| Engine Swaps Discussion of engine swaps. |
#29 |
Drives: 2013 Asphalt FR-S
So, if the fa20t is in production now, there should be a service manual floating around some were that would answer many of these questions yes....
~Namaste~ |
#30 | |
Drives: Scion FR-S/Toyota Yaris
I am right 80% of the time and wrong the other 80%. Of course opinion and conjecture is what everyone posts, everyone on here its what sparks discussion and a good thing. Avo is the largest turbo kit supplier for the Twins they even advertise that fact, they would be my first choice as if a wanted to turbo charge a 12.5:1 NA Subaru engine, their oiling system for the turbo sets the standard. If Avo knows more about this swap please divulge the findings ), because speculation and what not is not going away, this is Subaru's leading engine going forward, its a big deal for them.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#31 | |
I Love custom Turbo kits
Drives: Limited BRZ
Generally, people make it clear whether its opinion or fact. I'm just inviting you to make it clear with a simple IMHO, instead of making it seem written in stone facts
#32 | |
And the service manual is available from the usual torrent sites, I've been admiring the engine for a while now. Its quite a piece of engineering. A little 2L powering a heavy heavy Forester is an impressive accomplishment for Subaru.
#33 | |
Drives: Limited BRZ
90% of us flunked it ![]()
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | DriftEightSix (09-19-2013) |
#34 | |
Drives: Skoda Yeti DSG diesel 4x4
#35 | |
Add lightness!
Drives: 17' WRX
Until they massage this motor for the wrx/sti, it looks like a waste of time to me. At minimum, it looks like you'll need a set of proper cams. People around here complain that the FA20 power drops off a cliff at 7000rpm. The DIT verison does the same thing at 4800rpm. It's not like you'll be able to bolt on a downpipe and flash to stage 2 and get great results with the new motor. There is no real downpipe anymore and it looks like the turbo has very little headroom. ![]() ![]() Can we stop talking about putting this truck motor in our cars for now? |
#36 |
I don't know about anyone else, but until pure DI systems find a proven way to prevent valve fouling, I'll stick with a mix of port and direct injection.
| The Following User Says Thank You to wparsons For This Useful Post: | 200hp/tonne (12-16-2014) |
#37 | |
Drives: Limited BRZ
![]() ![]() ![]() ![]() QFFT (quoted for effing truth!)
#38 | |
Drives: 01 RS, STI V6 RA Limited, BRZ
I owned a Subaru shop for ten years. This new motor is the THE BEST motor Subaru has ever made. I have a GTX28 on my car and it spools way faster then the same turbo even on the 2.5 STi engines. The direct injection is fantastic. I'm at 300 whp on only 8 lbs of boost with no end in sight for injectors running out of headroom. No swap needed, just bolt on some boost. |
#39 | |
Yea I bought into the proven D4-S, multi-port +DI track record, but the torque dip is frustrating and the dang tip-in knock I'm not so sure its worth it. Sure the Foresters FA20T is tuned a little truck-like, but our FA20 is no F20C, this FA20T has a lot of potential. First everyone was saying the cams and head are the same, now you're saying I was right but they are too different? This is the direction that the entire automotive industry is heading IT. Fast spooling small turbo, flat torque curve, not super high revving. Isn't it slated to show up in the WRX tuned a lot less truck like? If it makes it into the BRZ as the base engine will we still be dismissing it? We can put off discussing this factory ~300hp FA20 variant as long as you all wish but it isn't going away. IMHO people want to ignore Subaru's accomplishment here because it not only slaps in the face of Tada's mandate against Subaru's wishes to turbo the BRZ but it also hurts a little for those investing in an aftermarket turbo FA20 build so early in this platform's life cycle. The reason many of us bought the FRS was low entry rwd sports car platform with future upgrade paths. When you bought a 240sx in 1990 would you ever have guessed the unlimited potential of that platform? Its much too early to be closed minded with these cars.
#40 | |
So to get the OEM turbocharger assembly to fit, you would need to both cut into your lower front frame, and also completely remove the undertray, as the turbo would be sitting a few inches lower than it. Then you would need to work out how to re-route the exhaust completely from the front of the car back. Putting the turbo long block into the car only really accomplishes *1* thing - lower compression pistons. For the 5k you would spend on the long block to do so, you could easily purchase aftermarket forged pistons to accomplish the same thing. |
| The Following 3 Users Say Thank You to AVOturboworld For This Useful Post: |
#41 | |
Add lightness!
Drives: 17' WRX
Remember we are talking about swapping in this motor on purpose with additional funds. I don't see a good reason why even if it was a straight bolt in. If it came stock with this motor that's a different discussion. |
| The Following User Says Thank You to industrial For This Useful Post: | Sportsguy83 (09-19-2013) |
#42 | ||
Avo you do get more than lower comp pistons. With a DI engine the piston top and head chamber are intricately designed to match, much better than slapping in aftermarket pistons (IMHO). The whole DI system and heads are designed for a turbo. No one is talking about using the FA20T turbo piping or manifold. Its the long block, ecu, and DI that in a years out one could pull from a JY and be a good base for a build. That's all.
| SUBARU 4Pot Calipers "Bremboed" Direct Bolt On- SD, CA CHEAP! | virjose | Brakes, Suspension, Chassis | 32 | 07-12-2013 12:40 PM |
| RallySport Direct's Eat, Greet, Swap Meet 2013 | RallySport Direct | BRZ Photos, Videos, Wallpapers, Gallery Forum | 3 | 05-14-2013 04:31 PM |
| RallySport Direct Eat, Greet, Swap Meet 2013 Edition!! | RallySport Direct | Southwest | 9 | 05-13-2013 06:46 PM |
| RallySport Direct Eat, Greet, Swap Meet 2013 Edition!! | RallySport Direct | Southwest | 0 | 04-03-2013 11:04 AM |
| RallySport Direct Eat, Greet, Swap Meet 2013 Edition!! | RallySport Direct | Rocky Mountains / Great Plains | 0 | 04-03-2013 11:04 AM |
