the spacing between pulleys there is substantial.
Originally Posted by meadowz06 View Post
I think I am about to pull the trigger on the innovative kit. I have 93 octane in Alabama. Auto transmission. How are the autos holding up? And what power gains can I expect with 93 octane, safe tune?
Thanks
Do it. These power levels are nothing for autos these days.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
whataboutbob (09-26-2013)
Old 09-26-2013, 03:29 PM   #1851
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks
do it. best decision i've made.
Old 09-26-2013, 03:44 PM   #1852
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Originally Posted by vgi View Post
definitely miracles, my avg is 28.8 with 90% highway
PS stock
no miracle... My roadtrip when I moved almost 1500 miles no tune/supercharger still had the header and muffler delete, I got 36 or 38 cant remember now. I just drive smarter, not harder :-)
JesseE is offline   Reply With Quote
Old 09-26-2013, 09:55 PM   #1853
whataboutbob
AutoX-10/10ths every run
Thanks
This is just a re-post of my last response to a similar question: http://www.ft86club.com/forums/showp...04&postcount=6
I've been running the Innovate Motorsports SC on my AT car for 3800 miles.
I have previous mechanical experience as a mtn bike mechanic, and I mounted it myself in 5.75 hours. The install wasn't difficult at all, the parts are all labeled and the install manual is well laid out with photos for each step. Flashing the tune is like updating firmware on your network router. Car started up on first try and I've had no issues with the system.
My daily commute is 80+ miles, mostly freeway. If I drive conservatively I get about 28-29 MPG.
The power delivery is smooth and linear. Boost kicks in at about 2500-2800 RPMs and pulls all the way to redline. I've had manual NA drivers following me on the freeway who told me that they had to drop 2 gears to keep up with me when I stepped on the gas.
I've also been autocrossing for about a year now in the car. I can say for sure that on courses where I'd be in 2nd and going slow when the car was NA it took a couple of seconds for the motor to rev up and get back into the power band. With the supercharger on now that is no longer an issue. I get immediate acceleration out of the turns. I haven't added an oil cooler yet, but I've not seen any increase in the car's running temperature.
One thing that I've noticed is that the auto tries to keep the RPMs low, and the Innovate kit delivers power nicely in the lower RPM range.
Here's a link with some videos I took right after the SC install:
http://www.ft86club.com/forums/showp...&postcount=133
And here's a dyno graph from a Mustang dyno (not the best pull that day):
http://www.ft86club.com/forums/showp...&postcount=139
I think that with the intercooler kit, headers, a custom tune (I'm running the Innovate 91 basemap), and some other mods you could get really close to 300. Keep in mind that it isn't just peak HP that matters, it is the area under the curve.
Hope this helps.
:happy0180:
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
evo4g63 (09-26-2013), normancw (09-27-2013), Pekingduck (10-01-2013)
Old 09-26-2013, 11:58 PM   #1854
20firestorm13
Drives: 2017 Halo Toyota 86
Alright, so I finally got most of the stuff done that I am doing for right now until the Intercooler for this is released.
On 93 Oct
225 whp
184 trq
on e85
253 whp
204 trq
My performance mods are:
Perrin 3 inch catback exhaust
Deatschwerks DW65C
Deatschwerks 700cc Injectors
Innovate Supercharger kit OEM
Dyno shows both the 93 run and the e85 run
20firestorm13 is offline   Reply With Quote
The Following 3 Users Say Thank You to 20firestorm13 For This Useful Post:
Alabang 86 (10-01-2013), DarrenDriven (09-30-2013), whataboutbob (09-27-2013)
Old 09-27-2013, 09:49 AM   #1855
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
What kind of unicorn magic is going on here?????
Have you gotten any more data on this? I know you said that there wasn't much heat transfer happening and wasn't sure if you found the cause?
calispec is offline   Reply With Quote
Old 09-27-2013, 09:53 AM   #1856
ft_sjo
Drives: GT86
I found that the de-gas pipe was flowing an awful lot of water, potentially by-passing the chargecooler element itself. I've put a restrictor in place and intend to do some testing at the weekend. It may be the cure! To the world!!
Regards,
Unicorn
Old 09-27-2013, 04:18 PM   #1857
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
@ft_sjo I was unable to find the brand of coolant in my setup. The shop that installed the kit mixes their own and refuses to tell me the brand/mixture.
But hopefully you've found what wrong with your kit in that pipe.
Anyway 1 week into ownership and my fuel economy has not dropped as bad as i thought. I used to get about 500km from a tank, now getting 450 - 460.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 09-27-2013, 11:25 PM   #1858
CajunFRS
Drives: Challenger R/T, CRX SI,
What's the news on the intercooler? Just curious. Tried to read back and couldnt find much.
CajunFRS is offline   Reply With Quote
Old 09-28-2013, 12:37 AM   #1859
ft_sjo
Drives: GT86
You can't always go by colour, but green is typically for older cars and not necessarily suitable for aluminium, which the charge cooler requires. You may just need to change it more frequently.
Old 09-28-2013, 04:08 AM   #1860
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Well hopefully not, I'm assured by the shop that they're using this mixture because it's what Sprintex told them to use on the prototype car.
Going to talk to Sprintex about it Monday morning since they are only a 5 minute drive away
Build thread
Old 09-28-2013, 06:50 AM   #1861
ft_sjo
Drives: GT86
I'm sure Bullet know what they're doing.
Old 09-29-2013, 03:13 AM   #1862
Mark@Abbey m/s
Drives: GT86 in Orange
Talk to Jamie @ Tokyo Motorsport.
http://www.tokyomotorsports.com.au/with regards coolant for the charge cooler.
We are going to try Evans Coolant in our development car.
Mark@Abbey m/s is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
