Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 09-22-2013, 05:41 PM   #1527
jdmasfcuk
jdmasfcuk's Avatar
Drives: Toyota 86 ZN6
^^ twins
jdmasfcuk is offline   Reply With Quote
Old 09-22-2013, 11:42 PM   #1528
86ers
86ers's Avatar
Drives: GT 86 C7P
Originally Posted by pcuerpo View Post
thanks @NIKDENG and @Tye300 for the clarification! so mali pala yung sabi nung guy when he was explaining things to me when i was getting the car, di pa pala naka DRL, even confirmed it to him so i guess i have to get that relay too.. booooo!
Exactly, my dealer SA dont know how to activate drl on my 86,
As previously they said its working. During my 1k pms, i ask him
To activate my drl, the SA ask another guy to check what i wanted
To do with the drl, and this guy also know nothing about this.
And finally teach him what to do step by step as i learned from this forum
And then this technician ask me where Did i learn that thing
I tell him "basa basa lang pag my time"
And then agreed to order me a relay, 2 weeks waiting to arrive. Just sharing.
86ers is offline   Reply With Quote
Old 09-23-2013, 12:30 AM   #1529
jdmasfcuk
jdmasfcuk's Avatar
lol... yung toyota mech sa casa dito samen d alam san yung oil filter.. tatlong beses tinaas sa lift para hanapin yung oil filter. sabi ko "yun oh"
Old 09-23-2013, 12:44 AM   #1530
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
@pearlhatchiroku, so pano yung grommets? did they provide you with those?
@86ers, sabi nga nung SA din sakin who said na naka DRL na, naka turbo yung 86 oo na lang ako lol
@jdmasfcuk, lol yun pa naman una kong napansin nung ineexplain sakin mga bagay sa engine bay before leaving since the oil filter was Subaru
pcuerpo is offline   Reply With Quote
The Following User Says Thank You to pcuerpo For This Useful Post:
jdmasfcuk (09-23-2013)
Old 09-23-2013, 03:24 AM   #1531
86ers
86ers's Avatar
Drives: GT 86 C7P
Originally Posted by NIKDENG View Post
They are used to plug the two tie down holes in the rear subframe which are used during the transportation of the cars from the factory. It should have been done as part of the pre-delivery inspection by the casa:
Thanks to Sir Nikdeng indeed a very use full post. kaya pala minsan i smell smoke inside kahit hindi nag bukas ng window or door.
i locate the grommet inside the hole mismo. i use small mirror and flashlight
nakita ko yung rubber sa hole at dinukot ko na lang, the other side naman its not vissible kaya kinapa ko ng daliri ko at ayon nakuha ko at installed it properly.
The Following User Says Thank You to 86ers For This Useful Post:
Old 09-23-2013, 10:50 AM   #1532
pearlhatchiroku
pearlhatchiroku's Avatar
Drives: pearl white eighty six
yup, i mentioned it when i went to check the car when it arrived at the dealership, then when i came to pick up the car the next day my agent told me they already installed it
pearlhatchiroku is offline   Reply With Quote
Old 09-23-2013, 09:49 PM   #1533
jsc1234
Originally Posted by pa3ck32 View Post
Congrats!
Check that the rubber stoppers/grommets are installed under your car.
It was not installed on my brz when I got it. Nasa glove box yung rubber stoppers. My agent didn't even know what it was for so I just installed it myself.
I think there was a post about it here somewhere before.
i have this problem after my kw v3 also rear left. any of you guys find solution?
jsc1234 is offline   Reply With Quote
Old 09-23-2013, 11:32 PM   #1534
NIKDENG
Drives: RED BRZ
There are two different types of plugs that you have to look out for that the CASA usually misses out on. The first is the subframe plugs as pictured by @86ers:
Details for this part is as follows so that the dealer can get the part for you if it is missing:
Part No: SU003-02911
Part Name: PLUG TIE DOWN
The other plug is for the rear boot struts which I think is what @jsc1234 is missing. You can easily check if you are missing this part by lifting the carpet on top of the shock mounts in the trunk:
This plug prevent water from entering the trunk through the top of the rear shock assembly. Details for this part is as follows:
Part No: SU003-03038
Part Name: PLUG D40
NIKDENG is offline   Reply With Quote
The Following User Says Thank You to NIKDENG For This Useful Post:
jdmasfcuk (09-24-2013)
Old 09-24-2013, 02:30 AM   #1535
pa3ck32
Drives: WRB BRZ
There really are no clips on the holes on the lower rear bumper area. The holes are used for the addition of a body kit or mudguards. If you are annoyed by the holes, you can buy these generic plastic plugs from a hardware store.
