Old 09-25-2013, 06:53 PM   #1
learnerspermit
learnerspermit's Avatar
Drives: C-17A
Car Dies at 170 Miles Check Engine Limp etc CASE CLOSED
Check Engine Light, Rough Idle, Limp Mode
2013 Scion FRS
So I leased the car on Saturday and have been putting some miles on it back and forth to work this week. Left Kroger today and the car started idling rough, not accelerating and died. Attempted to re start the car 5 or 6 times and I recieved a "Check Engine Light" , "Trac Off", and another light. The car idled terribly and wouldnt drive over 5 mph! Pulled back into a parking spot, turned it off, called the Toyota dealer and they said "check the fuel cap". I said it hasn't been touched since you guys filled it up before we left Saturday. The service advisor followed with "drive it up there first thing in the morning". (Wow) Fortunately my house was less than 2 miles away from Kroger where I broke down. Started the car up and it was able to rev up the CEL was still on but the "Trac Off" had extinguished. It drove decently home with a rough idle. Im going to suspect that the car has the wrong grade fuel in it and being so new the computer is very unhappy with some crappy fuel. I will post my findings tomorrow.
September 26 2013
A little update:
Dealer opens at 7 a.m. this morning. So as I'm driving to work I got a nice surprise I set the cruise control "arm" switch and on the display it illuminates but won't engage to hold a speed, and the arm light with not extinguish. Continue driving to the dealer. Pull up to the service lane and while waiting for them to open the car starts having a rough idle and proceeded to hunt for the idle followed by the engine dying from what seems like a lack of fuel. I then attempted to re start the engine, took two attempts and then started. So now I have a cruise light on, and a check engine light still. Now I've been told that they are out of courtesy rental cars today. I'm waiting on a sales manger to come in....... I know nothing about a direct injected engine like this particular one, but the car acts like my Duramax did when it had a bad fuel filter so I'm assuming direct injection is similar in theory of operation to the injection on a diesel please correct me? I have been shafted on car issues latley the same day I bought this I got my Volks for my other car scratched to shit at the tire place another on going battle this week.
Here's a video of the bad idle and dying waiting to go in the service lane
[ame]http://youtu.be/adQ0kNgp6Ks[/ame]
Update:
September 26 2013
Newest update just attempted to return my car to me. I was told a "loose negative battery cable" I smell bullshit and have a feeling I will be back soon. Codes were cleared however codes listed on my invoice:
PO87
PO171 (system to lean?)
PO193 (fuel rail pressure?)
PO1604
C1201 (communication stop with ECU)
C1241 (low battery positive voltage)
B1410
Googled trouble codes found those. My question is if In Fact this was due to a loose battery terminal why did I NOT get a battery light anywhere during this process?
Another issue this morning was the seat "pull to release" for the drivers side doesn't release the seat to slide forward for access to the back doesn't function. Invoice said everything worked fine so it's back in the service bay will update.
And the solution was told to me that's it's not suppose to work so the driver can't be moved while driving. and for reference this is the release in referring to
Update
September 27 2013
Back at the dealer again today. To no surprise same issue this time instead of breaking down in a Kroger parking lot it was while crossing traffic. Got to the dealer and the lead tech supervisor today was very professional and knowledgable he apologized for the mis communication from the service advisor yesterday and is personally handling this process now. He pulled the codes and they were again "fuel" related today... He's keeping the car over the weekend to run diagnostics as well as forwarding this information to Toyota. Hopefully Monday I will get my car back because I have to go out of town for work Tuesday. They also provided me with a nice rental car today.
Case closed 17 OCT 2013
Well finally go my car back from the dealer today. They diagnosed the issue to faulty wiring on the direct injection sensor to the harness. So the harness has been replaced and the car is fine now. Basically as the voltage changes due to the loose wire, the direct injection was told to dump fuel immediately followed by a lean code etc read the above for better description. I'm really happy with the service tech and the local dealer how they handled this now and happy to finally have the car.
learnerspermit is offline   Reply With Quote
The Following 5 Users Say Thank You to learnerspermit For This Useful Post:
Guff (11-06-2013), mad_sb (10-22-2013), Sportsguy83 (10-22-2013), strat61caster (10-17-2013), Wolfking (09-26-2013)
Old 09-25-2013, 06:59 PM   #2
ModBargains
ModBargains's Avatar
Drives: FRS, M3
First time I've heard of someone with that issue, be sure to update us and let us know what the cause was.
ModBargains is offline   Reply With Quote
Old 09-25-2013, 07:05 PM   #3
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
I swear if someone really filled up the car with the wrong gas is a moron, it even says what kind of gas to get on the gas cap. Good luck and i hope everything work out well for you.
Kelbyat07 is offline   Reply With Quote
Old 09-25-2013, 08:54 PM   #4
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Really there is a million of these threads about the same thing happening. Been happening to people since they got the car. Shit some people had it happen to the car before they got out of the parking lot.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
Rampage (09-26-2013)
Old 09-25-2013, 09:11 PM   #5
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
My money is on a fuel issue too. Get an octane booster from advanced auto before you drive it back and see how that feels.
Old 09-25-2013, 09:14 PM   #6
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
do you have any idea how much octane booster he would need to actually make a difference? ~10 gallon tank, assuming it is at 1/4 tank and he has 87 octane in there: according to my calculations he would need 1.5 assloads of it.
The Following 6 Users Say Thank You to SloS14 For This Useful Post:
Atropine (10-21-2013), fender9530 (11-06-2013), JDM FRS (09-26-2013), Koa (03-05-2015), Starscream15 (11-06-2013), wootwoot (09-25-2013)
Old 09-25-2013, 09:18 PM   #7
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
I couldn't stop laughing after reading this thread...
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 09-25-2013, 09:45 PM   #8
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
this is sounding a lot like that guy who had transmission issues after like 15 miles and turned out there was little to no tranny fluid in the car...
I hope your situation is better than that one
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 09-25-2013, 10:30 PM   #9
BRZnut
Drives: BRZ DGM Limited
Sounds to me like the Cam issues , but I though those issues were fixed. This is a new car (recent build) right?
Old 09-25-2013, 11:07 PM   #10
Tromatic
Mine ran fine on a tank of 87.
Old 09-26-2013, 12:13 AM   #11
nix
nix's Avatar
Drives: AVO BRZ
You should be OK to drive it back to the dealer, try and maintain rpm higher than normal and bump it into neutral as you begin to stop.
nix is offline   Reply With Quote
Old 09-26-2013, 12:27 AM   #12
dehydratedH2O
Drives: 2014 BRZ Limited DGM
this is not an octane issue. the car will run on low octane gas without going into limp mode. if you can't get it out of limp mode, have the dealer pick it up from your house with a tow truck. limp mode doesn't exist so you can get it to the dealer, it exists to get the car off the road for a safe tow.
dehydratedH2O is offline   Reply With Quote
The Following User Says Thank You to dehydratedH2O For This Useful Post:
SloS14 (09-26-2013)
Old 09-26-2013, 01:32 AM   #13
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
It could be the person who filled up the tank before delivery filled it up with diesel instead of gas.
#944_10_Series_FRS is offline   Reply With Quote
Old 09-26-2013, 01:42 AM   #14
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
Redacted.
Sent from my SGH-M919 using Tapatalk 2
ProTekk is offline   Reply With Quote
Check engine light just came on after 2k miles. danthedirt Issues | Warranty | Recalls / TSB 604 01-31-2015 04:26 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
Check engine light now on at 2995 miles Marshman Issues | Warranty | Recalls / TSB 2 12-17-2012 07:41 PM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 02:50 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
