Old 09-23-2013, 10:26 PM   #645
Brzetto
Drives: 4 wheels
Originally Posted by fatoni View Post
youre wasting your time guys.
Fatoni speaks the truth, you guys won't win. Move along.
Brzetto is offline   Reply With Quote
Old 09-23-2013, 10:34 PM   #646
fatoni
its pretty tough to win when facts are ineffective
The Following User Says Thank You to fatoni For This Useful Post:
LSxJunkie (09-24-2013)
Old 09-23-2013, 11:26 PM   #647
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Curious why they do the staggered wheel diameter?
A big part of muscle cars is having the nose down and the ass up. They use to do this by changing the rear leaf spring mounts and chopping the front springs. Staggered diameters allows this without messing with the suspension and sacrificing performance. It was also used by drag racers to allow them to have big burn outs and as soon as they took off the weight would shift to the back as the nose came up giving them more traction. The look is not for everyone but big time muscle car guys normally like to see the nose down a bit.
Sent from my Q10
Old 09-23-2013, 11:59 PM   #648
Brzetto
Drives: 4 wheels
They aren't facts when reality negates them.
Old 09-24-2013, 12:12 AM   #649
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
It's not low end, you clearly don't own a BRZ or FRS so your opinion is invalid.
I didn't say it was bad (quite the opposite - it's an excellent car), but at $24-32k (depending on market and options), it's definitely low-end, along with the MX5. In many ways, actually, that's a large part of its appeal. It's clearly in a completely different class from the $55-120k Corvette, or the $330k+ Ferrari.
chrisl is offline   Reply With Quote
Old 09-24-2013, 12:36 AM   #650
Brzetto
Drives: 4 wheels
I still wouldn't call the BRZ low end, the FRS is low end because it doesn't have the HID's or LED's in the front among other things. I don't have the premium BRZ though, I have the limited model that nearly pushes $30,000 You are entitled to your opinion, I'm entitled to mine. The Miata is in it's own class though. If we're going to be honest here, the BRZ is higher end than the Mustang for sure. To me a low end car does not do 150 mph with only 200hp, that's more like a higher end car.
Old 09-24-2013, 01:36 AM   #651
Brzetto
Drives: 4 wheels
Originally Posted by LSxJunkie View Post
This has nothing to do with muscle car stance and everything to do with aerodynamics and styling. Corvettes for the last 3 generations have been given a slight forward rake to reduce lift. The Corvette is a drag racer LAST.
You think that high end is defined by things like HIDs and LED running lights? $21,000 V6 Mustangs have those.
Standard across the range now. HIDs are standard in Honda CR-Zs too, which start at $20,000.
Oh, and I've been here since 2011.
The Mustang just received those lights, other cars have had them for years. The Mustang also can't achieve 150mph. The BRZ is, quality, lighter weight, build quality itself is superior, the style is better, the design is superior as well. Anyway.
Old 09-24-2013, 02:19 AM   #652
serialk11r
Drives: '06 AM V8V Coupe
Staggered wheel diameter? Never noticed that on Corvettes. Will take a closer look next time I see one. Aside from the rear wheels looking more full relative to the taller back end, having a bigger diameter wheels also makes the contact patch longer (relative to the axis of the car) which might be good for stability under acceleration?
Old 09-24-2013, 08:27 AM   #653
Mikem53
Drives: FR-S 6MT
Sent from my Q10
Actually. The staggered setup is used to create rake, for aerodynamics.. And for that swooping look. It's not a drag car! Drag cars don't use or want an IRS setup.
You get bad axle tramp with IRS and lots of HP..
Mikem53 is offline   Reply With Quote
Old 09-24-2013, 08:50 AM   #654
Mikem53
Drives: FR-S 6MT
Well you might not call it low end... But the facts say it is.. And since when does HIDs and LEDs make a car "high end" ?
And how is the FRS low end when it's the same car minus some HID's?
The point being made was the FRS/BRZ are entry level sports cars.. Just because you bought one with more options.. Doesn't change the fact that they are entry level sport cars.
The Following 2 Users Say Thank You to Mikem53 For This Useful Post:
Diode Dynamics (09-24-2013), LSxJunkie (09-24-2013)
Old 09-24-2013, 08:53 AM   #655
n2oinferno
Praise Helix!
n2oinferno's Avatar
Okay, let's talk some reality then.
Name any new entry level rwd sports car that slots in below twins or the MX5. I don't want to hear the "but... but.. the Subaru isn't entry level!" because it is. It's the same car with a couple of extra features. Like a PRHT Grand Touring MX5.
The MX5 and the twins are entry level, bottom of the barrel sports cars. This is not a bad thing, it just means that everything else goes up from there.
The Following User Says Thank You to n2oinferno For This Useful Post:
Old 09-24-2013, 09:06 AM   #656
Mikem53
Drives: FR-S 6MT
After stepping out of my C6 into an FRS.. "Bottom of the barrel" sport car is a bit harsh. It's actually a minimalist sports car, a purist approach.
Less grip, less power + low weight = realistic affordable sports car.
Old 09-24-2013, 09:30 AM   #657
n2oinferno
Praise Helix!
n2oinferno's Avatar
It's only harsh if you take it that way. It's not meant as an insult, it's meant that it's the most entry level.
Minimalist imo would be a Lotus Elise, or even better, the Ariel Atom. The Vette doesn't have a great interior, but what puts it a league above the twins is the performance. The new one makes that gap even wider.
Old 09-24-2013, 09:47 AM   #658
Mikem53
Drives: FR-S 6MT
Those examples are not really practical ones. The FRS is very practical, in relative terms compared to the Elsie and atom.
Performance is also a relative term. I always had to hold back with the vette..
Never being able to utilize the power and grip in everyday driving. Put your foot in it for more than 3 seconds.. And it's off to jail in cuffs. The FRS has useable power and handling for everyday fun! I seriously enjoy this car more than my last few high dollar, high powered machines..
I don't worry where I park it, LEO's , new tire cost.. Etc.. Sometimes less is more.. And a lot more fun!
2014 Chevrolet Camaro Z/28: The Trans-Am Racer Returns! JPxM0Dz Other Vehicles & General Automotive Discussions 53 02-24-2016 10:55 AM
OEM Chevrolet Corvette 17x9.5 +56 BII302 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 06-07-2014 01:52 AM
Marc08EX Detailed: 2007 Chevrolet Corvette Z06 - Black Marc08EX Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 07-11-2012 10:57 PM
2011 Chevrolet Corvette Z06 Carbon slots in right below ZR1 vh_supra26 Other Vehicles & General Automotive Discussions 2 03-14-2010 09:09 PM
