Old 09-19-2013, 09:03 AM   #127
regal
Drives: Scion FR-S/Toyota Yaris
Anyone on 0w20 have torque? Reputable report being made of a drop in oil pressure at high rpms with 0w20, my car is in the shop or I'd check this.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-19-2013, 09:06 AM   #128
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Stock Oil Pressure sensor does not read Oil pressure range, just an on/off switch when pressure is low, so torque is no good.
Old 09-19-2013, 12:12 PM   #129
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Also actual oil pressure isn't very relevant. Oil pressure relates to flow, not oil protection. Lower pressure is good, not bad, as it indicates higher flow rates which is good not bad.
Oil protects by forming a flying wedge in the bearings and oil pressure just has to be high enough to push the oil through fast enough to stop it overheating within the bearing.
Sliding components (such as rings) require only enough pressure to splash the bores. Oil protects those purely by film strength, also not related to oil pressure.
There's a reason oil pressure gauges are no longer fitted, and coolant temperature gauges aren't actually gauges anymore. Lay people misunderstand what the engine needs: low oil pressure and high coolant temperature. This is the opposite of what we used to think was required.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
Sportsguy83 (09-19-2013)
Old 09-19-2013, 12:19 PM   #130
regal
Thanks I forgot that the oil sender is just a switch.
I went to google found fastwrx.com and they sell everything needed to install an oil pressure gauge in the left vent :
Name Code Qty Each Options
Oil Gallery Plug 05791 1 11.00
ATI 60mm vPod Gauge Mount 08187 1 39.00
Prosport Oil Pressure 05388AM 1 55.00
Subtotal 105.00
Mods:
Old 09-19-2013, 12:42 PM   #131
Sportsguy83
Drives: Limited BRZ
Subtotal 105.00
Awesome! I sold it all a few weeks ago:
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play!
Old 09-19-2013, 01:14 PM   #132
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Subtotal 105.00
Another option, if you were looking to monitor a other components, would be the P3Cars vent gauge along with the AEM Pressure Sensor and that oil galley plug. Sure it costs 3x as much, but you can then monitor oil temp, oil pressure, AFR, coolant temp, EGT, vacuum, boost, 0-60 time, etc. so I suppose when all things are considered, you're getting a lot more functionality. However, if you're only concerned about oil pressure then the solution you provided is a good one.
FWIW...i've been running 0w20 Eneos Sustina since I purchased my car new. I've posted 2 UOAs in another thread. I'll be changing the oil this weekend sticking with Sustina but changing the filter from Mobil1 to the stock Subuaru filter. I'll be sure to post the 3rd Sustina UOA once it's received.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
viscositosis.rex (10-16-2013)
Old 09-19-2013, 03:05 PM   #133
frs10
Drives: tezla
how long have u guys been keeping the break-in oil for?
frs10 is offline   Reply With Quote
Old 09-19-2013, 03:44 PM   #134
bluesubie
Drives: 2004 Subaru Forester 2.5XT
It ranges anywhere from 500 miles to 5,000 miles.
-Dennis
bluesubie is offline   Reply With Quote
Old 09-20-2013, 09:59 AM   #135
frs10
Drives: tezla
-Dennis
any reason to change the stock earlier than later?
Old 09-20-2013, 01:21 PM   #136
bluesubie
Not in my opinion. Some people think they need to "get all of the metal bits out", but the truth is that the manufacturing process is so good there are very little leftover metal bits in a new engine. What is there (e.g. 60 parts per million of copper) will be trapped by the filter anyway if it's large enough to be harmful to the engine.
Truth is it takes 3-4 oil changes to get even this tiny amount of metals out. And I would want the more robust factory fill to be in the engine longer (at least 5,000 miles). Idemitsu says to follow the manufacturers (not the dealer or some random person at ft86club ) recommendation.
-Dennis
Old 10-07-2013, 06:30 PM   #137
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Eneos Sustina 0W20 First UOA
My first test with 6,646 South Florida Miles
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-07-2013, 11:46 PM   #138
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Nice tony, pretty convincing!
Old 10-08-2013, 07:44 AM   #139
tonystewart
Will the new Cusco Oil Cooler decrease the breakdown of the oil?
Old 10-08-2013, 09:04 AM   #140
bluesubie
Possibly. Although, with a fuel dilution reading of a trace and the flashpoint right on the edge of where it should be, fuel from the DI will probably take more of a toll on the oil than anything. TBN was "ok" at 2.0 although some labs will flag it as abnormal at this point or at anything below 2.0.
The insolubles reading is amazing! What oil filter are you using? I'm guessing that this was only your second oil fill on the car (after draining the factory fill). What oil is in the car now? Regardless of what Blackstone says, I would be very cautious about pushing the intervals beyond 6k miles until you establish a trend (maybe 3 uoa's at 6k miles).
-Dennis
eneos sustina 20valvewynn83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 01-04-2013 09:43 PM
Delete driver01 CANADA 5 08-30-2012 04:58 PM
Good price for Eneos 0w-20? Gregory Gawaran Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-26-2012 01:38 PM
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 3 07-08-2012 01:04 PM
Free Shipping on ENEOS Oil KronosPerformance Engine, Exhaust, Bolt-Ons 12 06-22-2012 06:17 PM
