Old 09-23-2013, 02:25 PM   #15
elrod
elrod's Avatar
Drives: WRB BRZ Limited MT
Originally Posted by shiv@vishnu View Post
Emissions compliance and fuel economy targets.
I realize that this is an unusual question for this kind of thread but ...
I would certainly like the boost in power and torque that the baseline tune provides in everyday driving, but what about highway MPG? On those occasions when I take a trip of 300 or so miles, would I still be able to achieve around 30 MPG cruising down the highway with a stage I tune?
elrod is offline   Reply With Quote
Old 09-23-2013, 03:31 PM   #16
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
i've noticed only a 1/2 mpg decrease since changing to the V1.1 tune. don't know if this is due to the tune or that i'm enjoying the car more. i think its the later.
garfull is offline   Reply With Quote
The Following 2 Users Say Thank You to garfull For This Useful Post:
elrod (09-23-2013), Garrett@Openflash (09-25-2013)
Old 09-24-2013, 03:42 PM   #17
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
As garfull said, you really shouldn't see a difference in fuel economy during cruise since very little mapping changes were done at light load conditions. Certainly nothing to make mpg take a turn for the worse. And under load, the new maps target a leaner-than-stock AFR and run more ignition advance so it should have been overall fuel economy, all things equal. Of course, after a tune, people tend to drive with a heavier right foot
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
elrod (09-24-2013)
Old 09-24-2013, 05:07 PM   #18
mid_life_crisis
Drives: FR-S 10 #103 AT
I'm pretty sure I know the answer to this question because to the ecu a flash is a flash, but any chance this Tablet and software can camouflage the fact that the thing has been tuned if you put it back to stock for dealer visits?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-24-2013, 05:09 PM   #19
mid_life_crisis
Originally Posted by arghx7 View Post
I would think that what you ended up doing here was retarding the exhaust closing timing a bunch (hence the 30 degree difference at mid range). I would expect that to give a later blowdown and more scavenging. The factory tune was probably set that way to keep too much oxygen from passing through the engine and heating up the cat through exothermic reactions.
This makes me nervous. Is this power at the long term cost of a catalytic converter down the road?
Old 09-24-2013, 05:13 PM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
ahhh fun times with the neverending quest to sucker punch the warranty.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
canu_50 (10-18-2013), kombatlion (10-18-2013)
Old 09-24-2013, 05:16 PM   #21
FRSTEVE
FWIW - i've run some pretty high powered cars in CA (400WHP, 500WHP and 600WHP+) ... i've had the cats on a few of the for a while and ran 100s of gallons of leaded gas and still passed emissions. Never really had any concerns about cats.
If you are concerned, when you're up for a smog check, you can always purchase a "newly, used" stock part (header, front pipe) that someone is selling to pass the test, which is the worst case scenario (1hr of labor and you're done for a few years).
New cars in CA get smogged after 5 years.
FRSTEVE is offline   Reply With Quote
Old 09-24-2013, 05:24 PM   #22
mid_life_crisis
I figure minor mods like N/A tuned shouldn't cost your warranty. The car should be built well enough to handle it. Now a turbo at 10 psi boost is another story...
The Following User Says Thank You to mid_life_crisis For This Useful Post:
dokterdewe (09-25-2013)
Old 09-24-2013, 05:27 PM   #23
Sportsguy83
Drives: Limited BRZ
What you "think" or deem acceptable has nothing to do with it. Its what is written on paper.
You are not loosing the warranty of your entire car. I have changed DRLs bringing my car in turbo because that part has nothing to do with it. But this is besides the point.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 09-24-2013, 10:13 PM   #24
arghx7
Drives: car
Short answer: don't worry about it, only an emissions lab would ever be able to tell.
Detailed answer: The only thing you as an enthusiast would care about is whether it throws a code, whether it fails a visual (if your inspection enforces a visual check), and whether it would fail a basic tailpipe test which measure concentration in ppm. On all three of those, you should be fine. Now, if I were in charge of Toyota's in-use testing program for EPA and CARB, would I test your car and send results to the EPA? Heck no. There's a reason why only catbacks are legal in Cali. Any engine mod you do beyond that can cause a drastic increase in emissions (percentage wise at least) over the life of the vehicle due to accelerated degradation of the cat, changing sensor accuracy (aftermarket intake), or changing AFR (reducing open loop delay).
BUT unless it's totally dead, you can only see a degraded cat in a "real" government emissions test with expensive sampling equipment. CA smog stations don't have the proper equipment, which costs millions of dollars. The OBD code p0420 only goes off when emissions are something like 1.5 times the legislated limits (I'd have to check the regs). If that light goes off, your cat is already fucked from an emissions standpoint.
This doesn't surprise me. Cali emissions tests are strict compared to other states but they're not strict compared to what the tests the manufacturer is required to do on their own cars after they've been in service. They have to be tested after 1 year and 4 years in service, and the results go to the EPA and CARB.
Most people are going to mod their car, turn off the CEL at some point, and never worry about the cat ever again.
The Following User Says Thank You to arghx7 For This Useful Post:
mad_sb (09-25-2013)
Old 09-25-2013, 10:40 AM   #25
mid_life_crisis
I don't suppose you have a dyno comparing stock to just tuned for those of us who don't want to buy all kinds of bolt-ons.
Old 09-26-2013, 02:59 PM   #26
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
Here is what you are looking for: http://www.ft86club.com/forums/showt...ght=vishnu+OFT
This is a comparison between Stock VS Vishnu OFT Tune. *No bolt ons
Robert@Openflash is offline   Reply With Quote
The Following User Says Thank You to Robert@Openflash For This Useful Post:
mid_life_crisis (10-08-2013)
Old 10-08-2013, 01:13 PM   #27
mid_life_crisis
@shiv@vishnu Would you consider this a relatively "safe" tune, one that pushes the envelope a little or conservative for someone who has access to 93 octane?
Old 10-08-2013, 02:02 PM   #28
Shiv@Openflash
Drives: 2013 FRS
Our OTS maps are absolutely safe. No changes that I would consider extreme by any means. Just fixed some stuff that should have been fixed in the first place (but weren't presumably due to emissions compliance constraints).
open stealing tablet, throttle response
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 02:03 AM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
Tein H-Tech & S-Tech / Street Basis Coilovers & More / Great Deals @ Import DPS!! rickspecd Brakes, Suspension, Chassis 4 07-12-2013 12:49 PM
