Old 09-25-2013, 08:54 AM   #29
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
It's worth noting... GL-5 absolutely does not belong in your transmission (unless also GL-4 rated, e.g. Motul). Maybe that was a typo?
Most GL-5 oils shift like dogshit. This is a persistent problem for AWD Scoobies because the gearbox contains the front differential and hypoid gears and it absolutely needs GL-5.
Now I'm not pretending to re-engineer Toyobaru's product here, but imo the factory tranny fill is poor. It just doesn't shift well and it's horrid when cold. Synchronizer performance *will* be improved by substituting something like Redline MTL GL-4, but note that MTL is a bit lighter than the book spec. Guys that have tried MT-90 (similar, but heavier, meets book spec) report that it shifts poorly when cold. My car (so far) shifts great on MTL, best when at operating temperature.
Trans oil selection can be everything and you'd think the engineers at Toyobaru and their trans vendor (Aisin) would know this, so wtf is up with this?
Anecdote: I had an early wrx that at 80K miles had to be double clutched to get into 5th. Before too much longer it was 4th and 5th. The car would have been completely unsalable at this point and I was beginning to face up to a transmission repair. A little fiddling with oil selection (might as well try!) *completely* solved that issue (nothing was actually broken) and the car has done an additional 100K since with no problems!
The manufacturer's poor attempt at CYA is really annoying here....
Ralph Spoilsport is offline   Reply With Quote
Old 09-25-2013, 09:17 AM   #30
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by DoomsdayJesus View Post
I forgot to mention, one of the gems the service rep told me the techline related, is that "the car's not meant to be driven that way," i.e. shifted around 7k RPM. .
Maybe that service rep knows more about these cars than we care to acknowledge?
Regardless, get some Motul 300v gear oil in that new tranny.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-25-2013, 10:19 AM   #31
OrbitalEllipses
Drives: Attitude
Originally Posted by vgi View Post
So turbo actually voids gearbox warranty?! Is this due to more hp/tq?
Yes...that's perfectly reasonable too. The issue is on a stock car.
Old 09-25-2013, 10:48 AM   #32
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, your drivetrain is now taxed to put more power to the ground, probably more than designed for.
Old 09-25-2013, 10:49 AM   #33
CARNZ
CHECK ENGINE
Drives: 2004 STi
I feel like the dealer fed a line of BS to SOA to convert it to a goodwill only and claim it as abusive driving.
I've replaced a trans on a BRZ here for grinding with zero issues from SOA or their tech line.
Maybe the jackass tech tried to claim it as abusive driving...
Anyone in MD/Baltimore area I will be glad to help you guys out on warranty items at my dealer as long as it's not something insane, lol
i don't cry about crickets
CARNZ is offline   Reply With Quote
The Following 3 Users Say Thank You to CARNZ For This Useful Post:
mwjcyber (09-25-2013), TheseColorsDontRun (09-25-2013), Turbowned (09-30-2013)
Old 09-25-2013, 11:04 AM   #34
Wepeel
Drives: '13 BRZ Ltd
At least you might have an out in the future - since they said they filled the trans with GL-5, which is not compatible with GL-3/4 (what the owner's manual recommends, because GL-5 can be corrosive to yellow metals). Would be a good idea to change the fluid for a GL-4 (or GL-4/5 rated).
Wepeel is offline   Reply With Quote
Old 09-25-2013, 11:38 AM   #35
vgi
Drives: frs
I can see this happening at subaru dealership:
- oh, you have an exhaust, that's extra +3-5 HP/TQ - the car was not designed for it and so kiss goodbye to engine, and whole drivetrain (and suspension probably too) warranty.
vgi is offline   Reply With Quote
Old 09-25-2013, 11:43 AM   #36
Sportsguy83
Drives: Limited BRZ
Depending on dealer, I also see it very possible.
Old 09-25-2013, 12:21 PM   #37
autobrz
Drives: Mazda 3
disclaimer: retarded reply about to follow...
everytime I read about MT grinding issues, I'm very glad I got the AT... plus it upshifts and downshifts faster than I can if I cared at all about the synchros...
autobrz is offline   Reply With Quote
Old 09-25-2013, 12:24 PM   #38
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
That wasn't a typo on my end, that's exactly what it says on the service receipt/summary. I'm calling the dealer today to find out what the hell is going on, and why they tried foisting the blame on SOA. Either way, no one with any sense is going to be sympathetic to them claiming shifting at 7k is "abuse" on a car with a 7400 RPM redline, and that's not remotely close to where I told them the problem started.
DoomsdayJesus is offline   Reply With Quote
Old 09-25-2013, 12:26 PM   #39
Dipstik-sportech
Dipstik-sportech's Avatar
I think this sums it up quite well
The Following 4 Users Say Thank You to Dipstik-sportech For This Useful Post:
akuhei (09-25-2013), charged86 (09-25-2013), Marchy (09-25-2013), sprintertrueno86 (11-26-2013)
Old 09-25-2013, 12:28 PM   #40
charged86
charged86's Avatar
Originally Posted by feldy View Post
But I thought all of you bought Subaru because of the name and maturity it brings.
So glad I went with Scion. Had crickets replaced, rubber weather striping, drivers side rear axle, both tail lights and the drivers side window visor replaced. Nothing denied so far. Even had the car on springs and koni shocks and was not denied axle warranty.
Nice work! What dealership. Also did the weather strip on driver side fix how when the window rolls up it pinches the weather strip
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 09-25-2013, 12:28 PM   #41
charged86
charged86's Avatar
Or didn't drive like a yaris. Lol
Old 09-25-2013, 12:50 PM   #42
ZionsWrath
Thanks
ZionsWrath's Avatar
ugh, so many threads making me rethink going FI vs waiting few years for a stock high HP car like a corvette :'(
5th Gear "Mini-Grind" BRianZ Issues | Warranty | Recalls / TSB 63 07-18-2015 06:12 AM
Should this be covered by warranty and can Subaru repair this? brzadmir Issues | Warranty | Recalls / TSB 16 08-01-2013 01:08 AM
New "Drive Clean" on wheel repair and fitment SkAsphalt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-10-2013 06:59 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
16" Subaru Steelies $39.99ea limited to 4 sets Stav Canada Classifieds 5 01-04-2013 12:15 AM
