Old 09-21-2013, 03:48 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Optimal tire pressure for handling with stock Michelin tires
35psi cold seems too high and the steering feels a little light. What pressure have people found makes the most of the stock tires?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 09-21-2013, 04:05 PM   #2
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
whatever on the sticker.
hanabie is offline   Reply With Quote
Old 09-21-2013, 04:06 PM   #3
brillo
35psi is what is on the sticker
Old 09-25-2013, 12:31 PM   #4
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
what exactly does "cold" mean. 50*F or no heat in the tires from driving. IM curious because my TPMS light came on after the cold front last week and I need to inflate.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 09-25-2013, 12:38 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
cold is ambient temperature
also where did you get 35psi from? That's what i would recomend for a quick fix at an autocross
dial it down to around 28 and be happy.
Old 09-25-2013, 12:53 PM   #6
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
What brillo said.
My BRZ
Old 09-25-2013, 12:58 PM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
right!
35 is correct on the sticker
i was thinking of my old vw which had 70 aspect tires.
honestly 35 is fine, not sure what you mean by light, car's pretty solid steering. Maybe you drove a car with stiffer/gripper tires before?
Old 09-25-2013, 01:37 PM   #8
wparsons
wparsons's Avatar
35 is a good starting point, but to really get optimal grip you need to be reading the temperature across the width of the tire to see if certain parts are heating up more when lapping/racing. For the road, just stick with 35.
flickr
Old 01-22-2016, 03:55 PM   #9
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
I don't know which of the many threads has the most visibility, but I figured I'd add my two cents in one of them... For us with actual seasons, I see 35 PSI @ 50F as optimal. That way you have more contact patch at a lower PSI for snow/ice. Then when it's nice out, you can have less sidewall flex when cornering at higher speeds in dry conditions.
Weigaldo is offline   Reply With Quote
Old 01-22-2016, 03:58 PM   #10
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
I do -3 to -5 on most of my cars for looooong trips. When tested under heat, it's usually where it needs to be. I noticed better mpg on our Rav4 when i took air out.... havent tested FRS.... will do it in coming week for 3-4 gas tanks.
I'd say -3 to -5 when cold so that there is more surface area=more friction=more loud interior but feels nicer in corners? (grip-wise)
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 12:01 PM
Recommended Tire Pressure for Aftermarket Wheels and Tires Chri5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-15-2013 01:28 PM
Looking to buy. 1 stock brz Michelin Primacy HP tire Norcalmav23 Wheels and Tires 0 05-02-2013 01:37 PM
Stock Michelin Tire Warranty? EAGLE5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-29-2013 05:15 PM
Optimal Tire Size For Stock Rims Raven604 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-05-2013 08:41 PM
