Old 09-26-2013, 08:30 PM   #1
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Torque RT700 - DOT 4 Racing Brake Fluid - Review
Torque RT700 - Racing Brake Fluid (DOT 4)
Torque RT700 Testing
Ever wondered why your brake pedal got mushy and unresponsive after a panic stop or a spirited drive? Were you ever curious about better brake fluids in hope of curing your brake pedal issues? Have you ever wondered why your brake pedal continues to get mushy, even though you're using a "performance brake fluid"? Look no further!
CSG has tested brake systems to ensure the highest quality and performance setups. We have tortured our brake setups to the point of failure to define the absolute maximum capacity each brake system offers. We discovered that despite having the best brake pads available, the brake pedal feel would diminish significantly over time with spirited driving. Frustrated at having to constantly flush brake fluid through our BRZ and S2k over the course of a track day, we've hunted for years to find a solution to our frustrations with DOT 4 "racing" brake fluids.
In order to meet the harsh demands of our track setups and the safety of our drivers, Torque RT700 was tested in the most extreme conditions we could form. Testing was conducted in a 390hp S2000 on a (purposely) stock brake setup. Lap after lap, the brake pedal continued to respond consistently, and throughout an entire day day of hot lapping in 112ºF desert heat, Torque RT700 Brake Fluid never deteriorated.
We have concluded that Torque RT700 is the finest DOT 4 brake fluid on the market. The results are summed up in a picture. Even faced with the task of surviving fiery hot brakes, Torque RT700 stood strong.
CounterSpace Garage is offline   Reply With Quote
The Following 10 Users Say Thank You to CounterSpace Garage For This Useful Post:
Anthonytpt (09-27-2013), bjun (03-12-2015), Bonburner (05-17-2023), fr_s (09-27-2016), jliongh (12-09-2016), normancw (01-05-2014), RehabJeff86 (09-27-2013), solidONE (11-06-2013), TofuJoe (07-11-2016), whataboutbob (03-29-2017)
Old 09-26-2013, 09:11 PM   #2
wparsons
wparsons's Avatar
Looks great, how's the price on it compared to the other typical go to's?
flickr
Old 09-26-2013, 10:24 PM   #3
CSG David
CSG David's Avatar
The price per bottle is $33.95 and is a direct competitor to Castrol SRF, which is considered the gold standard for brake fluids. If based on that particular track day alone with undersized brakes like the S2000 and using 5 sessions per track day as a metric, here's how the fluid would actually hold up:
Pricing is approximate MSRP and does not necessarily reflect sale prices.
ATE200/ATE Blue (1L) ~$19 (0.1 track days - give me 2 laps)
RBF600 (0.5L) ~$21 (0.2-0.5 track days - can fade in a few laps if you were really going for that hot lap)
RBF660 (0.5L) ~$32 (1-2 track day - hint of fade at the end of each session, but pedal feel continuously gets worse per session)
PMU (1L) ~$56 (2-5 track days - hint of fade end of each session but the pedal feel somewhat comes back)
RT700 (0.5L) ~$34 (still no changes after 6 solid track days and lots of spirited mountain runs)
Castrol SRF (1L) ~$80 (Gold standard for brake fluid...use has been varied and no exact data was found on how long this fluid lasts)
We were very skeptical at the brake fluid claims. For all we knew, it could have been snake oil, however, we bit the bullet even after knowing how well PMU worked for us and decided to try the brake fluid out. Torque has been marketed as the brake fluid of choice to Flying Lizard and other famous race teams. With this in mind, we had to test this out to verify the findings and to do so, we employed a few test vehicles to test the fluid out. That list includes the BRZ, GTR, M3, RSX-S, and S2000 over the course of 4 months of testing in hot weather conditions.
What is not easily noted on paper or results is the pedal feel and the extremely favorable modulation you get from the compressibility of the fluid.
A disclaimer for every car owner in general, your brake fluid degrades sufficiently enough over the course of the year even when you park it full time that service/owner's manuals will recommend you to replace your brake fluid every year for optimal brake performance for even daily driven cars like Camrys, etc.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
Anthonytpt (09-27-2013), gkubed (04-12-2017), solidONE (11-06-2013)
Old 09-27-2013, 11:14 AM   #4
wparsons
wparsons's Avatar
It's on par with RBF660 for cost, and way less than SRF so that's definitely well priced. I haven't had any boiling/fade issues with ATE Super Blue, but that's definitely due to how hard I'm (not) working the brakes.
flickr
Old 09-27-2013, 11:20 AM   #5
CSG Mike
CSG Mike's Avatar
At the moment, anyone who requires (or desires) more than RBF600, we recommend Torque RT700.
The Project Mu G-Four is a great choice in that you get a visual indicator for when your fluid needs changing; it turns from teal to brown as it wears out, and is a close 2nd choice for us.
Old 09-29-2013, 04:33 AM   #6
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
good to know. Haven't tracked the frs yet, but i fully cooked my old STi brakes with rbf600's and ebc yellows on 3-4 hot laps in laguna seca. Nice to know there's a better product.
bkblitzed is offline   Reply With Quote
Old 10-01-2013, 12:28 PM   #7
CSG David
CSG David's Avatar
Based on the number of times we replace brake fluid, the RT700 actually pays for itself after we realized how many bottles of RBF600 were used to regularly change the brake fluid. That brake pedal feel allows you to modulate the brakes a little more precisely as the compressibility and the consistency of the fluid does not change as you beat your brakes the brakes. This is actually the greatest benefit from RT700 over the RBF line up.
