Old 08-20-2013, 06:02 PM   #141
ft86xtc
Drives: 2013 FRS
I see your puttin in work up there, im surprised i thought everyone went to importwars at great lakes. Nice runs though!
ft86xtc is offline   Reply With Quote
The Following User Says Thank You to ft86xtc For This Useful Post:
mack4477 (08-21-2013)
Old 09-14-2013, 12:11 AM   #142
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
Originally Posted by FullBlown View Post
-FBM Stage 1 Base kit with gtx28 upgrade
-FBM 3" Exhaust
-ACT clutch
-FBM Custom 93/E85 tune
Stock VS 93 Pump VS E85
I won't lie, this video gave me chills and damn near got wood!
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
The Following 2 Users Say Thank You to ravenblackfrs For This Useful Post:
ftc~brz (09-24-2013), mack4477 (09-14-2013)
Old 09-14-2013, 04:45 PM   #143
mack4477
Drives: 2013 Firestorm FR-S
You should try driving it
mack4477 is offline   Reply With Quote
The Following User Says Thank You to mack4477 For This Useful Post:
ravenblackfrs (09-14-2013)
Old 09-14-2013, 04:50 PM   #144
Frs300
Frs300's Avatar
Drives: Pile of junk
@mack4477 anymore videos? i guess i could check youtube chan myself
Frs300 is offline   Reply With Quote
Old 09-14-2013, 04:59 PM   #145
mack4477
Nothing since the last batch. Haven't had much time to set anything up. Got a buddy with a 525ish awhp Evo moving to town next week. That should be pretty damn close
charged86 (09-16-2013)
Old 09-24-2013, 01:58 AM   #146
FRSTEVE
@mack4477 - fantastic results. I was wondering up top, where the WHP starts to drop off, is that intentional (easier shifts) or is the turbo out of steam up there?
I was personally thinking of a GTX30R, but wanted to right size things (match intercooler capabilities, with various pipe diameters and the staying in the good range for the turbo).
Thanks.
FRSTEVE is offline   Reply With Quote
Old 09-24-2013, 02:02 AM   #147
mack4477
Thanks.
The GTX28 does run out of steam a little earlier than some of the slightly bigger turbos. But for me, the extremely fast spool was worth the trade. As far as matching things up perfectly, I would talk to LJ @FullBlown. The man knows his stuff
ravenblackfrs (09-24-2013)
Old 09-24-2013, 11:44 AM   #148
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have found that the GT2871R loses as much as 2 psi from max boost at 8000 RPM.
Old 09-24-2013, 04:54 PM   #149
FRSTEVE
@king_tut and mack4477 - thank so much for your replies, its very helpful.
@king_tut - you mention a 2psi drop at top, was wastegate duty cycle maxed out? If so, have you considered using a stronger wastegate spring to see if it keep things shut at 8000 rpm? I usually assume pressure drop is due to something leaking (wastegate, BOV). The drop in power at same boost levels would be due to running out of the efficiency cycle of the turbo. I really would like the spool of the smallest turbo, that can make power using all the revs available to us (and not much more than that).
did you guys consider asking for a twinscroll option? have the manifold go 4-2 or put a divider at the housing interface?
thanks again!!!
Old 09-24-2013, 04:56 PM   #150
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
@king_tut - you mention a 2psi drop at top, was wastegate duty cycle maxed out? If so, have you considered using a stronger wastegate spring to see if it keep things shut at 8000 rpm? I really would like the spool of the smallest turbo, that can make power using all the revs available to us (and not much more than that).
thanks again!!!
If you are looking to make more power up top a twinscroll application is the last thing you want to do. From what ive heard twinscroll setups focus more on the midrange and tend to taper off up top. They are also only truly benefitial on larger frame turbos(i.e. 6262, gtx35r etc)
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 09-24-2013, 05:22 PM   #151
FRSTEVE
Makes sense, i'm just used to evo twin scroll since their runners are so short and the have so much exhaust velocity, it can drive it efficiently (great spool and a properly matched top-end). Unfortunately, our boxers aren't designed that way.
I really wouldn't consider running a 62 frame on such a small motor. I have a PT5858 CAE, ball-bearing in my 6 cylinder, 3.0 liter motor and its pretty well matched, but would I would think it it would be too laggy for a 2.0 liter even with our higher compression motors.
Old 09-24-2013, 06:40 PM   #152
Dipstik-sportech
Dipstik-sportech's Avatar
I actually was considering switching to a pte 5858 bb sometime in the near future. My buddy has a gt40 on a 2.0l Honda and it makes useable boost at 4000rpm on a top mount manifold. I never understood why people talk about lag. Our cars are so short geared you'd be hard pressed to fall out of boost, and if they mean if you're on the highway and u punch it in 6th well most anything short of a diesel will lag that's y we downshift lol. Who races from 6th lol
Old 09-25-2013, 11:49 AM   #153
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am running a 9.7 psi spring in my wastegate currently. My guess has been running out of efficiency of the turbo is causing it. I know the AVO kit performs similarily, but not many people on this forum post boost plots that I can compare mine to. I also have my dump tube recirced which most don't and I think that might be causing the weird bump/dip I get at 6000 RPM. Here is my current boost plot:
Old 09-25-2013, 02:48 PM   #154
pmccut
Drives: Blue Subarus
Mine has always tapered off as well. GT2871R, open dump tube.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
400HP Toyota GT86 GT4 Racer by GPRM Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 46 04-10-2015 10:31 PM
DCW Firestorm FRS doggy Member's Car Journals 381 02-28-2015 05:29 AM
E85 400hp mark Fabron757 Forced Induction 26 06-20-2013 02:41 PM
L3P's Firestorm FR-S L3P47 Member's Car Journals 67 06-02-2013 11:32 PM
Looking for a Firestorm 6MT? phm14 Scion FR-S / Toyota 86 GT86 General Forum 1 06-11-2012 02:46 PM