Thanks @NIKDENG
pa3ck32 is offline   Reply With Quote
Old 09-24-2013, 01:29 PM   #1536
Alabang BRZ
Watch fifth.gear.s23e02. Tiff and Vicki pit the RenaultSport Megane against Toyota GT86.
Unsurprising who wins.
Alabang BRZ is offline   Reply With Quote
The Following User Says Thank You to Alabang BRZ For This Useful Post:
Tye300 (09-25-2013)
Old 09-26-2013, 12:04 AM   #1537
jsc1234
Part Name: PLUG D40
found my problem thanks @NIKDENG
Old 09-29-2013, 10:28 PM   #1538
dhoeze
Drives: Toyota 86
Finally was able to join the Yellowcab EB... See you guys sa mga next mini ebs.
Godspeed!
dhoeze is offline   Reply With Quote
Old 10-02-2013, 11:54 AM   #1539
WhitePlainsBRZ
Drives: WR Blue Mica Subaru BRZ
Hi guys!
I need help.
I received a brand new Blue BRZ last August 28, 2013 from Motor Image Pilipinas Greenhills. This was a replacement of the Subaru WRX STI A-line hatchback I bought last March from them. They replaced my WRX STI with the BRZ plus cash (for private reasons I won't mention here).
Since I had to choose from one of their models, I chose the blue BRZ with the intent of using it and selling it after they release the new WRX STI with its new design.
After I picked it up from Motor Image Pilipinas Greenhills, I drove it straight to the custom bodykit installer/fabricator. (August 28)
Since then, the car has been at their shop for the installation of the Rocket Bunny version 1.0 kit with modified custom ducktail (which looks like the wing from Rocket Bunny 2.0) and a modified custom front bumper (again which should look like the front bumper of the Rocket Bunny 2.0).
I ordered the Rays 57Xtreme (Matte Gunmetal) 18x9.5 (front) and 18x10.5 (rear) from the U.S. and buying the Nitto Invo tires (235/40/18 front , 265/35/18 rear) along with PCD converter, spacers and F1 Rays lugnuts from A-toy Customs.
I have ordered a bunch of items all for the purpose of using this car until the new WRX STI arrives. I have all the parts I ordered from the US along with the HKS Supercharger kit and the AirRex/AccuAir TMP+1 package.
However, it has come to a point where I was late in finally realizing that I wanted to get another car since I have the opportunity to get it - depending on the resale value of my BRZ and parts.
I hope you guys can help me refer me to those interested in getting a Subaru BRZ.
Can you help me determine a reasonable price for this?
Breakdown of my expenses:
Blue BRZ - 1.928M
30 kilometers only.
Premium Insurance - P59,300
Back-Up sensors from Subaru (supplied and installed by MIP Greenhills) - P25,000
Vkool VK70 clear full tint (installed and supplied by MIP Greenhills) - P35,000
Sub-Total: P2,047,300.00
Brand New Rays 57Xtreme Matte Gumetal 5x114 18x9.5 +22 offset (front) and 18x10.5 +12 offset (rear) with Brand New Nitto Invo tires (235/40/18 front, 265/35/18 rear), lugnuts, PCD convert with spacers,
Rocket Bunny Kit modified installed and painted - P450,000
Total: P2,497,300.00
I have spent this amount for the car with currently 30 kms mileage.
Would you help me decide a reasonable selling price for something that is practically brand new - Motor Image Pilipinas Greenhills (13kms reading) to West Ave with currently 30 kms mileage?
Obviously, I want to get every cent for what I paid for. However, I hope you can help me get a reasonable selling price for this? This is a car ready to be driven by the new owner. No more waiting time for the bodykit installation and trouble of ordering for imported parts and customs duties troubles (approx 1 month of your stress erased already).
Thank you for reading guys.
Is 2.3M reasonable enough - almost 200K savings for something that has 30kms mileage and already modified?
WhitePlainsBRZ is offline   Reply With Quote
Old 10-02-2013, 12:30 PM   #1540
Ojokik
Drives: Toyota 86 Silver Metallic
@WhitePlainsBRZ
Can you post the pic of your BRZ?
Thanks!
Ojokik is offline   Reply With Quote