Old 10-01-2013, 04:48 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
Is a slightly compressible fluid considered a benefit? That seems at odds with the idea of swapping braided lines, but I've always thought that a little flex in the system would help modulation with hard pads.
Old 10-01-2013, 05:50 PM   #9
CSG David
CSG David's Avatar
Every fluid is slightly compressible. When you press the pedal 3 times and hold, does that pedal remain in the same general position or does it feel like the pedal feel like it's losing pressure and sinking? Are those pedal pumps solid and somewhat linear each time? These are some things that you can feel and understand that there is a range of travel that is proportional to how hard the pads are depressed.
Fresh fluid that has been flushed gives you that confident feel. Brand new cars some times exhibit that excellent feel. The point at which the fluid starts to absorb some moisture (or lacks the ability to absorb moisture) is where the different fluids begin to differ greatly.
Stainless steel braided lines are different. They do firm up the brake pedal by decreasing the amount of line expansion, however, you can never really fix the feel of boiled fluid without changing it out. On top of that, brake lines are much more "rigid" compared to the brake lines of yester-years. Brake lines are a consumable in which they must be replaced every so often and that goes for the same for SS lines as well.
In terms of modulation, the confident pedal feel and lack of brake fade also contributes to excellent connection between you and your brake pads. Certainly brake pads plays a large role in modulation as well.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Anthonytpt (10-01-2013), Calum (10-01-2013)
Old 10-24-2013, 02:38 PM   #10
CSG David
CSG David's Avatar
Some updates on the RT700 brake fluid at 3 months and 10k miles of hard use.
I installed some Project Mu Type NS400 brake pads to simulate a street driving experience for those who are interested in top end brake fluid and OE upgrade brake pads. With a spirited run, the Type NS400 hold up well with upgraded bite over OEM brake pads, but these pads will fade without proper brake management. They are the perfect OE upgrade brake pads that dust very little and have absolutely no noise. Fade resistance is increased for street driving over OEM brake pads.
At no point did the RT700 ever show evidence of drop off despite extreme weather changes and constant heat cycles. Pedal feel continues to remain confident and modulation feel is a slight increased sensation over previous brake fluids. RBF600 appears to have some drop off over time for street driving and a potential to boil brake fluid is actually quite high during spirited runs. OEM brake fluid is a joke when it comes to this type of fun. With high end brake fluid, this is not an issue. RT700 still remains the top choice for confident braking performance.
Anthonytpt (10-24-2013), smg1138 (07-16-2016)
Old 11-03-2013, 05:47 PM   #11
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
@CSG David,
I'm considering changing out my brake fluid but I haven't been able to find how much fluid I need to purchase. Would I be safe with two 500mL bottles or do you think I'd be fine with just one?
Also, your advocacy for this fluid is encouraging. Is there any drawback to this fluid besides maybe the price?
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 11-03-2013, 07:43 PM   #12
Calum
That Guy
Originally Posted by Cjymiller View Post
@CSG David,
That's what they're sending me for my complete fluid change.
Old 11-03-2013, 11:36 PM   #13
CSG David
CSG David's Avatar
@CSG David,
1. 2-500mL bottles is sufficient to completely flush your brake fluid system. You will effectively flush our your brake fluid extremely well with 1.5 bottles.
2. No drawbacks. This is like advocating the use of 100 octane at the racetrack when you're driving a boosted/FI car tuned for 91-octane in 100F weather. 100 octane is simply safer and better for your engine, but just cost more to run.
The Following User Says Thank You to CSG David For This Useful Post:
Cjymiller (11-04-2013)
Old 07-08-2014, 01:35 PM   #14
CSG David
CSG David's Avatar
This is a long awaited updated.
It has been over a year since I've used this brake fluid in my personal car (S2000 CR). I've cracked multiple rotors and overheated the brake system multiple times. My car runs on 255/40/17 RS3s and was boosted once upon a time with no brake ducting.
Throughout those multiple track days and in cold and intense heat conditions, RT700 has held up to abuse. I have had a slight hint of fade at one point when I repeatedly abused the brake system beyond its operating limitations. With other brake fluids, I would feel the brake pedal degrade over time. If I boil standard DOT4 brake fluid, the brake pedal feel almost never really returns. With the RT700, the brake pedal feel recovered quickly. Even after a slight mushy feel after several back to back to back sessions in 110ºF heat, the pedal would spring back to life after a proper cool down and resting period in the paddock.
That, to me, has been the most impressive thing about RT700. While I would have repeatedly changed the RBF600 brake fluid every track day, I wounded up never having to change or top off the brake fluid with RT700 for over a year.
The Following 5 Users Say Thank You to CSG David For This Useful Post:
BatStig (10-06-2014), gkubed (04-12-2017), SuperDave (06-29-2016), whataboutbob (03-29-2017), wparsons (07-08-2014)
CounterSpace Garage - Authorized Dealer - Torque RT700 Racing Brake Fluid CounterSpace Garage Announcements, Contests, Giveaways 0 09-26-2013 07:33 PM
Brake fluid question barabia Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-31-2013 11:08 PM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 03:20 PM
Racing brake fluid promo MillersOilsUS Brakes, Suspension, Chassis 0 12-31-2012 11:29 AM
