Old 09-16-2013, 08:45 PM   #393
FR-S Matt
Originally Posted by OICU812 View Post
You're 18x9.5" all way around correct? How you getting away with near zero camber up front and so on...? Or am I reading your finals wrong?
Nope, its correct. Rear still has some camber. Stock bolts still. I still have the white line camber bolts packaged. 18x9.5 square, +38 offset. Not sure how low, but I have about a 1 1/2 gap from tire to fender all around. Pics this weekend when I clean the car.
These SPC arms are great. These should have been stock on the car.
Old 09-16-2013, 10:07 PM   #394
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Ok I'm just really surprised that you can get away with little to no camber up front with such wide wheels are you running a very stretched tire?
Old 09-16-2013, 10:17 PM   #395
jeebus
Originally Posted by FR-S Matt View Post
Here are my alignment specs. Decided not to go with the more negative camber route. I think I'll be just fine and I am happy with the outcome. It does handle extremely well now. Let me know your thoughts on it.
The front camber settings are too wussy. Rear and front toe in? Why?
jeebus is offline   Reply With Quote
Old 09-16-2013, 10:53 PM   #396
FR-S Matt
That's hardly any toe at all. I'd rather have slight toe in for straight line. The front camber isn't necessary unless I'm racing with hard cornering. Besides, I can always adjust that later if I want. This is my DD.
Old 09-17-2013, 04:14 AM   #397
OICU812
Just a dude
OICU812's Avatar
Oh ok I thought you put on some T0s and had lowered bunch more. Good to know also on the SPCa thx!
Old 09-17-2013, 10:02 AM   #398
Racecomp Engineering
Hmmmm, I mean if you're happy with how it handles that's good, but honestly that's just way too little camber. I'd expect better and more even tire wear with the alignment that you posted right before that. And of course better handling.
- andy
Old 09-17-2013, 10:22 AM   #399
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
- andy
I agree.
This is my current alignment, and after my last road course / auto x I can say i'm VERY happy with the camber settings.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
OICU812 (09-17-2013)
Old 09-18-2013, 12:07 PM   #400
jeebus
A little toe in at the rear makes sense, but I just don't see any need at the front. But your front camber...slightly positive? Do you not drive in corners at all?
Old 09-18-2013, 01:21 PM   #401
FR-S Matt
I do, but I don't drive like a racecar everywhere I go.
I may adjust the camber to -1.5 later if I feel the need to. Right now it's pretty crisp and corners well at 0.
Old 09-18-2013, 04:34 PM   #402
FRSTEVE
@jeebus - when you say slightly positive, are you look at the before measurements section? I'm seeing -1.5 and -1.6 on the screenshot for the current measurements.
FRSTEVE is offline   Reply With Quote
Old 09-18-2013, 04:43 PM   #403
I think you're looking at Gopherboy, not FR-S Matt.
- Andy
Old 09-18-2013, 04:54 PM   #404
FRSTEVE
@Racecomp Engineering - oops! you're right, forgot who the OP was. BTW, saving up for some of the Zeros!!!
The Following User Says Thank You to FRSTEVE For This Useful Post:
Racecomp Engineering (09-18-2013)
Old 09-20-2013, 02:22 AM   #405
thebear21
thebear21's Avatar
Drives: scion fr-s (RIP)
tarmac 0's 280's to 96734 any service member discounts?
thebear21 is offline   Reply With Quote
Old 09-20-2013, 01:32 PM   #406
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Just bolted on a set of T2s with 400/400. Very nice so far. I still need to get the rear camber adjusted, then a full alignment. Then there's tuning them. But initial impressions are surprisingly comfortable.
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 08:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 01:44 AM
