Old 09-11-2013, 06:44 PM   #71
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Originally Posted by 1010110 View Post
I installed the cusco oil cooler (MT) along with an innovate supercharger on my car last night. While on the car's shakedown run, which included some spirited driving, the maximum temp reached was 200F. In between spirited runs the oil temp quickly stabilized.
Is this with the stock radiator?
andrewFT86 is offline   Reply With Quote
Old 09-11-2013, 06:47 PM   #72
zoomzoomers
zoomzoomers's Avatar
So it works. Now the true test will be at the track with 110 + temps.
Old 09-11-2013, 07:04 PM   #73
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I really wish it does pass the ultimate test, but find it hard to believe given the surface area.
Eager for results!!
Old 09-11-2013, 07:14 PM   #74
zoomzoomers
Eager for results!!
I'm no expert, so take what I say with a large grain of salt, but if you get this oil cooler from Cusco and upgrade to a larger capacity radiator then you "should" be able to get similar, if not the same, cooling efficiency as a Perrin or Greddy. No?
Also, I noticed that SARD has a oil cooler of their own, but I haven't heard/seen much about it. Have you?
Old 09-11-2013, 07:45 PM   #75
Sportsguy83
Drives: Limited BRZ
Well, it would all be speculation at this point but the main thing here is: in order to cool 6 quarts of oil, you need a large capacity oil cooler because the surface area and the time the oil spends at the cooler are the variables driving the cooling.
Now, using a liquid to liquid solution is more efficient than air to liquid but still, surface area, capacity are very important.
Old 09-12-2013, 11:37 AM   #76
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by tonystewart View Post
Soon
Automatic Transmission Version
Hope this solution works better for you and may you have zero leaks. Will you be at the Southeast86 meet in Orlando next month?
Old 09-17-2013, 12:14 PM   #77
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Just wanted to update this thread as I had asked Cusco to send me info once they released the version for Automatics, and the new cooler is confirmed to work with both Automatics and Manuals.
Check out the PDF they released:
http://www.cuscousainc.com/downloads...il_coolers.pdf
The new part number is 965 012 AN
Thanks!
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
liquidsky44 (09-17-2013)
Old 09-17-2013, 12:31 PM   #78
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Has anyone looked at Post #66?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
M1K3 (09-17-2013)
Old 09-17-2013, 12:37 PM   #79
xjohnx
Grip>Slip
xjohnx's Avatar
what're your thoughts on it?
Old 09-17-2013, 12:38 PM   #80
M1K3
M1K3's Avatar
Drives: vrooom...
Have you installed it yet? And would love to see some before and after Oil Temps if possible.
M1K3 is offline   Reply With Quote
Old 09-17-2013, 12:44 PM   #81
tonystewart
The car is unavailable for downtime till Friday PM, it will be installed and I have my ecutek data logs, both normal and performance runs before temps already done. I will photograph and post during install.
I bought it from FA20club.com, Toni's company is excellent!
Old 09-17-2013, 10:00 PM   #82
keen as
keen as's Avatar
Drives: 86 GT MT
I have installed this kit as tonystewart has pictured.
The car is NA stock
I have tracked it before and after oil cooler at different tracks and different ambient temps.
My impression is that it probably gives 10deg C cooling and matches the graph shown at the pdf http://www.cuscousainc.com/downloads...il_coolers.pdf
Wakefield park with NO oil cooler, stock NA car
Ambient 15deg celcius (59F)
after 6 minutes on track, oil temp peak 128 deg C (262F)
water temp stable around 90 deg C (194F)
That was the end of that session. I think that if the session continued, then the temp would have crept up a bit higher.
Sydney Motorsport Park Eastern Creek WITH oil cooler, same NA car
Ambient 27deg celcius (81F)
after 6 minutes on track, oil temp peak 120 deg C (248F)
The sessions continue for total of 20mins and 120 deg C was the peak. Mostly, the oil temp was between 115-120 deg C (239-248F).
I am happy with the result on a stock NA car.
The instal is very neat. I prefer using radiator hoses and not having oil lines. I also like the idea that when I change the oil, there is no residual oil in the cooler.
I expect that if using on a car with FI on the track, will need radiator upgrade.
keen as is offline   Reply With Quote
The Following 9 Users Say Thank You to keen as For This Useful Post:
1010110 (09-18-2013), jcz (11-07-2015), M1K3 (09-18-2013), normancw (11-04-2013), Sportsguy83 (09-18-2013), Tye300 (11-04-2013), Wepeel (09-23-2013), whataboutbob (06-22-2014), zoomzoomers (09-18-2013)
Old 09-17-2013, 10:36 PM   #83
xjohnx
Grip>Slip
xjohnx's Avatar
has anyone confirmed that the Cusco cooling unit is actually a rebranded OEM cooler? if so, anyone put together a part list yet?
Old 09-18-2013, 02:46 AM   #84
Kostamojen
Yes!
1) Go to a junkyard, find a turbo Subaru from the last 20 years with the Oil cooler still intact.
2) Remove said oil cooler and pay next to nothing for one.
3) Buy some radiator hoses and tube adapter things.
Or you can just send me half of that $600 you would have spent on that kit and I'll do it for you LOL!!!
4) Install on your car... DONE! :P
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
New Cusco oil cooler ahaghshenas Engine, Exhaust, Transmission 11 04-02-2013 10:48 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
