#29 |
I had a '05 G35 6MT and I could swear that the reverse was on the left near 1st. LOL I guess it's been awhile...
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#30 |
Glorious BRZ Master Race
Drives: Subaru Libird
^Yeah it's on the right side for G35.
My 2004 Celica GT-S had Reverse it on the upper left. But I always had to muscle against a tough spring in the linkage to jam it in there. Thank you Subaru for giving us a collar ring, thank you.
#31 | |
I haven't had a MT car that required a pull on a spring/lever since I took over my older brother's VW Scirocco 16V way back in the day... I personally prefer the BMW method where you have to exert a decent amount of force to get the lever into reverse, but I'm sure I can get used to pulling a spring/lever again. As long as they both work I'm good!
#32 |
I usually post drunk
It's more convenient, as long as they have the lockout which appears to be on the shifter there.
#33 |
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
if you mean that they accidentally toss it into revers, they can't because there is a cable lock out on them. Some have pull collars and some need for the shifter to be pushed down.
#34 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Everyone should just be glad it's not a Dog-Leg 5spd....
- The Ancient BRZ Sacrament by Zaku |
#35 |
#36 |
Drives: Toyota Aristo
Toyota has always had this when they have done 6 speed voxes... very 90s nothing new at all.
This will have a pull colar just like my corolla07 pretty sure STI has a pull colar as well |
#37 |
i'm sorry, what?
Drives: Canada
[u2b]hakNxO5pME4[/u2b]
#38 |
#39 |
Drives: Attitude
There's plenty of nice 5MT units out there. I don't see the reason for 6MT elitism. For instance, take the WRX and STI transmissions. Some people break the 5MT, though for the most part you don't see that anymore until higher power levels (~400hp); however, the STI 6MT is nearly indestructible by most accounts. It also weighs a ton more, but what I want to talk about is the ratios. People think 6 gears = low highway cruising RPM. The WRX 5MT and STI 6MT cruise at nearly the same RPM in their terminal gears; the difference is the closeness in ratios between the two. Personally, I find the ratios of the 5MT to be spaced more naturally than the closer geared 6MT.
Like I said though, it's all about the gearing. Take the Charger 5MT unit: some of the worst spacing out there. In fact, from what I saw of the JDM 6MT ratios for the GT86, 5th and 6th gear ratios aren't even really that low. Hell I think the spec sheet showed 6th as 1.000! |
#40 | |
Drives: Toyota Auris
I don't even know how my car would behave. I'm afraid there is no safety mechanism, and some nasty noises would be heard if one were to "test" it (not me, no chance!) Btw, I know old cars with 4 speed gear boxes that had the reverse... you guessed right, where the "5th" would be (right and up). No cable lock or anything on those... just unsynchronized reverse pinions trying to engage. OrbitalEllipses: "People think 6 gears = low highway cruising RPM" Well, I hope it would mean low highway cruising RPM. From what I've read (too lazy to check the numbers myself) it should be around 3000-3300rpm (instead of well over 4000 for my current car). |
#41 |
Drives: Attitude
Obviously I don't want to be a 2000rpm at 80mph in 6th with the amount of torque this car makes. An American engine is a different story...pushes you into the seats at any RPM
#42 | |
Drives: '06 AM V8V Coupe
If a G35 did 3200rpm at 80, that's way too many rpms. A Honda 3.5L with 5 speed auto on the Pilot or Accord does 2600-2700 at 80. This car is going to do about 3100 at 80 with the 3.727 f/d. |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 02:40 AM |
| Good 'ol Fifth Gear | Guff | Other Vehicles & General Automotive Discussions | 15 | 12-08-2011 09:20 PM |
| nurburg and top gear | fatoni | Other Vehicles & General Automotive Discussions | 17 | 11-06-2011 07:03 PM |
| Top gear USA | 4agze | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 12-08-2010 11:01 PM |
