Old 09-19-2013, 11:34 AM   #1
Gani21
Gani21's Avatar
Drives: Blue Frs
Lightweight crank pulley on an AUTOMATIC
Has anyone done this already? will i run into problems such as smoking out the torque converter, just bought a perrin one and im a bit uneasy if this will break things. also whats the name of the tool to hold the pulley in place for this motor? thanks guys
Gani21 is offline   Reply With Quote
Old 09-19-2013, 02:54 PM   #2
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Yep I've been running a Perrin pulls for over a year with no issues. I don't think there should be any concern about you're torque converter. It makes a difference, but not that kind of difference.
Old 09-19-2013, 03:51 PM   #3
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
When i presented the idea of buying one for an automatic i was told that it wouldn't make a difference whatsoever so i'd be wasting my money
Obja is offline   Reply With Quote
Old 09-19-2013, 04:24 PM   #4
wlfpck
Drives: 2015 GTI
How would it have no difference? The fact that you are reducing the rotational mass would definitely make a difference.
The real question is how much of a difference. In which, others can chime in on their experiences.
2013 GTI - Gone
2015 GTI
wlfpck is offline   Reply With Quote
Old 09-20-2013, 04:47 PM   #5
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Have the Go Fast Bits pulleys set installed on AT. No issues so far, although no considerable difference either. I mean there is difference, the engine feels a bit "lighter" and responsive to the acceleration pedal, but far from "day and night" improvement.
To remove the stock pulley you ideally need something like this:
http://www.company23.com/index.php?r...&product_id=51
But in fact what is required is a metal rod with 2 "fingers"/bolts which could be inserted simultaneusly into any 2 of the 4 holes on the stock crank pulley to hold in place while unscrewing the bolt.
Efferalgan is offline   Reply With Quote
Old 09-20-2013, 04:56 PM   #6
Jvalich
Drives: '13 Subaru BRZ Limited
I have about 15000 miles on a Perrin Lightweight pulley with no issues. No night and day difference but the engine did feel a touch more responsive. Taking away rotational mass can't really hurt... can it?
JV
White 2013 BRZ Limited auto6, Perrin LW Pulley
Manga Flow CB Exhaust, Motive Master Cylinder Brace
K&N filter, Meagan Racing Strut Bar, P&L Motorsports SS Brake lines
Jvalich is offline   Reply With Quote
Old 09-21-2013, 08:43 AM   #7
troek
troek's Avatar
Drives: 2012 Toyota 86
haters gonna hate
troek is offline   Reply With Quote
Old 09-21-2013, 02:57 PM   #8
Captain Insano
That makes absolutely no sense whatsoever. Not chastising you, more just indicating somebody gave you bad info. Losing rotational mass on any car is good, including automatic transmission cars. Do lighter wheels help AT cars? Do lighter drive shafts help AT cars? Do light weight parts in general help AT cars? These are rhetorical questions, the answer to all of these questions is "yes".
And for those comparing, this won't make a night and day difference on either an auto or a manual. It will make a slight difference in responsiveness as people have indicated (I've run pulleys on past MT cars). This for either an auto or manual. For the cost, I do consider pulleys a worthy mod for either an auto or manual.
Captain Insano is offline   Reply With Quote
The Following User Says Thank You to Captain Insano For This Useful Post:
Obja (09-22-2013)
Old 09-23-2013, 02:24 AM   #9
Gani21
Gani21's Avatar
Drives: Blue Frs
ive heard thing about the torque converter smoking out due to way too much weight being taken off. i just wanted to see the peoples experience with the aftermarket pulley on their AT cars. also will it throw off the check engine light and how did you guys who have it on your car get it on in the first place?
Old 09-23-2013, 03:18 AM   #10
Hawk77FT
Drives: GTS 86
Your answer reminds me of this guy:
Hawk77FT is offline   Reply With Quote
Old 09-23-2013, 08:56 AM   #11
neutron256
neutron256's Avatar
A crank pully tool is needed to install in on an AT which basically just allows you to hold the pully still while while allowing access to the bolt. I got the one from Grimmspeed. I've been running my peering pulley for over a year now and have had zero problems with it.
Old 09-23-2013, 06:39 PM   #12
Gani21
Gani21's Avatar
Drives: Blue Frs
Can anyone show me how to install it?
Old 09-23-2013, 07:07 PM   #13
neutron256
neutron256's Avatar
Just check out the DIY. It's exactly the same as the MT except you need a tool to hold the pulley still while you loosen/tighten the bolt.
Old 09-23-2013, 07:28 PM   #14
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
Should have gotten a manual?
Plxdjake89 is offline   Reply With Quote
FS: Perrin lightweight crank pulley tmccoy33 Engine, Exhaust, Bolt-Ons 1 09-12-2013 04:52 PM
WTB: lightweight crank pulley (purchased) blue_frs Engine, Exhaust, Bolt-Ons 4 07-29-2013 05:33 PM
FS: Kartboy Lightweight Crank Pulley OrbitalEllipses Engine, Exhaust, Bolt-Ons 6 03-21-2013 08:21 AM
My lightweight crank pulley experience WolfsFang Engine, Exhaust, Transmission 22 11-29-2012 02:15 AM
Ralco RZ Lightweight Crank Pulley HELP! JERZgrl88 Engine, Exhaust, Transmission 11 10-10-2012 12:41 PM
