#15 |
Owner and Operator
Drives: FR-S, Yamaha R6, 1972 Camaro
I am going to see if this helps: http://mystarbrite.com/startron/
I put it in my motorcycles, for other reasons.
-Schifko
#16 | |
Drives: '13 FRS - STX
Could you elaborate about it "not being needed in the winter"? |
#17 | |
Drives: 2013 Argento FR-S
Sent from my XT912 using Tapatalk 2 |
#18 | |
![]() I have yet to see anything definitive, but even at it's loudest the noise was just an annoyance, wasn't going to do anything about it until confirmed failures were reported, so far none yet. |
#19 | |
#20 |
Drives: Whiteout FR-S
Would adding this result in warranty denial?
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#21 |
After the pump issues, I can't imagine them having the stones to do so. On the other hand.... I'd be more worried about it gumming up something else. Found this while googlin' around:
http://www.klotzlube.com/techsheet.asp?ID=51 Klotz Uplon Fuel Lube provides upper cylinder and fuel pump lubrication. Protects the induction and fuel delivery systems from dry, abrasive properties of methanol alcohol. Uplon Fuel Lube increases horsepower by reducing power robbing friction. Seal conditioners maintain constant fuel pressure and prevent lean-out conditions. Blends with gasoline, methanol alcohol and nitromethane. |
#22 |
Drives: 13 Whiteout
I would love for my cars exhaust to smell like BeNol.
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
#24 | |
Company seems a bit off their rockers, but hey whatever helps you sleep at night. http://www.klotzlube.com/Klotz_Diet.pdf |
#25 | |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
Sounds like snake oil to me, I wouldn't expect more HP but if it fixes the crickets and it's safe to burn, more power to you. Either way, I'd rather deal with the crickets and wait for a fix than putting an unknown into my fuel system that's just going to cost money. Especially something that should be covered by the warranty when there's eventually a fix. |
#26 |
Professional Smartass
Drives: White Out FRS
I've been running this stuff for a while now. Lucas 2 stroke low ash. Using 1-2oz in a full tank. It's night and day between a tank with it and a tank without.
#27 | |
#28 | |
It might be snake oil, but if you looked at today's gasoline, especially California's gas, I'd call the gasoline snake oil before i called anything from Klotz snake oil.
Klotz, as far as I know, is one of THE best oil companies. I may be wrong, but I remember when mixing my own Nitro fuels for models, Klotz was the very best oil to add. Today's gas formulations are just stupid, mixed more for emissions than performance, and the addition of ethanol just adds more problems into the mix. A capfull of 2-stroke oil per tankfull will do absolutely nothing negative. Quote:
| 0W-20 full synthetic oil for $3.49 a quart | terrypm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 04-08-2014 04:51 PM |
| Is FR-S oil Synthetic or Conventional? | EBMCS03 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 52 | 01-08-2013 10:37 PM |
| Whats your average MPG now in the winteRnHow far are you going on a full tank of gas? | NickFRS | Northwest | 17 | 12-21-2012 11:59 PM |
| 340 miles and one full tank later... | gunmetal5 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 11-14-2012 09:32 PM |
| %100 Full Sythentic VS Fully Synthetic | ProjectD | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 10-05-2012 01:28 PM |
