| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Drives: 2002 honda civic ex
5000 to spend on what?
Exactly that...if you had 5 grand to spend on a car what would it be?
#2 |
formerly Dixie Normous
Drives: The ladies wild!
KP61 starlet and swap in a 3sgte
#3 |
2 wheel member
Drives: JZA80, 997.1, Taco
#4 | |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
i'd probably just spend it on my MR2 (after i spent $1000 or so re-doing the suspension on my truck). ![]() -Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
#5 |
hashiryu
Drives: Mk4 Supra
An indoor farming kit to grow and sell cash crops to multiply the $$$ so I could buy something decent.
#6 |
Site Moderator
Drives: ichi 86 Project
upgrade the suspension area like:
Coilovers w EDFC control unit 4/2 pot calipers w performance pads slotted rotters SS brake lines trans & motor mounts adjustable rear lateral control arms aluminum control arms adjustable rear sway bar sway bar end links rear top sway v bars ball joints tie rods rear lower arm bar bushings: rear diff support bushings lateral link bushings control arm bushings rear trailing arm bushings and if I still have $$$$, I'll upgrade: performance ground kits oil catch can kit lightweight flywheel mid-weight pulley kit regrind cams w upgrade valve springs porting and coating ceramic: intake manifold throttle body valve lifts by the time I get to this area, I should be broke again. lol Last edited by ichitaka05; 03-12-2010 at 03:42 AM. |
#7 |
Inexperienced
Drives: Crappy old '90 civic. Frankie.
What if I've already got 1200 of my own and I want to get an '07 CBR600RR?
If not, then.. a 300zx, I guess. |
#8 | ||
2 wheel member
Doubt you can find a decent SW20-22 for $5k unless it's salvaged or a non turbo. Those are just as rare as MKIV Supras. Quote:
#9 |
Drives: Toyota Corolla SR5
save it and make it a down payment for a new car like the FT86 lol
#10 | |
2 wheel member
#11 |
Drives: 2014 Scion FR-S
buy toyota stock, it's bound to go back up to it's high 91. its currently in the 70s.
I've seen some pretty nice older 600F4i's for around 2000-3000, only thing is i don't know how good of a condition their in since most of them are in areas where there's alot of stunters. |
#12 | |
2.1L 3SGTE
-Mike
#13 |
2 wheel member
Can you post some pics? I did a 500 mile radius around SoCal and only came up with 2. Both of them were in decent shape but over 5K. I search for 94+ b/c it has the better tail lights.
#14 |
Id probably have to get something a bit more practical then an mr2...as much as i would like one.
http://www.autotrader.com/fyc/vdp.js...standard=false more like this civic si...except that it has 170k miles http://www.autotrader.com/fyc/vdp.js...standard=false |
