Old 09-16-2013, 11:17 PM   #6259
blubrz
Drives: WRB BRZ
here...I'll get things kicked off.
Sunoco 93 octane on the 93 octane FI Visconti tune. this was just a few minutes of tooling around at various speeds and RPM. Enjoy!
blubrz is offline
Old 09-16-2013, 11:19 PM   #6260
blubrz
Drives: WRB BRZ
My review Thread has 7,757 views and 156 replies, yep, more than enough people has seen them.
Oh but remember, you are too lazy to search
Where is the search by views and replies feature....
blubrz is offline
Old 09-16-2013, 11:24 PM   #6261
blubrz
Drives: WRB BRZ
LOL... please, dont talk about what you have no idea....
intelligence over insult for sure!
[ame="http://www.youtube.com/watch?v=0oaVN0PXwHo"]http://www.youtube.com/watch?v=0oaVN0PXwHo[/ame]
blubrz is offline
Old 09-16-2013, 11:50 PM   #6262
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
blubrz did you catch a case of verbal diarrhea or has a troll broken into your house and sitting on your computer right now???
enouf is offline
Old 09-16-2013, 11:53 PM   #6263
blubrz
Drives: WRB BRZ
you pick!!!
blubrz is offline
Old 09-16-2013, 11:56 PM   #6264
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by blubrz View Post
Sure, the next guy has way better customer service, looks at the knock and adjusts it for shitty gas...
And is that not reason enough to change tuners???? Do you need to wait until the car is rod knocking before you decide to switch tuners?
It's funny you say 2 out of thousands.... ALL of the FI tune logs i have seen from the former super star would make me scared to drive the cars. Period. Granted that is not thousands but it is more than 2. Give it time more people will come forward.
In the interest of fairness, i have seen a few pump gas logs that did not look bad. Not what i would consider worth the money, but not bad.
mad_sb is offline
The Following User Says Thank You to mad_sb For This Useful Post:
Sportsguy83 (09-17-2013)
Old 09-17-2013, 12:01 AM   #6265
mad_sb
OK, I'll bite, why is your knock correction learned value zero? Hmm could it be because john had a lot of issues with the IAM working it's way down to zero becaue of knock so he just decided to defeat the whole course correction (IAM) system?
mad_sb is offline
Old 09-17-2013, 12:05 AM   #6266
blubrz
Drives: WRB BRZ
Why the hell have you seen them and no one else? I'm trying to get something good going on here. Post em up!!
WAIT!!! ALL? I just posted my FI (Vortech Supercharger) log. It was scary?
I really want people to come forward. Everyone post their log. Seriously.
Let's help each other out. John sure isn't going to.
blubrz is offline
Old 09-17-2013, 12:07 AM   #6267
blubrz
Drives: WRB BRZ
Not sure. Would no knock not warrant a no knock correction learned?
blubrz is offline
Old 09-17-2013, 12:23 AM   #6268
mad_sb
This will explain the details better than i can after a few belgian ale's.
I saw this on a few of his tunes. I assume he was having issues with the IAM continuting to work it's way down. You have 3 components to knock control on subaru ecu's.
Feedback correction (what is logged as Knock correction (ca))
Course correction (IAM changes)
Fine Learing (the system that decides when to move the IAM up)
The IAM system relies on the ignition advance table, which is added to the base ignition timing by the formula Learned Knock Correction = IAM * Ignition advance map. there are a couple of load and rpm tables that affect when the course correction system is at play, but from what i can see of your log, JV have zeroed out the ignition advance map.
I can not thing of any good reason to do this. It defeats one of the OEM knock control mechanisms. On a forged internals motor perhaps, but then it would be dyno tuned and on the conservative side.
I will say that even those -1's are a lot more frequent than the last pump gas tune i did for my car and that was using kroger gas.
In short, the igntion advance map looks like this in stock form, if it has been set to zero (as would be indicated by zero knock correction learned value when load is over .6 g/rev) there is an issue the tuner was trying to work around.
mad_sb is offline
Old 09-17-2013, 12:48 AM   #6269
mad_sb
I wonder when did I insult you.... Again, facts are there. Same gas, same boost, two tunes.
One knocks at -5, the other knocks at 0. FYI, tuning "for crappy gas" means removing timing and making less power, not zero knock and more power so.
One makes 245 WHP, the other makes 278 WHP. The proof is in the pudding.
Psssst... its not the gas, its ruled out when it has been the same in the car since I bought it more than a year ago.
Also, its the last post Im making about it. Its beaten to death, you take the facts and come to your own conclusions. No need to agree with me. If you still think its the gas or my car more power to you
If I had a horse, I would kill it and invite you over to hit it repeatedly with me (beat it sounds too gehy )
mad_sb is offline
Old 09-17-2013, 02:00 AM   #6270
mobybrz
Drives: White 2013 BRZ
Originally Posted by Calum View Post
Sounds like a good thread to be stickied in a tuning forum... mods MODS?!
Sent from my GT-S7560M using Tapatalk 4
Would you prefer a google form that we can all see the results of:
https://docs.google.com/forms/d/1cRB...vDaKw/viewform
(obvious beta is obvious...feedback encouraged)
mobybrz is offline
The Following User Says Thank You to mobybrz For This Useful Post:
Yruyur (09-17-2013)
Old 09-17-2013, 02:21 AM   #6271
Yruyur
Yruyur's Avatar
Very nice. Start a new thread and lets get this off his thread.
Sent from a Motorola DynaTAC 8000X
Yruyur is offline
Old 09-17-2013, 02:22 AM   #6272
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
This was at idle. Sorry I don't have a knock log to share, but I didn't feel like hitting the gas with maxed out fuel trims and four check engine codes (one being p0171 = lean).
EDIT: Codes are not present on stock or ANY OTHER tunes.
Nightbringer is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
