Old 08-09-2013, 07:47 PM   #99
DaBrz
Mines rattles also, but it's due to aftermarket exhaust. Trying to figure out how to stop it... I stuffed napkins in areas I think it would rattle and it worked for a few days, but now it rattles again.
DaBrz is offline   Reply With Quote
Old 09-18-2013, 11:27 PM   #100
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
I had a horrible buzzing/rattle coming from the passenger side footwell - I thought it was just crap in my glovebox or the box itself, but I removed the whole assembly and it wasn't that.
Low and behold, it was the plastic blower motor housing. I contorted my way upside down under the passenger side dash and took out the blower motor to give it a good talking-to. (Unplug the electrical plug, loosen 3 screws, drops right out).
Looks like this:
Flip it upside down and you'll see a little plastic panel on it:
To backtrack for a second, knowing that I had to fix a rattle, I purchased some sticky-backed black felt at a local craft store (Michael's). It came in thin 9x11in sheets and was like $2.99/ea. Excellent for stopping vehicular rattles.
I popped open the little plastic panel with some body panel tools and wrapped the edges of the door in felt. Because the felt is so thin, the panel clicked shut again no problem.
Just incase it wasn't just the panel rattling, I put little round pieces of felt (I cut them) on both sides of the screw holes, where the screw touches the plastic and where the plastic meets the rest of the housing.
I reassembled it and hoped for the best. The rattle was constant before and in 2 days, I haven't heard it at all, so I'm guessing this solved it. My sanity can now slowly return.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
The Following 3 Users Say Thank You to wdninja For This Useful Post:
Lord09 (02-23-2016), PNW FRS (05-22-2015), Shagaliscious (11-19-2013)
Old 09-19-2013, 12:10 AM   #101
Boringmechanic
Drives: Scion FRS
This seems to be fairly common with the frs, one thing i was told was that scion tried to buld this car with out going past the 25k mark, so i think they had to cut corners perhaps just a tad, like interior paneling insulation ect. My Scion TC2 had 30,000 miles on it and it had a lot of creaks and rattles to so maybe its just something scion isnt quite on top of. Simple solution... EXHAUST SYSTEM!!! :}
Boringmechanic is offline   Reply With Quote
Old 09-19-2013, 01:29 AM   #102
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
Was driving mine today, and they're just now starting to get ridiculous.
First it was the drivers door lock, if I locked the door it fixed it though, but now it has come back, even while locked, with a vengeance.
I had the rear deck lid rattle and solved that (for now) by spraying some WD-40 in there.
Now my head unit has a rattle, there's another rattle that sounds like it's coming from the vicinity of the driver's side rear-view mirror.
Also I was getting odd wind noise on the passenger side window.
Don't get me wrong, I still love the car, but I feel like I'm driving the story of the telltale heart at some points.
Mandy is offline   Reply With Quote
Old 09-19-2013, 10:37 AM   #103
gily25
Drives: Silica BRZ 6MT
If you've ever taken apart a vehicle that's on it's second or third generation and you find little pieces of sticky foam or a strip of deadener (I'm talking oem, not used car fixes) then you're seeing the development of first year car woes. If you're determined you can buy some weather strip and dynamat/raamat/etc. and get to town.
The weight of this car was extrememly important in development, they've taken out some bracing/skeleteon you might see in a sedan or lux line car, that leaves less places for body panels to be secured. Just look at how few places you have to unscrew to take the door card off compared to a Camry or Civic. That and essentially the rear interior is primarily held in by the rear seat?! Some companies are already making upgrade items that will probably be incorporated in future generations, like heavier rear decks instead of the shaky oem cardboard one.
gily25 is offline   Reply With Quote
Old 09-21-2013, 11:21 AM   #104
frslee
Just drive it
Drives: 13' FR-S
Winter is coming, prepare for rattle.
frslee is offline   Reply With Quote
Old 09-21-2013, 05:58 PM   #105
thebus
Drives: Whiteout
I plan on parking it for the winter, both my doors rattle sounds like they're not tight enough or bouncing.. My gauge cluster cover just started.. I'm just turning up the music disappointed with all the rattles but every time I open her up and hit some turns I don't care haha
thebus is offline   Reply With Quote
Old 09-21-2013, 06:03 PM   #106
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Originally Posted by sevi21 View Post
i have a few minor rattles under heavy acceleration due to deep exhaust note...but
barely noticeable. One that is quite annoying is the visor on the driver side, i just hit
it every once and a while lol
Ah yeah the driver side headliner under the visor.. I wonder if some sound dampening can get rid of that.
mike_ekim1024 is offline   Reply With Quote
Old 09-21-2013, 06:21 PM   #107
Luis_GT
Rear Deck Popping... and my passenger side speaker whenever I have the base set to 2 bars over flat...
Old 09-21-2013, 07:37 PM   #108
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Rear Deck rattle - Fixed with WD40
HVAC rattle - Only rattles over bumps
Drivers side rattle - I believe its coming from the fuse box area. I pushed against it when I'm driving and that eliminates the rattle.
sprintertrueno86 is offline   Reply With Quote
Old 09-21-2013, 08:06 PM   #109
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
I'm experiencing rattling where the third break light sits. On top of that, I also hear some tapping sound coming from the trunk. The sound becomes more noticeable when the rear seats are folded.
Jolaessss is offline   Reply With Quote
Old 09-22-2013, 12:15 AM   #110
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Rear deck not popping anymore. Dupont fast drying teflon spray lube.
Used the red tube and sprayed around the welds I could reach easily in the trunk.
Penetrates quickly then the carier dries fast.
Didn't even pry things apart or punch stuff.
I've been using the older formula on my motorcycle chain for several years with great success.
Can't use the new formula on chains, but I think it would work fine for curing the deck pop.
Old 09-22-2013, 09:08 PM   #111
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Shit i dont know but its getting worse i think
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 09-22-2013, 10:09 PM   #112
Gen
Drives: Scion FR-S
Is it the visor itself or something inside the headliner? There's a number of wires in the headliner itself that could come loose. Just tape 'em back up. If it's the visor itself, adjust the visor on the pivot pole thing (whatever it's called) so that there is less play.
For what it's worth, I've never in my life ridden in a car that did not have rattles, unless someone specifically spent time getting rid of them. Everything from Porches, M3s, Mercedes, to Toyotas and Mazdas...every one of them rattled if they had over 15k on the clock. I consider it a maintenance item. Stiffer suspension = more likely to rattle as well.
Gen is offline   Reply With Quote
'Fluttering'/soft rattle at speed Symbiont BRZ First-Gen (2012+) — General Topics 35 12-22-2016 02:23 PM
Does anyone have a rattle coming from the center dash? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 29 09-30-2012 11:09 AM
Door Rattle Issue DriftEightSix AUSTRALIA 4 06-28-2012 02:11 AM
Rattle in door speaker panels Lefty Electronics | Audio | NAV | Infotainment 2 06-18-2012 07:41 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 08:46 PM
